Macintosh Quadra 900 Troubleshooting
(Redirected from Quadra 950 Troubleshooting)
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh Quadra 900. This guide covers the most common problems encountered with this tower workstation.
The Quadra 900 shares its case design and many components with the Quadra 950. Most troubleshooting procedures apply to both systems.
  • Verify the power cable is securely connected
  • Check that the key-lock switch is in the "On" position (not "Off")
  • Test with a known-good power outlet
  • Disconnect all external peripherals except keyboard and monitor
  • Remove all NuBus and PDS cards temporarily
Power supply specifications:
  • Input: 100-240V AC, 50-60 Hz
  • Maximum output: 303W
  • +5V rail: 4.85V โ€“ 5.15V
  • +12V rail: 11.9V โ€“ 12.7V
No Power (Unit Dead)
Macintosh Quadra 900. Source: Wikimedia Commons.
No response when power button pressed Key-lock in "Off" position Turn key-lock to "On" position
No response, key-lock is "On" Failed power supply Test power supply outputs; replace if necessary
No response PRAM battery dead or leaking Replace PRAM battery, check for corrosion
No response Failed power button or front panel cable Check front panel connections, test power button continuity
Fans spin briefly then stop Power supply capacitor failure Recap or replace power supply
Ticking or clicking sound Power supply overload or short Remove all cards and drives; test with minimal configuration
Chime but No Video
Video Issues After Startup Chime
Chime, no video, drive activity normal Monitor not connected properly Check DB-15 video cable connection
Chime, no video Monitor incompatible or failed Test with known-good monitor
Chime, no video VRAM failure Reseat or replace VRAM SIMMs
Chime, no video NuBus video card conflict Remove NuBus video cards, test built-in video
Chime, scrambled or distorted video VRAM failure Replace VRAM SIMMs
Chime, rolling or unstable picture Monitor sync issues or analog board problem Try different monitor; check video cable
Sad Mac Error Codes
See the Sad Mac Error Codes page for a complete reference.
Common Sad Mac Codes for Quadra 900
Error Code Meaning Recommended Action
0000000F ROM test failed May indicate logic board failure
0001xxxx RAM test failure Reseat or replace RAM SIMMs
0002xxxx RAM addressing error Check RAM configuration (must be in groups of 4)
0003xxxx RAM write/read error Replace failed SIMM group
0005xxxx ROM checksum error May indicate logic board failure
000Exxxx Data bus test failed Check for shorts; may indicate logic board failure
Stability Issues
Random crashes during use Failing capacitors Inspect and recap logic board and power supply
Crashes during heavy load Insufficient power or overheating Check power supply voltages; verify fan operation
Crashes after warmup Thermal-related component failure Check for cold solder joints; inspect capacitors
Freezes with disk activity SCSI chain issues Check termination and ID conflicts
Intermittent boot failures Dirty or corroded contacts Clean RAM sockets, NuBus slots, and connectors
System hangs at startup PRAM corruption Reset PRAM (Cmd+Option+P+R at startup)
Erratic behavior Bad PRAM battery Replace 3.6V lithium battery
RAM Issues
Memory Problems
System reports less RAM than installed SIMM not seated properly Reseat all SIMMs
System reports less RAM Mismatched SIMM group SIMMs must be installed in matched groups of 4
Crashes when accessing large amounts of memory Failing SIMM Test by removing SIMM groups one at a time
RAM errors on boot Wrong speed SIMMs Use 80 ns or faster 30-pin SIMMs
Intermittent RAM errors Dirty SIMM contacts Clean SIMM contacts with isopropyl alcohol
SCSI Device Issues
SCSI Problems
SCSI devices not recognized SCSI ID conflict Verify each device has unique ID (0-6)
Drives not found Missing termination Terminate at both ends of SCSI chain
System hangs during SCSI scan Cable or connector issue Check cables; clean connectors
Intermittent drive access Failing drive or cable Test with known-good drive and cable
Floppy icon with blinking question mark No bootable system found Check hard drive, reinstall system software
Floppy Drive Issues
Floppy Drive Problems
Disk not recognized Dirty read/write heads Clean heads with isopropyl alcohol
Disk stuck in drive Failed eject mechanism Manual eject via paperclip hole
Disk ejects immediately Disk unreadable or wrong format Try different disk; may need head alignment
Grinding noise during read Worn or dirty mechanism Clean and lubricate drive mechanism
Floppy disabled (Secure mode) Key-lock in "Secure" position Turn key-lock to normal "On" position
Audio Issues
Sound Problems
No startup chime Speaker disconnected Check internal speaker connection
No sound, chime works Sound output muted in software Check Sound control panel settings
Distorted audio Failing capacitors Recap logic board
Crackling or popping Bad solder joints Inspect and reflow audio circuit solder joints
NuBus Card Issues
Expansion Card Problems
Card not recognized Poor contact Reseat card; clean edge connector
System crashes with card installed IRQ or resource conflict Try card in different slot
Card works intermittently Oxidized contacts Clean card and slot contacts with DeoxIT
Multiple cards conflict Power limitations Some slots provide only 15W; high-power cards need 25W slots
Capacitor Failure Symptoms
Signs of Capacitor Problems
Symptom Location Recommended Action
No power or immediate shutdown Power supply Recap power supply capacitors
System instability under load Power supply Check and replace filter capacitors
Video distortion Logic board Inspect and recap VRAM area
Audio issues Logic board Recap audio section
Random crashes Logic board or power supply Full recap recommended
See the Macintosh Quadra 900 Capacitor Replacement Guide for detailed instructions.
