Sega CD (Model 1) Capacitor Replacement Guide
Replacing the ageing electrolytic capacitors in your Sega CD (Model 1) is essential for long-term reliability, clean audio, and stable operation. Decades-old capacitors are prone to leakage and failure, risking damage to the mainboard and causing issues such as audio distortion, random resets, or failure to read discs. Proactive recapping is strongly recommended for all Model 1 units, especially those showing any signs of instability.
editBefore starting, carefully inspect all capacitors for:
- Leaking electrolyte – Brown, green, or white residue at the base of capacitors, especially near the audio and power sections.
- Bulging or domed tops – Indicates internal gas build-up and imminent failure.
- Corroded or stained PCB – Green or black marks near capacitor pads signal leakage.
- Audio hum or distortion – Often caused by dried-out or leaky audio rail capacitors.
- Failure to power on, random resets, or disc read errors – Power rail capacitors with high ESR can cause instability.
If any capacitor is suspect, replace all electrolytics in the unit.
Sega CD Model 1 Capacitor List
editThe Sega CD Model 1 (front-loading) uses a mix of through-hole and surface-mount electrolytic capacitors. Always cross-check with your board’s silkscreen, as minor revisions exist.
Main Board Electrolytic Capacitors
edit| Ref. Designator | Capacitance | Voltage | Type | Function / Notes |
| C1, C2, C3, C4, C5, C6, C7, C8, C9, C10 | 10 µF | 16 V | SMD | General decoupling |
| C11, C12, C13, C14, C15, C16, C17, C18, C19, C20 | 22 µF | 16 V | SMD | Audio path, filtering |
| C21, C22, C23, C24, C25 | 47 µF | 16 V | SMD | Audio output, op-amp rails |
| C26, C27, C28, C29 | 100 µF | 16 V | SMD | Power rail smoothing |
| C30, C31 | 220 µF | 10 V | SMD | Main +5 V, +12 V filtering |
| C32 | 470 µF | 16 V | Through-hole | Main +5 V bulk filter |
| C33 | 1000 µF | 16 V | Through-hole | Main +12 V bulk filter |
| C34 | 2200 µF | 10 V | Through-hole | Primary input filter (from PSU) |
Note: Some revisions may use slightly different values or have additional SMD capacitors. Always verify before ordering replacements.
CD Drive Board Capacitors
| C101, C102, C103, C104 | 10 µF | 16 V | SMD | Servo and logic decoupling |
| C105, C106 | 47 µF | 16 V | SMD | Motor drive filter |
| C107 | 220 µF | 10 V | SMD | Rail smoothing |
If your unit uses a Sony KSS-240A or similar mechanism, check for additional SMD capacitors on the drive PCB.
Recapping Procedure
edit- Unplug and disassemble – Disconnect power, remove the Sega CD from the Mega Drive/Genesis, and open the case by removing all screws on the underside.
- Label all cables – Carefully unplug and label all internal ribbon cables and connectors.
- Remove main and drive boards – Unscrew and gently lift out the main PCB and CD drive PCB.
- Desolder old capacitors – For through-hole types, use a soldering iron and pump or braid. For SMD capacitors, gently heat both ends and lift off with tweezers.
- Clean pads thoroughly – Remove all old solder and any leaked electrolyte with isopropyl alcohol and a brush.
- Install new capacitors – Observe correct polarity (longer lead = positive for through-hole; stripe = negative for SMD).
- Solder carefully – Avoid overheating pads, especially on SMD footprints.
- Inspect work – Check for solder bridges and proper orientation.
- Reassemble and test – Refit boards, reconnect all cables, and reassemble the case.
Recommended Tools & Parts
edit- Temperature-controlled soldering iron (fine tip for SMD, chisel for through-hole)
- Desoldering pump and solder wick
- Fine-tipped tweezers for SMD work
- Isopropyl alcohol (99%) and ESD-safe brush
- High-quality 105 °C, low-ESR capacitors (Nichicon, Panasonic, Rubycon)
- Lead-free or leaded solder (0.5 mm)
- ESD wrist strap
- Magnifier or inspection loupe
Post-Recap Voltage & Function Checks
editAfter reassembly, verify the following at the mainboard test points (with the unit powered and connected to a Mega Drive/Genesis):
| Test Point | Nominal Value | Acceptable Range | Max Ripple (p-p) |
| +5 V (main logic) | 5.00 V | 4.85 – 5.15 V | < 50 mV |
| +12 V (motors, audio) | 12.00 V | 11.5 – 12.6 V | < 120 mV |
| -12 V (audio) | -12.00 V | -11.5 – -12.6 V | < 120 mV |
- Audio output should be free of hum or distortion.
- Disc access should be reliable; random resets or read errors may indicate remaining power issues.
Additional Tips
edit- Always replace all electrolytic capacitors at once – partial recaps are not recommended.
- Clean all leaked electrolyte thoroughly – even small amounts can corrode traces over time.
- Double-check polarity before soldering – reversed capacitors may explode or fail instantly.
- Use SMD-specific tools for surface-mount capacitors to avoid pad damage.
- Test the power supply – a failing external PSU can damage new capacitors and the mainboard.
- If audio remains noisy after recap, check the muting transistors and op-amps.
- Store the Sega CD in a dry environment – humidity accelerates capacitor degradation.
