Laserwriter And Laserwriter Plus Manual 030-1296-a 1986
LaserWriter and LaserWriter Plus is Apple's 1986 owner's manual for the LaserWriter and LaserWriter Plus printers, part number 030-1296-A. It has 146 printed pages (vii front pages, 1-146); the scan has 155.[1] It was written for owners using a Macintosh 512K, Macintosh Plus or Macintosh XL, and covers both printers and the LaserWriter Plus Kit that upgrades a LaserWriter to a Plus.[2]
Contents
Page numbers are the manual's own.[1]
  • About This Manual (p. vi); The LaserWriter and the LaserWriter Plus (vii)
  • Chapter 1, Setting Up the LaserWriter (1): what you need (3), the LaserWriter Plus Kit (4), choosing a place (5), unpacking and setting up (7), installing the toner cartridge (11) and cleaning pad (15), paper trays (16), loading the paper cassette (17), powering up (19), connecting to your Macintosh (23), the AppleTalk connector (23), testing the AppleTalk connection (24)
  • Chapter 2, Installation and Printing (29): printer software and printing resources (32-37), screen fonts (38-44), printing with the LaserWriter (45), Page Setup and Print options (49-52), about paper (53)
  • Chapter 3, Using the LaserWriter (55): Hard Disk 20 installation (58), printing with the Macintosh 512K, XL and Plus (60), manual feed (63-64), changing and naming printers (65-66), adding and removing resources and fonts (67-68)
  • Chapter 4, Maintenance and Troubleshooting (73): replacing the toner cartridge (75), installing the new cleaning pad (80), cleaning the LaserWriter (83), replacing or cleaning the separation belt (85), troubleshooting (87-99): Chooser problems, no test page, a document that will not print, checking the AppleTalk network (93), paper jams (95), image problems (97)
  • Chapter 5, Designing for the LaserWriter (101): sample documents and fonts
  • Appendix A, How the LaserWriter Works (119); Appendix B, Specifications and Ordering Information (120); Appendix C, Status Lights, Sockets and Switch (123); Appendix D, Current Startup Disk (126); Appendix E, Symbol and Zapf Dingbats keyboard equivalents (127); Appendix F, Non-AppleTalk Products, including Diablo 630 emulation (129); Appendix G, Interference and Safety (132); Appendix H, Service and Support (133); Glossary (135); Index (141)
What it settles
Appendix B gives Apple's specification. The engine is a Canon LBP-CX; the controller has a 12 MHz 68000, ½ MB of ROM, 1½ MB of RAM and AppleTalk and RS-232C interfaces. Print resolution is 300 dpi, speed up to eight pages per minute, and the recommended duty cycle up to 4,000 pages per month. Power is 115 V AC ±10% 60 Hz (US) or 220 or 240 V AC ±10% 50 Hz (Europe). The printer is 18.5 in wide, 16.2 in deep (28.2 in with trays), 11.5 in high and weighs 77 lb.[3] The ordering list gives M0156 (110 V) and M0156Z (220 V) for the LaserWriter, M0191 for the LaserWriter Plus Kit and M0180 for the toner cartridge.[3]
At power-on the green light flashes while the printer warms up, the yellow light flashes while it processes the test page, and a test page appears within about two minutes. The test page shows the mode-switch position and the number of pages printed. A green test light on the back of the printer means the controller electronics are not working.[4] Appendix C lists the status lights, the four-position mode switch (AppleTalk, Special, 9600, 1200) and the pin assignments of the 9-pin RS-422 port (3 signal ground, 4 and 5 transmit data, 8 and 9 receive data) and the 25-pin RS-232 port (2 transmit data, 3 receive data, 4 RTS, 7 signal ground, 20 DTR).[5]
The owner maintenance in Chapter 4 is cartridge replacement, the cleaning pad, cleaning the transfer guide, transfer wire and rollers, and replacing or cleaning the separation belt. Apple says to clean the belt with water, not alcohol, when a black line runs down the right side of printed pages.[6]
It is an owner's manual. There are no service procedures, no board-level information, no parts list and no DC supply voltages.[1] Service procedures and part numbers are in the LaserWriter Plus Service Source.
Pages that cite this document
Download: LaserWriter and LaserWriter Plus manual 030-1296-A 1986.pdf
  1. ↑ 1.0 1.1 1.2 Apple Computer, Inc., LaserWriter and LaserWriter Plus (1986), copyright page and contents pp. iii-v (PDF pp. 2-6); index ends p. 146 (PDF p. 155). Hosted as File:LaserWriter and LaserWriter Plus manual 030-1296-A 1986.pdf.
  2. ↑ LaserWriter and LaserWriter Plus, About This Manual and The LaserWriter and the LaserWriter Plus, pp. vi-vii (PDF pp. 7-8).
  3. ↑ 3.0 3.1 LaserWriter and LaserWriter Plus, Appendix B, LaserWriter Specifications and Ordering Information, pp. 120-122 (PDF pp. 129-131).
  4. ↑ LaserWriter and LaserWriter Plus, Powering Up, pp. 19-22 (PDF pp. 28-31), and Troubleshooting, p. 89 (PDF p. 98).
  5. ↑ LaserWriter and LaserWriter Plus, Appendix C, LaserWriter's Status Lights, Sockets, and Switch, pp. 123-125 (PDF pp. 132-134).
  6. ↑ LaserWriter and LaserWriter Plus, Chapter 4, Taking Care of the LaserWriter, pp. 75-86 (PDF pp. 84-95).
