Macintosh Plus
Revision as of 12:15, 12 March 2025 by Josh (talk | contribs)
Macintosh Plus
Type Personal Computer
Release Date January 16, 1986
Discontinued October 15, 1990
Introductory Price US$2,599
CPU Motorola 68000 @ 8 MHz
Memory 1 MB RAM (expandable to 4 MB)
Storage 800 KB 3.5" floppy drive, External SCSI
Display 9" monochrome CRT (512×342 pixels)
Sound Monaural 8-bit, 22 kHz (4-voice)
Dimensions 13.6" H × 9.6" W × 10.9" D
Weight 16.5 lbs (7.5 kg)
OS System 3.0 – System 7.5.5
Predecessor Macintosh 512K
Successor Macintosh SE
Codename Mr. T
Model M0001A
Historical Background
The Macintosh Plus was the third model in Apple’s Macintosh line of personal computers, introduced on January 16, 1986. It was a significant improvement over its predecessor, the Macintosh 512K, shipping with 1 MB of RAM (expandable to 4 MB) and introducing an external SCSI port for the first time on a Mac. Priced at US$2,599 at launch, the Macintosh Plus was highly successful and remained on the market until October 1990. Originally released in beige (Pantone 453), the case color was changed to platinum gray in 1987. The Macintosh Plus was the earliest Mac capable of running System 7 (up to version 7.5.5) and introduced user-upgradable SIMM memory modules and an 800 KB double-sided floppy drive.
To keep your Macintosh Plus in good condition:
  • Regularly clean dust from inside the unit.
  • Inspect and replace the PRAM battery if needed.
  • Check connections regularly for corrosion or looseness.
  • Periodically power on the device to maintain capacitors.
PCB Schematics
The Macintosh Plus features two main PCBs: the Logic Board and Analog Board. Detailed schematics are available in the two images attached as well as the maintenance manual. File:Macintosh Plus.pdf
Macintosh Plus Logic Board
Macintosh Plus Logic Board Schematic
Analog Board
Analog Board Schematic
Electrolytic capacitors on the analog board commonly fail and should be replaced proactively. Recommended capacitors include:
  • Main filter capacitor (RIFA) (4700µF)
  • High-voltage CRT capacitors (e.g., 10µF 160V)
  • Medium-value capacitors (22µF, 33µF, 47µF)
File:MacintoshPlus CapacitorLocations.jpg
Capacitor replacement locations placeholder
Retrobrite
To address plastic yellowing:
  • Apply hydrogen peroxide-based Retrobrite evenly.
  • Expose treated parts to UV light.
  • Rinse thoroughly after treatment.
File:MacintoshPlus Retrobrite.jpg
Retrobrite before/after placeholder
Common issues include:
No Power
  • Check fuse and RIFA capacitors on the analog board.
  • Inspect solder joints on analog board.
  • Check the voltages on the cable connecting the analog board to the logic board.
If you still don't have power, a full recap may be required.
Chime but No Video
  • Adjust brightness control.
  • Check video connector and solder joints.
Unstable Operation
  • Verify and adjust the +5V supply.
  • Inspect and recap analog board.
Sad Mac Errors
Common Sad Mac error codes:
  • 01xxxx – ROM issues.
  • 02xxxx – RAM issues.
Floppy Drive Problems
  • Clean and lubricate drive mechanics.
  • Check and replace eject gear if necessary.
Image Uploads
Please upload relevant images for each section:
  • Front and rear views
  • PCB schematics
  • Capacitor replacement locations
  • Before/after Retrobrite photos
  • Floppy drive mechanics
