PDP-8/e
| PDP-8/E in a rack cabinet at the Computer History Museum (Tomwsulcer, CC0) | |
| Manufacturer | Digital Equipment Corporation |
| Type | 12-bit minicomputer |
| Released | 1970[1][2] |
| Discontinued | 1978[1] |
| Intro price | US$6,500 at introduction[1][2] |
| CPU | TTL processor on three quad modules (M8300, M8310, M8330); 1.2 µs fast and 1.4 µs slow memory cycles[3][1] |
| Memory | 4,096 12-bit words of core (MM8-E), up to 32K[3] |
| Storage | — |
| Display | — |
| Sound | — |
| Expansion | 20-slot OMNIBUS (10 used by the basic computer), expandable to 60 slots[4] |
| Power | 95–130 V or 185–250 V AC, 47–63 Hz; 450 W; H724 or H724A supply[3][5] |
| Dimensions | 10.5 × 19 × 24 in[2] |
| Weight | About 100 lb, of which the power supply is about 45 lb[2] |
| OS / Firmware | — |
| Predecessor | PDP-8/I, PDP-8/L[1] |
| Successor | PDP-8/A[1] |
The PDP-8/E is a 12-bit minicomputer introduced by Digital Equipment Corporation in 1970 at US$6,500.[1][2] It replaced the wire-wrapped backplanes of the earlier PDP-8 models with the OMNIBUS, a backplane in which every slot is wired identically, and put the whole processor on three large "quad" modules of TTL logic.[1] Options plug into the same bus as single cards. DEC built the cheaper PDP-8/F and the OEM PDP-8/m around the same processor from 1972, and withdrew all three in 1978 as the PDP-8/A took over.[1][6] Wikipedia calls the PDP-8/E common and well regarded, because so many I/O devices were made for it.[7]
The 8/E, 8/F and 8/M share their processor, memory and options, and DEC's maintenance manual covers all three; they differ in box, front panel and power supply.[4][5] See PDP-8/e Power Supply Guide, PDP-8/e General Maintenance and PDP-8/e Troubleshooting.
| Item | Specification |
| Memory cycle | Fast 1.2 µs (fetch, internal IOT, non-autoindex defer); slow 1.4 µs (execute, autoindex defer) |
| Memory reference instruction | 2.6 µs (one fast and one slow cycle) |
| Word length | 12 bits |
| Memory | 4,096 words, up to 32K optional |
| Mains (processor) | 95–130 V, 47–63 Hz, about 6 A; or 185–250 V, 47–63 Hz, about 3 A; 450 W |
| Operating environment | 0 to 55 °C, 10 to 95 % relative humidity, non-condensing |
Processor and OMNIBUS
The basic PDP-8/E has eight functional parts: the M8330 timing generator, M8310 register control, M8300 major registers, MM8-E core memory, H724 power supply, M8320 bus loads, M8650 Teletype control and KC8-EA programmer's console, with an M849 RFI shield between memory and the other options.[8] The OMNIBUS has 20 slots, ten of them needed by the basic computer; an OMNIBUS expander adds 20 more inside the box, and an expander box brings the total to 60.[4] Boards that work as a set (the CPU, the EAE, the memory) are joined across their tops by H851 edge connectors.[2] DEC's recommended order puts the console first, the M8330 next to it, and the M8320 bus loads always in the last slot.[9]
Memory
The MM8-E 4K core memory is three boards: G104 sense/inhibit, H220 stack and G227 X/Y drivers. Each further 4K field is another triplet, which needs the M837 (KM8-E) memory extension control.[9][1] The slice level and X/Y current are set at the factory with jumpers, the field number with three jumpers on the G104, and the sense strobe with a six-position switch.[10]
The H724 (H724A for 230 V) provides +5 V at 20 A for the logic, −15 V at 8 A and +15 V at 1 A for the memory and bus loads, unregulated +8 V at 2 A for the console lamps, and a 28 V AC centre-tapped winding, brought out as 14 V AC for options.[11][12] It is a linear supply weighing about 45 lb.[2] The KC8-EA programmer's console has incandescent lamps fed from the unregulated +8 V, which is why it cannot be fitted to an 8/F, whose supply has no +8 V output.[11][6] David Gesswein notes that the H724 does not provide enough +5 V for a box full of M-series cards, because DEC assumed most slots would hold memory.[13]
Known problems
- Electrolytic capacitors in the H724: DEC's own preventive maintenance asks for the supply to be inspected for leaky capacitors and overheated resistors every three months.[14] See PDP-8/e Power Supply Guide.
