Macintosh Quadra 605 General Maintenance
(Redirected from LC 475 General Maintenance)
Proper maintenance is essential to extending the lifespan and ensuring reliable operation of your Macintosh Quadra 605. This guide also applies to the LC 475, Performa 475, and Performa 476, which share the same logic board.
Regular Cleaning
Internal Cleaning
  • Power off and unplug the computer. Allow capacitors to discharge for several minutes.
  • Remove the top case by pressing the release tabs on the rear.
  • Use compressed air to remove dust from the logic board, power supply, and floppy drive.
  • For stubborn dust, use a soft ESD-safe brush.
  • Clean fan blades if present (some configurations include internal fans).
  • Inspect for signs of capacitor leakage, corrosion, or pest damage.
External Cleaning
  • Wipe the case with a slightly damp cloth. Avoid excess moisture near vents.
  • Clean the floppy drive slot with compressed air.
  • Use isopropyl alcohol on a cotton swab for stubborn marks.
Keyboard and Mouse Cleaning
  • ADB keyboards can be cleaned by removing keycaps and washing them in soapy water.
  • Clean under the keys with compressed air.
  • ADB mice should have the ball removed and rollers cleaned with isopropyl alcohol.
PRAM Battery Handling
Battery Specifications
The Quadra 605 uses a 3.6V lithium battery (typically 1/2 AA size) for PRAM. This battery maintains system settings including date, time, startup disk, and display preferences.
Best Practices
  • Check the battery voltage annually. Replace if below 3.2V.
  • Remove the battery if storing the machine long-term to prevent leakage.
  • The stock battery holder can be replaced with a CR2032 holder for easier battery changes.
  • New batteries should last 3-5 years under normal use.
Cleaning Battery Leakage
If the PRAM battery has leaked:
  • Remove the battery immediately.
  • Neutralize lithium battery residue with distilled white vinegar applied via cotton swab.
  • Follow with isopropyl alcohol to clean and dry the area.
  • Inspect nearby traces and components for corrosion damage.
  • Test continuity of traces near the battery holder.
Connector and Socket Corrosion
Key Areas to Check
  • SIMM socket โ€“ Oxidation can cause RAM errors. Clean contacts with DeoxIT D5.
  • VRAM sockets โ€“ Same treatment as SIMM socket.
  • CPU socket โ€“ If the machine has been upgraded, check for oxidation on socket pins.
  • ADB port โ€“ Corrosion can cause keyboard/mouse issues.
  • SCSI connector โ€“ Both internal and external connectors should be inspected.
  • Floppy drive connector โ€“ Ribbon cable connections can oxidize.
Use DeoxIT D5 on a cotton swab for cleaning connector contacts. For stubborn oxidation, a fiberglass pen can be used carefully on gold contacts.
Common Failure Points
Capacitor Health
The Quadra 605 logic board uses surface-mount electrolytic capacitors that are prone to failure after 25+ years. Symptoms of capacitor failure include:
  • Failure to power on
  • Startup chime but no video
  • Intermittent operation
  • Corrosion visible on logic board
See the Macintosh Quadra 605 Capacitor Replacement Guide for detailed replacement information.
Power Supply Capacitors
The LC-series power supply shared by the Quadra 605 is also prone to capacitor failure. Symptoms include:
  • No power
  • Clicking or ticking sounds
  • Intermittent startup
  • Unstable voltages
The power supply should be recapped along with the logic board.
PRAM Battery Damage
Leaking PRAM batteries can destroy traces on the logic board. Inspect the area around the battery holder regularly.
Floppy Drive
The manual-inject floppy drive can fail due to:
  • Worn eject gear (common failure point)
  • Dirty heads โ€“ clean with isopropyl alcohol on a cotton swab
  • Failed capacitors in the drive mechanism
SCSI Hard Drive
Original SCSI drives are mechanical and will eventually fail. Consider replacing with:
  • SCSI2SD adapter
  • BlueSCSI
  • ZuluSCSI
These solid-state replacements are more reliable and quieter.
Voltage Adjustment and Power Checks
The power supply does not have adjustable voltage outputs. However, you should verify proper voltage levels when troubleshooting:
Expected Voltage Levels
Rail Expected Range
+5V 4.85V โ€“ 5.25V
+12V 11.4V โ€“ 12.6V
Measure voltages at the logic board power connector with the system under load. Out-of-spec voltages indicate power supply problems, typically failed capacitors.
Thermal Considerations
The Quadra 605's compact case has limited airflow. Ensure:
  • All ventilation slots are clear of dust and obstruction.
  • The machine is not placed in enclosed spaces.
  • Consider adding thermal pads between the CPU and case if overheating occurs.
The 68LC040 runs relatively cool but can still benefit from adequate ventilation.
