Power Macintosh 6500 Troubleshooting
Revision as of 13:10, 16 July 2026 by Josh (talk | contribs) (Add representative photo (Wikimedia Commons, attributed on file page))
Troubleshooting is essential for diagnosing and resolving issues with your Power Macintosh 6500. This guide covers common problems and their solutions.
Preliminary Checks
  • Power cable is securely connected
  • Monitor is connected and powered on
  • Keyboard and mouse are connected to ADB port
  • No disks are in the floppy or CD-ROM drives during startup
No Power
Power Macintosh 6500. Source: Wikimedia Commons.
Power Issues
No response when power button pressed Failed power supply Check power outlet; test with known-good cable; inspect PSU capacitors
Power light on but no startup Logic board failure Reseat RAM and PCI cards; check for capacitor leakage
Clicking or ticking sound Power supply fault Replace power supply
Powers on briefly then shuts off Short circuit or thermal protection Check for loose screws or debris; inspect for failed components
Startup Issues
Startup Problems
Chime but no video Video circuit failure or RAM issue Reseat RAM; test with different monitor; check VRAM
No chime, no video Dead logic board or RAM failure Remove all RAM and test; reset PRAM (Cmd+Opt+P+R)
Flashing question mark No bootable system found Check hard drive connections; boot from CD-ROM; reinstall system
Sad Mac icon Hardware failure Note error code; see Sad Mac Error Codes
Gray screen with no boot System software corruption Boot from CD; reinstall system software
Sad Mac Error Codes
The 6500 may display Sad Mac codes indicating hardware failures. See Sad Mac Error Codes for a complete reference.
Common codes:
  • 0000000F / 00000001: RAM failure (check/replace RAM)
  • 0000000F / 00000005: ROM checksum failure
  • 00000003 / 00000001: Bus error during boot
RAM Issues
Memory Problems
System reports less RAM than installed Bad DIMM or incorrect speed Verify 60 ns or faster DIMMs; test each DIMM individually
Random crashes or freezes Faulty RAM Run memory test software; try known-good RAM
Death chimes at startup RAM not recognized Reseat or replace RAM; clean DIMM contacts
Hard Drive Issues
Storage Problems
Drive not recognized Cable connection or drive failure Check IDE cable; verify jumper settings; test drive externally
Slow performance Failing drive or fragmentation Back up data immediately; consider replacement
Clicking sounds from drive Imminent drive failure Replace drive immediately; attempt data recovery
"This disk is unreadable" File system corruption Run Disk First Aid; reformat if necessary
CD-ROM and Zip Drive Issues
Optical and Removable Drive Problems
CD-ROM not reading discs Dirty lens or laser failure Clean lens; check for disc damage; replace drive
CD tray won't eject Belt slippage or mechanical failure Use paperclip emergency eject; replace belt
Zip "click of death" Drive head or media failure Replace Zip drive; do not use affected disks in other drives
Zip drive not recognized SCSI termination issue Check internal SCSI chain; reseat drive
Video and Display Issues
Display Problems
No video output Bad connection or video circuit failure Check monitor cable; test with different monitor
Distorted or wavy display Refresh rate mismatch or interference Adjust monitor settings; move away from interference sources
Wrong colors or color banding VRAM issue Zap PRAM; check video settings in Monitors control panel
Video works only at low resolution VRAM or video chip failure Video subsystem may need repair
Audio Issues
Sound Problems
No audio output Muted or disconnected speakers Check Sound control panel; verify speaker connections
Distorted audio Bad capacitors or speaker damage Recap if necessary; test with headphones
Crackling or popping Capacitor failure See Power Macintosh 6500 Capacitor Replacement Guide
PRAM and Settings Issues
If the system loses settings, displays wrong date/time, or has unusual startup behavior:
  • Reset PRAM: Hold Cmd+Option+P+R during startup until you hear a second chime
  • Replace PRAM Battery: The 4.5V alkaline battery may be depleted
⚠️ PRAM battery
The Power Macintosh 6500 uses a 3.6 V 1/2AA lithium PRAM battery that leaks and can burst, corroding the logic board. Remove it from any un-serviced unit and clean/repair any leakage before troubleshooting.[1]
⚠️ Recap (logic board and PSU)
The Power Macintosh 6500 uses aluminium electrolytic capacitors on both the logic board and the power supply, and they leak with age. Recap and clean both boards as a first step; the large 2200 uF PSU filter capacitors in particular are a known failure point, giving a dead machine, failure to power on, or instability.[2]
  1. 68kMLA — Exploding Maxell PRAM Batteries. Source for the leaking/exploding 3.6 V lithium PRAM battery.
  2. Recap-a-Mac — Power Macintosh 6100; Badcaps "Macintosh 6100 power supply"; and the Apple Performa/Power Macintosh 6400/6500 Service Source. Source for the logic-board and power-supply electrolytic failures (including the 2200 uF PSU capacitors) and the recap.
