Apple Service Guide Laserwriter Printers Volume Iii July 1995
The Apple Service Guide for LaserWriter Printers, Volume 3 is Apple's July 1995 field-service booklet for the LaserWriter 16/600 PS, LaserWriter Select 360, Personal LaserWriter 320 and LaserWriter 4/600 PS, part number 072-0142. It has ten front pages and 201 numbered pages; this scan has 208 PDF pages.[1] Like Volume 2, it presents material from the Service Source CD in a format for technicians working at the customer's site.[1]
Contents
Page numbers are the guide's own. In this scan, add ten for the PDF page in the introduction and safety section, nine in chapter 1, eight in chapters 2 and 3, and seven in chapter 4. The fold-out wiring diagrams are bound out of sequence: p. 97 is PDF p. 33, p. 161 is PDF p. 107 (again at PDF p. 168) and p. 201 is PDF p. 170.[1]
  • Introduction (p. 1); Safety (2-6): safety rules, toner, laser and fuser safety, ESD prevention, ESD-safe workstation
  • Chapter 1, General Information (8-24): connecting to a Macintosh, LocalTalk, an IBM PC by parallel cable, and Ethernet (8-11); cable connectors (12); printer ports (13); printer pinouts (14-18: 16/600 PS RS-422, HDI-30 SCSI, Ethernet and parallel; Select 360 RS-232); troubleshooting tips (19-24)
  • Chapter 2, LaserWriter 16/600 PS (26-97): exploded views and parts lists for the printer, envelope feeder and sheet feeder (26-34); I/O and DC controller boards (35); specifications (36); POST and EPOST diagnostics (38); test and configuration pages and configuration switch (40-44); printer utilities for Macintosh, Windows, NetWare and UNIX (45); RAM, fax card and hard drive upgrades (46-50); registration adjustment (51); troubleshooting, with paper sensors, sensing switches, paper path, motors and fans, flowchart and tables (53-96); wiring diagram (97)
  • Chapter 3, LaserWriter Select 360 (100-161): exploded view and parts list (100-105), boards (106), specifications (107), status LEDs, POST and diagnostics (109-110), service test page (111), RAM and fax card upgrades (114), troubleshooting (116-160), wiring diagram (161)
  • Chapter 4, Personal LaserWriter 320 and LaserWriter 4/600 PS (164-201): exploded view and parts list (164-166), boards (167), specifications (169), paper paths (171), status LEDs and diagnostics (172), sensing system (174), service test pages (175-176), mirror adjustment (178), registration adjustment (180), troubleshooting (181-200), wiring diagram (201)
What it settles
LaserWriter 16/600 PS: Canon LBP-P430 engine; 600 dpi; 17.1 pages per minute (letter) or 16.2 (A4); AMD 29030 RISC processor at 25 MHz; 8 MB RAM expandable to 32 MB; 4 MB ROM; QuickDraw, PostScript Level 2 and HP PCL5; about 0.79 kW; 19.1 kg with cassette.[2] The POST tests the SIMM/CPU, I/O controller, engine and any fax card or hard drive, putting out one LED per stage passed; on an error it flashes the toner and jam LEDs alternately. The Extended POST, run by the technician with a serial loopback cable, reports about a dozen more specific codes, charted in Figure 12.[3] After a fusing-system failure the DC controller charges capacitor C208 to prevent overheating; leave the power off for about 10 minutes, or unplug the printer, remove the rear panel, I/O controller board and I/O shield, and jumper the two wires at the base of C208.[4]
LaserWriter Select 360: Fuji Xerox P1 engine, 600 dpi (300 dpi in PCL mode), 10 pages per minute. The specification table repeats the Select Service Source's height of "8.0 in. (25.3 cm)".[5]
Personal LaserWriter 320 and LaserWriter 4/600 PS: Canon P90 engine, 300 dpi (320) or 600 dpi (4/600 PS), about 4 pages per minute; both need 4 MB of RAM in total to print edge to edge on legal paper.[6]
The safety section says to leave the printer switched off for at least 5 minutes before working on the fuser.[1]
What this guide does not contain
There are no schematics and no component values. The board figures locate connectors, switches and a few named parts (such as C208); the wiring diagrams show connections between assemblies. The parts lists cover Apple's service modules and spares.[1]
Pages that cite this document
Download: Apple Service Guide LaserWriter Printers Volume III July 1995.pdf
  1. ↑ 1.0 1.1 1.2 1.3 1.4 Apple Computer, Inc., LaserWriter Printers, Volume III (Apple Service Guide), July 1995, title page, Table of Contents pp. i-vii, Introduction p. 1 and back cover. Hosted as File:Apple Service Guide LaserWriter Printers Volume III July 1995.pdf.
  2. ↑ LaserWriter Printers, Volume III, Tables 7 and 8, pp. 36-37 (PDF pp. 44-45).
  3. ↑ LaserWriter Printers, Volume III, Printer Diagnostics, pp. 38-39 (PDF pp. 46-47).
  4. ↑ LaserWriter Printers, Volume III, Capacitor Discharge, p. 58 (PDF p. 66).
  5. ↑ LaserWriter Printers, Volume III, Table 47, p. 107 (PDF p. 115).
  6. ↑ LaserWriter Printers, Volume III, Table 79, pp. 169-170 (PDF pp. 176-177).
