Macintosh Plus
Revision as of 18:06, 4 April 2025 by Josh (talk | contribs) (Undo revision 1167 by Josh (talk))
Macintosh Plus
Macintosh Plus
TypePersonal Computer
ReleasedJanuary 16, 1986
DiscontinuedOctober 15, 1990
Intro priceUS$2,599
CPUMotorola 68000 @ 8 MHz
Memory1 MB RAM (expandable to 4 MB)
Storage800 KB 3.5" floppy drive, External SCSI
Display9" monochrome CRT (512×342 pixels)
SoundMonaural 8-bit, 22 kHz (4-voice)
Dimensions13.6" H × 9.6" W × 10.9" D
Weight16.5 lbs (7.5 kg)
OS / FirmwareSystem 3.0 – System 7.5.5
PredecessorMacintosh 512K
SuccessorMacintosh SE
CodenameMr. T
Model no.M0001A
Historical Background
The Macintosh Plus was the third model in Apple’s Macintosh line, introduced on January 16, 1986. It shipped with 1 MB of RAM (expandable to 4 MB) and introduced an external SCSI port, significantly improving over the Macintosh 512K. Initially beige-colored (Pantone 453), the case became platinum gray in 1987. The Plus could run up to System 7.5.5, introduced SIMM memory modules, and featured an 800 KB floppy drive.
For detailed general maintenance practices including cleaning, PRAM battery handling, connector corrosion prevention, and voltage adjustments, please see the dedicated Macintosh Plus General Maintenance page.
The Macintosh Plus features two main PCBs: the Logic Board and Analog Board. Below are detailed schematics and the official Apple service manual for the Macintosh Plus.
Apple Service Manual
File:Macintosh Plus.pdf
Macintosh Plus PCB Schematics
Logic Board Analog Board
Macintosh Plus Logic Board
Macintosh Plus Logic Board Schematic
Analog Board
Detailed capacitor replacement guidelines for both analog and logic boards can be found on the Macintosh Plus Capacitor Replacement Guide page.
File:MacintoshPlus CapacitorLocations.jpg
Capacitor replacement locations placeholder
Retrobrite
File:MacintoshPlus Retrobrite.jpg
Retrobrite before/after placeholder
A comprehensive troubleshooting guide addressing no power, chime but no video, intermittent operation, Sad Mac errors, and floppy drive problems is available on the Macintosh Plus Troubleshooting page.
