Macintosh Plus
Revision as of 12:54, 23 April 2025 by Josh (talk | contribs)
Macintosh Plus
Macintosh Plus
TypePersonal Computer
ReleasedJanuary 16, 1986
DiscontinuedOctober 15, 1990
Intro priceUS$2,599
CPUMotorola 68000 @ 8 MHz
Memory1 MB RAM (expandable to 4 MB)
Storage800 KB 3.5" floppy drive, External SCSI
Display9" monochrome CRT (512×342 pixels)
SoundMonaural 8-bit, 22 kHz (4-voice)
Dimensions13.6" H × 9.6" W × 10.9" D
Weight16.5 lbs (7.5 kg)
OS / FirmwareSystem 3.0 – System 7.5.5
PredecessorMacintosh 512K
SuccessorMacintosh SE
CodenameMr. T
Model no.M0001A
The Macintosh Plus was the third model in Apple’s Macintosh line, introduced on January 16, 1986. It shipped with 1 MB of RAM (expandable to 4 MB) and introduced an external SCSI port, significantly improving over the Macintosh 512K. Initially beige-colored (Pantone 453), the case became platinum gray in 1987. The Plus could run up to System 7.5.5, introduced SIMM memory modules, and featured an 800 KB floppy drive.
For detailed general maintenance practices including cleaning, PRAM battery handling, connector corrosion prevention, and voltage adjustments, please see the dedicated Macintosh Plus General Maintenance page.
The Macintosh Plus features two main PCBs: the Logic Board and Analog Board. Below are detailed schematics and the official Apple service manual for the Macintosh Plus.
Apple Service Manual
You can download the Service Manual here: File:Macintosh Plus.pdf
Macintosh Plus PCB Schematics
Logic Board Analog Board
Macintosh Plus Logic Board
Macintosh Plus Logic Board Schematic
Analog Board
Detailed capacitor replacement guidelines for both analog and logic boards can be found on the Macintosh Plus Capacitor Replacement Guide page.
Retrobrite
A comprehensive troubleshooting guide addressing no power, chime but no video, intermittent operation, Sad Mac errors, and floppy drive problems is available on the Macintosh Plus Troubleshooting page.
Sub-system Specification (Macintosh Plus, Jan 1986)
CPU Motorola 68000 @ 7.8336 MHz (15.667 MHz ÷ 2)
Bus width 16-bit data • 24-bit address (16 MB logical)
ROM 128 KB “v4.0” Toolbox / HFS / SCSI Manager
RAM 1 MB on four 256-K × 1 DRAM SIMMs — expands to 4 MB via 30-pin SIMM slots
Video 512 × 342 monochrome frame-buffer (22.1 KB) DMA-shared with system RAM
Sound 8-bit PWM DAC via VIA timers • 22 kHz RC low-pass → LM380 amplifier
Disks Sony OA-D34V-22 800 KB auto-inject 3.5″ floppy
I/O ports DE-9 mouse/KB • DB-19 ext. floppy • DB-25 SCSI-1 • RS-422 serial × 2 • 3.5 mm audio-out
Memory Map (Physical)
Macintosh Plus Address Space
Range Size Purpose
$000000 – $3FFFFF 4 MB DRAM (configured 1 MB – 4 MB)
$400000 – $41FFFF 128 KB ROM (v4.0 Toolbox)
$480000 – $4BFFFF 256 KB I/O A – VIA 1, VIA 2, SCC, IWM, VBL PAL
$580000 – $5BFFFF 256 KB I/O B – WD 5380 SCSI DMA registers
$600000 – $FFFFFF Mirrors / reserved
  • Frame-buffer note:* still occupies the last 22 016 bytes of physical RAM (e.g. $3FE000 – $3FFFFF in a 4 MB system).
ROM Layout (128 KB, v4.0 “Plus-class”)
Offset Size Module
$400000 8 KB 68000 vectors + Mini-Shell
$402000 20 KB QuickDraw 1.2 (monochrome, relocatable)
$407000 52 KB Toolbox, SANE, Font & Menu mgrs.
$414000 16 KB Sony 800 KB floppy driver & IWM tables
$418000 24 KB SCSI Manager, Disk Cache, HFS
$41E000 8 KB I/O traps, Declarations, Copyright
SCSI Sub-system
  • Western Digital WD 5380 NCR-compatible controller
  • 5 MB s⁻¹ 8-bit synchronous (practically 1.2 MB s⁻¹ async)
  • DMA-like handshake handled in software by 68000 — no true DMA
Floppy-Disk Format (800 KB GCR)
  • 80 tracks • double-sided variable-speed
  • 12 → 8 sectors/track (outer→inner) • 512-byte sectors
  • 800 KB formatted • still uses IWM (not yet SWIM)
Key I/O ICs
  • 6522 VIA × 2 — timers, sound PWM, keyboard/mouse handshake
  • 8530 SCC — dual RS-422 serial (230 kbps)
  • IWM — Integrated Woz Machine floppy controller
  • WD 5380 — 8-bit SCSI controller
  • MC6883 PAL — VBL interrupt & DRAM cycle arbiter
Sound Path
68000 → VIA Port A (8-bit sample) • VIA Timer 1 toggles Port B at 22.254 kHz → PWM → RC filter → LM380 → speaker / headphone jack.
RAM Upgrade Notes
  • Uses four 30-pin SIMM sockets (Bank 0 & Bank 1).
  • Accepts 256 KB or 1 MB SIMMs, 150 ns or faster.
  • Mixed sizes allowed per bank (must match within a bank); 4 MB max.
Hardware Easter Egg
Boot while holding ⌘ + Option + ⇧ + Clear to hear the hidden *bass-only* startup chime — final compact-Mac model to include it.
