Macintosh SE/30 Reloaded Logic Board
Revision as of 08:34, 30 March 2025 by Josh (talk | contribs)
== Macintosh SE/30 Reloaded Logic Board ==
Type Logic Board
Designer Community-designed (Based on original Apple design)
First released 2023
Latest revision N/A
Operating voltage —
Layers / PCB 4-layer PCB
Compatibility Macintosh SE/30
Features * Modern design
  • SMD components
  • Apple ASICs
  • GAL-based PAL replacements
  • 32-bit clean ROM support
Model No. SE30RL
Overview
The Macintosh SE/30 Reloaded Logic Board is a modern open-hardware recreation of Apple’s original SE/30 logic board. Developed by the vintage computing community, it combines compatibility with the original Macintosh SE/30 and modern PCB fabrication, improving reliability and usability.
File:PCB Inspection.jpg
Careful pre-inspection helps avoid soldering issues.
Quick Specs
Quick Specs
  • PCB Type: 4-layer with internal power/ground planes
  • CPU: Motorola 68030 @ 16MHz (PLCC)
  • FPU: Motorola 68882 (optional)
  • RAM: Four 30-pin SIMM slots (up to 128MB with clean ROM)
  • ROM: Supports original ICs or programmable ROM SIMM
  • I/O: Internal/External SCSI, Serial, ADB, Audio, Floppy
Preparation and Inspection
Step Description
Cleaning Use >90% isopropyl alcohol on both PCB sides.
Visual Inspection Under magnification, check for shorts, broken pads, poor vias.
Dry Fit Components Test-fit sockets, connectors, and SIMMs.
ESD Safety Always wear a grounded wrist strap and use an anti-static mat.
Required Components and Tools
Components Tools
  • Apple ASICs: GLU, ASC, RTC, SWIM
  • Programmed GAL16V8 (x6), 27C64 Video ROM
  • 30-pin SIMM sockets, PDS slot, headers
  • DB-19/25 connectors, mini-DIN ports, audio jack
  • Fine-tip temperature-controlled soldering iron
  • Hot air rework station
  • No-clean flux pen + gel
  • Leaded solder (0.5mm preferred)
  • Stereo microscope or magnifier lamp
  • Multimeter, oscilloscope
  • GAL and EPROM programmers
Assembly Techniques
Surface-Mount Soldering
Flux and steady hands are key!
Component Technique
0402/0603 Passives Tin one pad, place part, solder second pad, reflow first.
SOIC/QFP Pin-by-pin or drag solder with flux.
PLCC Tack corners, flow solder under leads, inspect with magnification.
Through-Hole Soldering
Through-hole connectors properly aligned.
  • Tack two corner pins, verify alignment, solder all pins.
  • Trim excess leads with flush cutters.
  1. Power filtering, fuses, and clock oscillator
  2. SMD passives (resistors, capacitors)
  3. SMD logic, GALs, and custom ICs
  4. Through-hole sockets, SIMM slots, headers
  5. External connectors, switches, audio jack
Initial Testing
File:Bench Test Setup.jpg
Current-limited bench power test
  • Supply +5V and +12V using a current-limited bench PSU
  • Test voltage rails and look for excessive draw
  • Logic probe for clock and reset activity
  • Test without CPU/FPU for safety
Subsystem Test Checklist
Subsystem Checks
CPU/ROM Chime sound, address line activity
RAM Detects correct amount, boots OS
Video Raster visible, no vertical stripes (Simasimac)
ADB Mouse/keyboard respond, LED toggles
Sound Clear startup chime and test tones
SCSI Boots from BlueSCSI or HDD
Floppy Spindle motion, reads boot disks
Troubleshooting Guide
File:Diagnostic Screen.jpg
Simasimac: common sign of ROM/GLU issues
Symptom Causes
No boot or chime No clock/reset, shorted power rail, missing GALs
Simasimac ROM not detected, GLU issues, bad sockets
Death chimes RAM failure, bad VIA, bad address decoding
ADB non-functional Fuse F1 blown, missing RTC/PRAM battery
No floppy/SCSI Bad SWIM, missing termination, F3 blown
Unique Features
  • Modern 4-layer PCB design
  • Improved component layout and silkscreen
  • External 3.5mm audio jack
  • ROM SIMM support for custom ROMs (e.g. 32-bit clean)
  • Durable modern connectors
Community & Resources
Conclusion
Building the Macintosh SE/30 Reloaded Logic Board is a rewarding challenge for vintage computing enthusiasts. It offers the joy of hands-on assembly combined with the satisfaction of breathing new life into a timeless Mac.