- Mismatched boards: early modules with three-digit numbers (M833, M865) were defective in various ways and were replaced by the M8330 and M8650.[1]
- PDP-8/E, PDP-8/F, PDP-8/M Maintenance Manual, Volume 1, DEC-8E-HMM1A-D-D, 1973: File:PDP-8E Maintenance Manual Volume 1 (DEC-8E-HMM1A-D-D).pdf
- Illustrated Parts Breakdown, PDP8E, DEC-PDP8E-IPB-1: File:PDP-8E Illustrated Parts Breakdown (DEC-PDP8E-IPB-1).pdf
See PDP-8/e Documentation for these and the PDP-8/M and H740 drawing sets.
Gallery
PDP-8/E with its cover off, VCF Berlin 2014 (Morn, CC BY-SA 3.0)
PDP-8/E power supply during restoration (Tony Duell, CC BY 2.0)
DEC's component location drawing of the H724
- PDP-8/e General Maintenance
- PDP-8/e Troubleshooting
- PDP-8/e Power Supply Guide
- PDP-8/e Documentation
- PDP-8/m
- PDP-8
- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 Douglas W. Jones, "What is a PDP-8/E?", PDP-8 Summary of Models and Options (comp.sys.dec FAQ), faqs.org. Introduction 1970, withdrawal 1978, US$6,500, three-board CPU on the OMNIBUS, MM8-E triplets, early defective modules, replacement by the PDP-8/A.
- ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 David Gesswein, "PDP-8/E and PDP-8/M Computer Information", pdp8online.com. Introduction 1970 at US$6,500, H851 connectors, size and weight, power supply weight.
- ↑ 3.0 3.1 3.2 3.3 Digital Equipment Corporation, PDP-8/E, PDP-8/F, PDP-8/M Maintenance Manual, Volume 1: Processor, DEC-8E-HMM1A-D-D, September 1973, pp. 1-7 to 1-8, Table 1-1 (File:PDP-8E Maintenance Manual Volume 1 (DEC-8E-HMM1A-D-D).pdf).
- ↑ 4.0 4.1 4.2 DEC, DEC-8E-HMM1A-D-D, p. 1-2, "Description".
- ↑ 5.0 5.1 DEC, DEC-8E-HMM1A-D-D, p. 3-172, section 8, power supplies (H724 or H724A for 230 V).
- ↑ 6.0 6.1 Douglas W. Jones, "What is a PDP-8/F?", faqs.org. PDP-8/F and 8/M introduced 1972, withdrawn 1978; the 8/E front panel needs the +8 V lamp supply.
- ↑ "PDP-8", Wikipedia, en.wikipedia.org/wiki/PDP-8.
- ↑ DEC, DEC-8E-HMM1A-D-D, pp. 3-2 to 3-4, "PDP-8/E Basic System".
- ↑ 9.0 9.1 DEC, DEC-8E-HMM1A-D-D, pp. 2-6 to 2-7, Tables 2-2 and 2-3, jumpers and recommended module order.
- ↑ DEC, DEC-8E-HMM1A-D-D, pp. 4-20 to 4-22, Table 4-6 and sections 4.7.3 to 4.7.9, memory circuit variables.
- ↑ 11.0 11.1 DEC, DEC-8E-HMM1A-D-D, pp. 3-172 to 3-176, section 3.47, PDP-8/E power supply.
- ↑ DEC, DEC-8E-HMM1A-D-D, p. 4-23, Table 4-7, H724 power supply parameters.
- ↑ David Gesswein, "PDP-8 h724 Power Supply Information", pdp8online.com.
- ↑ DEC, DEC-8E-HMM1A-D-D, pp. 4-5 to 4-6, Table 4-2, processor preventive maintenance schedule.
Cite error: <ref> tag with name "ipb" defined in <references> is not used in prior text.
