The Atari 65XE is an 8-bit home computer introduced by Atari Corporation in 1985 as part of the XE ("XL Enhanced") series. It maintained compatibility with the Atari 8-bit family while featuring a redesigned case and revised electronics, targeting the home computing and gaming market during the mid-1980s.
Atari 65XE
Atari 65XE Home Computer
ManufacturerAtari Corporation
TypeHome Computer
Released1985
Discontinued1992
Intro priceUS$120 (1985)
CPUMOS Technology 6502C @ 1.79 MHz (NTSC) / 1.77 MHz (PAL)
Memory64 KB RAM, 16 KB ROM (BASIC, OS)
StorageExternal cassette tape (410/1010), optional 5.25" floppy disk drive (1050/XF551)
Display320×192 pixels, 40×24 text, 16 colours (ANTIC/GTIA)
SoundPOKEY: 4 voices, 8-bit, noise, envelope, keyboard scan
Dimensions34 cm × 24 cm × 7 cm
Weight1.7 kg
OS / FirmwareAtari BASIC (in ROM), Atari OS
PredecessorAtari 800XL
SuccessorAtari 130XE
CodenameSweet-16
Model no.65XE
🧠 Architecture and Processor
At its core, the 65XE uses the MOS Technology 6502C microprocessor, a variant of the classic 6502, running at:
  • 1.79 MHz (NTSC systems)
  • 1.77 MHz (PAL systems)
The 6502C coordinates system operations and interfaces with Atari’s custom chips, including ANTIC (video), GTIA (graphics), POKEY (sound and I/O), and PIA (peripherals).
💾 Memory and Storage
The Atari 65XE is equipped with:
  • 64 KB RAM
  • 16 KB ROM, comprising:
    • 10 KB for the operating system (OS)
    • 6 KB for Atari BASIC (Revision C)
Storage options include:
  • Cassette tape drive (Atari 410/1010)
  • 5.25" floppy disk drive (Atari 1050, XF551)
  • Cartridge slot for instant program loading
🖥️ Display and Graphics
Video output is managed by the ANTIC and GTIA chips, providing:
  • Resolution up to 320×192 pixels
  • Text display: 40 columns × 24 rows
  • 16 colours (palette from 256 possible hues/luminances)
  • Multiple graphics modes (ANTIC modes 2–15), hardware vertical/horizontal scrolling
  • Hardware sprites ("player/missile graphics") for smooth animation
The XE series supports composite and RF video output for connection to TVs and monitors.
🔊 Sound Capabilities
Audio is generated by the POKEY chip, offering:
  • 4 independent audio channels (voices), each 8-bit
  • Programmable frequency, noise, and envelope control
  • Keyboard scanning and serial I/O support
  • Capable of complex sound effects and simple music synthesis
🎮 Input/Output and Expansion
The 65XE provides a range of I/O ports:
  • Cartridge slot – for software and hardware expansions
  • SIO (Serial Input/Output) port – connects to disk drives, printers, modems, and other peripherals
  • Two joystick ports – compatible with Atari-standard controllers
  • Composite and RF video outputs – for TV/monitor connection
  • Parallel bus (internal, not user-accessible) for memory upgrades and peripherals
The XE series dropped the XL’s parallel bus connector, limiting some expansion options compared to earlier models.
🔍 PCB Schematics & Service Manual
The Atari 65XE features a compact mainboard integrating the 6502C CPU, ANTIC, GTIA, POKEY, and RAM/ROM ICs. Service documentation and schematics are essential for repair and restoration.
Logic Board Schematic Diagrams
Atari 65XE Logic Board
File:Atari65XE Schematic.png
Atari 65XE Mainboard Schematic
For full service documentation, see the Atari 65XE Service Manual
