Macintosh SE/30 Reloaded Logic Board
Overview
Preparation and Inspection
| Step | Description |
| Cleaning | Use >90% isopropyl alcohol and a lint-free wipe to clean both sides of the board. |
| Inspection | Under magnification, inspect the PCB for any shorts, broken pads, or fabrication issues. |
| Dry Fit Checks | Fit sockets and large connectors to verify alignment. |
| ESD Precautions | Always wear a grounded wrist strap and work in an ESD-safe area. |
Required Components and Tools
| Components | Tools |
Assembly Techniques
Surface-Mount Soldering
| Component | Technique |
| 0402/0603 passives | Pre-tin one pad, place the component, solder the second pad. |
| SOIC, QFP ICs | Use drag soldering or pin-by-pin with ample flux. |
| PLCC ICs | Align carefully; tack corners; drag or point solder the leads. |
Through-Hole Soldering
- Use sockets for CPU, FPU, ROM unless soldering directly.
- Align and tack first, then solder each pin.
- Use flush cutters to trim excess leads.
- Confirm each pin has solid contact and solder fill.
Recommended Assembly Sequence
- Power-related components (fuses, oscillator)
- All SMD passives
- SMD ICs and transistors
- PLCC/DIP sockets and SIMM connectors
- External ports, headers, switches, and jacks
Power Check
- Use a bench power supply with current limiting.
- Check resistance between +5V and GND before powering.
- After applying power: verify +5V, +12V, and -12V rails.
- Feel for overheating components.
Subsystem Tests
Subsystem Verification
| Subsystem | Test |
| ROM/CPU | Boot chime, screen output |
| RAM | System boots, memory reported in OS |
| Video | CRT displays proper raster and icons |
| Sound | Audible startup chime and software playback |
| ADB | Mouse and keyboard functionality |
| SCSI/Floppy | Boot from known-good media, verify termination and data lines |
| Symptom | Potential Cause |
| No boot, black screen | Check clock oscillator, reset pin, CPU alignment |
| Simasimac | ROM access failure, bad socket, missing GALs |
| Death chimes | RAM error, GAL timing, bad addressing |
| Blank video | Video ROM missing, UE8 or PAL issue |
| No ADB | Fuse F1, ADB chip (UL11), PRAM battery |
| No floppy | Check SWIM chip, F3 fuse, D3 diode |
| No SCSI | Termination issue, 53C80 controller |
- 4-layer PCB reduces noise and improves signal reliability.
- No electrolytic capacitors – replaced with SMD ceramics/tantalum.
- Standardized SIMM and ROM socket layout.
- Optional 32-bit clean ROM SIMM support (no need for MODE32).
- Modern Molex-style power connector instead of card-edge.
Community Resources
Gallery
PCB inspection (placeholder)
SMD soldering (placeholder)
Socket alignment (placeholder)
Bench setup (placeholder)
Simasimac screen (placeholder)
Conclusion
The Macintosh SE/30 Reloaded Logic Board project brings new life to vintage hardware. Designed by the community, it offers a reliable, clean, and modern way to revive a classic machine—with the flexibility to tinker, experiment, and extend.
This page is based on extensive community documentation, builder experiences, and verified design files. Please consult the official GitHub repository and forums for the most current support and development updates.
