Atari 400 Troubleshooting Guide
This guide provides detailed, step-by-step troubleshooting for the Atari 400 home computer. It covers common startup failures, video and audio faults, keyboard issues, and memory/logic problems. Component-level checks and proven repair strategies are outlined for both NTSC and PAL models.
Preliminary & Power-up Checks
Begin by confirming the power supply and system voltages before suspecting mainboard faults.
Power Checks
- Verify the external PSU outputs +5 V DC (4.85–5.15 V) under load.
- Inspect the power jack and internal fuse for corrosion or breakage.
- Confirm the power switch moves freely and makes firm contact.
| Test Point | Expected Voltage | Notes |
| Mainboard edge connector (pin 1 = +5 V, pin 2 = GND) | +5 V DC | Primary logic rail |
| Cartridge slot pin 12 (+5 V) | +5 V DC | Cartridge power |
| CPU (6502) pin 8 (Vcc) | +5 V DC | Core supply |
| RESET line (CPU pin 40) | Low → High | Should pulse low at power-on, then rise to 5 V |
Visual Inspection
- Remove the top cover; check for burnt components, loose wires, or corrosion—especially near the power input and voltage regulator.
- Inspect for bulging/leaking capacitors and reflow any suspect solder joints.
Display & Chime Diagnostics
The Atari 400 should display a solid blue screen (NTSC) or light blue (PAL) with the built-in Memo Pad prompt if no cartridge is inserted.
| No video, no sound | No power, blown fuse, or dead voltage regulator | Check PSU, replace fuse, test/replace 7805 regulator |
| Black screen, no border | CPU, ANTIC, or RAM failure | See memory/logic section; swap ICs if socketed |
| Solid colour screen, no prompt | OS ROM or address decoding fault | Reseat/replace OS ROM; check logic chips |
| Rolling, distorted, or B&W video | Bad modulator, wrong TV channel, or faulty GTIA/CTIA | Test on composite output; swap GTIA/CTIA if possible |
| Intermittent video loss | Loose RF cable, cracked solder at modulator | Resolder or replace modulator |
Audio (Power-on Chime)
- The Atari 400 does not produce a startup chime.
- If you hear static or noise from the TV speaker, the audio circuit is at least partially alive.
Memory & ROM Faults
The Atari 400 uses up to 16 KB RAM (typically 8 × 4116 DRAMs) and a socketed OS ROM.
RAM Faults
| Black screen, no cursor | Lower RAM failure (first 8 KB) | Touch DRAMs for overheating; piggy-back or replace suspect chip |
| Garbage characters, random freezes | Upper RAM failure | Test with known-good RAM board; swap chips if socketed |
| Coloured blocks or stripes | Address bus fault or DRAM stuck bit | Check address lines; replace failed DRAM or 74LS158/74LS257 multiplexers |
ROM Faults
| Solid colour screen, no prompt | OS ROM failure | Reseat or replace OS ROM (C012296/C014377) |
| Boots with cartridge, not without | OS ROM bad, cartridge ROM OK | Replace OS ROM |
Connector & Socket Issues
- Cartridge slot: Dirty or oxidised contacts can cause boot failures or crashes. Clean with isopropyl alcohol and a soft brush.
- Keyboard connector: Ribbon cable may loosen or corrode; reseat and clean contacts.
- IC sockets: Early Atari 400s use single-wipe sockets prone to poor contact. Gently rock and reseat chips, or replace sockets if intermittent faults persist.
- Monitor/TV out: Check for bent pins or cracked solder at the modulator and mainboard.
Component-level Tests
Clock & Reset
- The 6502 CPU requires a stable 1.79 MHz (NTSC) or 1.77 MHz (PAL) clock from the system oscillator.
- RESET should pulse low at power-on, then return high (5 V).
- Use a logic probe or oscilloscope to confirm activity at CPU pins 37 (φ2) and 40 (RESET).
Chip Substitution & Piggy-back
- Power off and remove one suspect IC at a time (if socketed).
- Replace with a known-good part, observing orientation.
- For DRAM, piggy-back a good 4116 atop each suspect chip; if behaviour changes, the underlying chip is faulty.
- Never piggy-back custom Atari chips (ANTIC, GTIA/CTIA, POKEY, etc.).
Minimal Boot Configuration
- The Atari 400 will not boot without working RAM, OS ROM, ANTIC, and GTIA/CTIA.
- Remove the cartridge and all unnecessary peripherals for basic diagnostics.
Audio & I/O Failures
Audio Issues
- No sound in games or Memo Pad:
- Suspect POKEY chip (C012294); swap with known-good if socketed.
- Check speaker wiring and TV volume.
- Inspect for cold solder joints at the modulator and audio output.
Keyboard & Joystick Problems
- No key response:
- Reseat keyboard ribbon; clean contacts.
- Test with another keyboard if available.
- Inspect for broken traces on the keyboard PCB.
- Joystick not detected:
- Clean joystick port; check for broken solder joints.
- Faulty POKEY or 4050 buffer IC may cause input failures.
Cartridge & Peripheral Issues
- System boots with Memo Pad but not with cartridge:
- Clean cartridge contacts; test with another cartridge.
- Inspect cartridge slot for bent pins.
- If all cartridges fail, suspect address decoding logic (74LS138/74LS42) or cartridge power rail.
Error & Code Tables
The Atari 400 does not display error codes or beep patterns. For advanced diagnostics, use a test cartridge (e.g., Atari Diagnostic or SALT) if available.
Diagnostic order and the Star Raiders test
On the Atari 8-bit machines the components fail, statistically, in this order: RAM → OS ROM → POKEY → GTIA/ANTIC → CPU. Work through them in that order. The Star Raiders cartridge is a quick diagnostic: it exercises ANTIC, the CPU and GTIA/CTIA, so if it runs those three are good and the fault is narrowed to the PIA, the OS ROM, the MMU or the RAM. Before swapping chips, leave the machine powered for about ten minutes and feel for an overheating RAM chip, and make sure the RAM, OS ROM, ANTIC, MMU, PIA and CPU are all fully seated (reseating cures many garbage-screen / no-boot faults).[1]
Power and clock
- Power: the external "ingot" supply, an oxidised power switch and a cracked DC power connector all cause dead or intermittent operation. Check the switch and connector, and test/replace the 470 uF 16 V radial electrolytic in the left-rear corner of the board.[1]
- CPU clock and reset: check for a clean 1.79 MHz clock at the 6502/SALLY (pin 37), and that RESET pulses low then high at power-up. A RESET stuck low points to the reset circuit.[1]
Keyboard and POKEY
POKEY scans the keyboard and generates the sound and the SIO serial signals. A dead keyboard while sound still works is a classic POKEY (or keyboard-membrane) fault; SIO/peripheral problems also point to POKEY.[1]
- ↑ 1.0 1.1 1.2 1.3 Atari 8-bit pictorial fault guide, 8bithardware; Black Screen [XL/XE Fix Checklist], Atari Owners Club; and AtariAge repair threads. Source for the RAM→ROM→POKEY→GTIA/ANTIC→CPU failure order, the Star Raiders diagnostic cartridge, the seated-socket checks, the PSU 470 uF capacitor and switch/connector faults, and the SALLY 1.79 MHz clock/reset checks.
