Template:Infobox computer hardware
Revision as of 17:00, 23 May 2026 by Josh (talk | contribs) (Collapse all blank lines inside <includeonly> โ€” they were generating empty paragraphs that pushed content down on transcluding pages)
Usage
Infobox template for hardware components (microprocessors, chipsets, controllers, expansion cards). Place the infobox as the very first line of the article with no blank lines above it; otherwise MediaWiki will create an empty paragraph that pushes content down.
Example skeleton โ€” supply only the fields you need (blank ones are hidden automatically):
{{Infobox computer hardware
| name             = Intel 8086
| logo             = [[File:Intel logo.svg|90px]]
| image            = [[File:Intel 8086.jpg|260px|frameless]]
| caption          = Intel 8086 in DIP-40 package
| developer        = Intel Corporation
| manufacturer     = Intel
| type             = 16-bit microprocessor
| introduced       = June 8, 1978
| discontinued     = September 1998
| arch             = x86
| data_width       = 16 bits
| address_width    = 20 bits (1 MB)
| clock            = 5โ€“10 MHz
| process          = 3 ยตm HMOS
| transistors      = 29,000
| package          = DIP-40, PLCC-44, CLCC-44
| voltage          = +5 V
| instruction_set  = x86 (8086 ISA)
| used_in          = [[IBM PC (5150)]], NEC PC-9801, Olivetti M24
| successor        = [[Intel 80186|80186]], [[Intel 80286|80286]]
| model            = 8086
Field reference
Field Description
name Component name shown as the infobox title
logo Optional logo image
image Main image of the component
caption Caption shown below the main image
developer Who designed the part
manufacturer Who manufactures the part
type Microprocessor, chipset, controller, etc.
introduced (or release_date) Initial release date
discontinued Discontinuation date
arch (or architecture) Architecture family
data_width Data path bit width
address_width Address bus bit width
clock (or frequency) Clock frequency
cache L1/L2/L3 cache sizes
process Semiconductor process node
transistors Transistor count or gate count
package IC package type
socket CPU socket type
voltage (or vcc) Operating voltage
power Power consumption
instruction_set (or isa) Instruction set architecture
used_in (or application) Systems where this part is used
predecessor Previous-generation part
successor Next-generation part
codename Internal development codename
model (or part) Part number