Key-Lock Security System
The three-position key-lock can cause confusion:
  • Off โ€“ System will not power on at all
  • On โ€“ Normal operation
  • Secure โ€“ System operates but floppy drive and ADB ports are disabled
If the system won't power on or peripherals don't work, check the key-lock position.
โš ๏ธ PRAM battery โ€” remove it now
The Quadra 900 carries a 3.6 V 1/2AA lithium PRAM battery. These leak and can burst, spraying corrosive electrolyte across the logic board and destroying nearby components — often while the machine simply sits in storage. Remove the PRAM battery from any un-serviced unit. If one has leaked, neutralise and clean the residue and repair corroded traces and vias before troubleshooting.[1]
Unlike the LC and Mac II surface-mount-electrolytic boards, the 68040-family Quadra 900 logic board uses tantalum capacitors, which do not leak with age — the logic board does not normally need recapping. If the board misbehaves, look to leaked-PRAM-battery corrosion, socket/connector contacts and the power supply rather than to board capacitors.[2]
  1. โ†‘ "Warning! Exploding Maxell PRAM Batteries", 68kMLA; and MacDat — Macintosh II family. Source for the leaking/exploding lithium PRAM battery that destroys nearby components.
  2. โ†‘ "Apple Macintosh Quadra 650", Retro Viator; and the Apple Macintosh Quadra/Centris 650 Service Source. Source for the 68040-family logic boards using tantalum capacitors (no logic-board recap needed) while the power supply uses electrolytics that do need replacing.
  3. โ†‘ "Compact/Desktop Power Supply Capacitor Lists (by make and model)", 68kMLA; and "Capacitor Replacement in a Vintage Power Supply", Big Mess o' Wires. Source for the shared desktop PSU form factor (IIci/IIcx/IIvi/IIvx/Performa 600/Quadra 650/Quadra 700), the electrolytic failure symptoms and the PSU capacitor lists.
Surface-mount capacitor leakage
The Macintosh Quadra 900 logic board uses surface-mount electrolytic capacitors whose electrolyte turns corrosive with age and creeps across the board, eating through traces, pads and IC pins. Typical signatures are a machine that will not chime, chimes but shows no video, plays distorted or missing audio, or shows a garbled or checkerboard screen. Wash the affected area and replace every electrolytic with a tantalum or polymer part, then repair any lifted traces. Apple fitted tantalum capacitors on the Macintosh Quadra 900 logic board, so board-level leakage is unusual on this model, but the electrolytic supply still needs it. The switch-mode power supply (ASTEC or TDK on the LC-family machines) holds its own electrolytics and fails the same way, so recap it alongside the board.[1]
PRAM battery
The Macintosh Quadra 900 backs up its clock and Parameter RAM from a 3.6 V ½AA lithium cell. These cells — red Maxell parts especially — leak or burst and corrode the board, so remove an aged one on sight. A flat cell can also stop a soft-power machine booting or disturb the video; left plugged in, trickle power preserves the settings, but a machine switched off at the wall with a dead cell loses them. Clean the area and fit a fresh 3.6 V cell.[2]
Boot chime and Sad Mac
  1. โ†‘ Mac84, Macintosh LC series power-supply recapping guide; the MacCaps capacitor reference; and iFixit. Source for surface-mount electrolytic leakage eating traces, pads and pins, the ASTEC/TDK LC power-supply cap failures, and Apple's use of tantalum (non-leaking) capacitors on the Quadra 700/900 logic boards.
  2. โ†‘ Warning! Exploding Maxell PRAM batteries, 68kMLA; and Mac Battery Leaks, MacDat. Source for the 3.6 V ½AA lithium PRAM cell, the Maxell leak/explosion board damage, and soft- versus hard-power PRAM retention.
