Osborne 1 Troubleshooting Guide
The Osborne 1 is a classic portable CP/M computer whose reliability depends on clean power, healthy RAM, and a working CRT subsystem. This guide details practical troubleshooting steps for common faults, diagnosis and repair.
Preliminary & Power-up Checks
Begin by verifying the Osborne 1’s power and basic startup sequence, as power supply and connector issues are the most frequent causes of “dead” systems.
- Unplug the unit and visually inspect for burnt, cracked, or leaking components, especially around the power input and CRT high-voltage area.
- Confirm the main fuse is intact.
- With a multimeter, check for:
- +5 V DC and +12 V DC at the motherboard test points or across large filter capacitors.
- AC voltage at the input side of the power supply.
- If voltages are absent or unstable:
- Inspect and reflow cold solder joints at the power connector and switch.
- Replace the fuse if blown; if it blows again, suspect a shorted rectifier or capacitor.
- Remove all expansion cards and disk drives, then attempt power-up to isolate faults.
| No lights, no CRT glow, no fan | Blown fuse, failed power supply, broken switch | Replace fuse; test/replace power supply; check switch continuity |
| CRT glow but no beeps, no drive activity | Logic board not powered, cable loose | Reseat motherboard power connector; check for +5 V at main ICs |
| Intermittent power loss | Cracked solder, loose connector | Reflow joints; clean and reseat connectors |
Display & Chime Diagnostics
The Osborne 1’s 5" CRT should display a raster and beep at startup. Display issues are often due to power, logic, or CRT subsystem faults.
No Video, No Raster
- Confirm CRT filament glows faintly (view in a dark room).
- Check for high voltage “static” on the CRT face.
- Inspect CRT board for burnt resistors, failed flyback transformer, or broken neck board.
Raster but No Text
- Indicates video section is working, but logic board is not sending video data.
- Reseat all socketed ICs, especially video RAM and character ROM.
- Check ribbon cable from logic board to CRT board for continuity.
Garbled or Rolling Display
- Suspect failed video RAM, character ROM, or timing logic (e.g. 74LS chips).
- Adjust vertical/horizontal hold pots if rolling; if ineffective, check timing ICs.
| No raster, no CRT glow | CRT filament supply failure, flyback dead | Check/replace flyback; test filament voltage |
| Raster present, no text | Logic board not running, video cable loose | Reseat logic board, check video cable |
| Garbled/rolling text | Video RAM/ROM or timing logic faulty | Swap video RAM/ROM; check 74LS chips |
Floppy Drive & Storage Subsystem
Osborne 1 boot relies on both floppy drives and their controller logic.
- Listen for drive spin-up and head movement at power-on.
- If drives are silent or not recognised:
- Check drive power and data cables.
- Swap drive select jumpers if misconfigured.
- Inspect and clean drive heads and rails.
- If “BOOT ERROR” or no access:
- Reseat the FDC (Floppy Disk Controller, usually a WD1791 or similar).
- Replace suspect FDC or buffer ICs (74LS245, 74LS373).
- Try a known-good boot disk.
| No drive activity | No power, bad cable, failed FDC | Check cables, swap FDC, test drive with external PSU |
| “BOOT ERROR” | Bad disk, FDC, or buffer logic | Try different disk; swap FDC/buffers |
| Drive spins but never loads | Mis-set jumpers, dirty heads | Set jumpers, clean heads |
Memory & ROM Faults
RAM and ROM failures are a primary cause of boot and display anomalies.
RAM Faults
- Osborne 1 typically uses 4116 or 4164 DRAMs (check board revision).
- Faulty RAM causes:
- Random characters, system freeze, or continuous beeping.
- No boot, blank or garbled screen.
- Use a logic probe or oscilloscope to check for activity on address/data lines.
- Piggy-back a known-good DRAM on top of each suspect chip to isolate faults.
- Replace failed RAM; always use anti-static precautions.
ROM Faults
- Corrupt ROM (Monitor or BIOS) results in no boot or random characters.
- Reseat ROM chips; clean pins.
- Replace with known-good ROM or compatible EPROM if available.
| Random beeping, freeze | Bad DRAM | Piggy-back/test/replace DRAM |
| Garbled characters | Bad video RAM or character ROM | Swap video RAM/ROM |
| No boot, no sign of life | Dead ROM or CPU | Reseat/replace ROM, test CPU |
Connector & Socket Issues
The Osborne 1 uses many socketed ICs and ribbon cables, which are prone to corrosion and poor contact.
- Power off and carefully remove each socketed IC; clean pins with isopropyl alcohol.
- Inspect for bent, broken, or corroded pins.
- Reseat all ribbon cables, especially between logic and CRT boards.
- If repeated faults occur, replace suspect sockets with high-quality machine-pin types.
Component-level Tests & Voltage Table
Regular component-level checks can prevent misdiagnosis and further damage.
Voltage Test Points
| Test Point | Expected Voltage | Notes |
| Mainboard +5 V rail | +5.0 V DC (±5%) | Logic supply; check at DRAM/CPU Vcc |
| Mainboard +12 V rail | +12 V DC (±10%) | Drives, CRT, some logic |
| CRT filament | 6.3 V AC | Should glow faintly |
| FDC supply | +5 V, +12 V DC | Required for drive operation |
Clock & Reset
- 4 MHz clock crystal (or as marked) should show stable oscillation at CPU.
- RESET line should pulse low on power-up, then go high.
- If stuck low, check reset circuitry (capacitor, resistor, 555/logic IC).
Audio & I/O Failures
Osborne 1 has a simple piezo beeper for audio.
- No beep at power-on:
- Check beeper with continuity tester.
- Trace beeper circuit back to logic board; check for broken traces or failed driver transistor.
- Keyboard not working:
- Reseat keyboard connector.
- Test for continuity in ribbon cable.
- Suspect PIA (Peripheral Interface Adapter, e.g. 6821) if keyboard matrix fails.
⚠️ Power supply
Recap the Osborne 1 supply before relying on it. The mains-side RIFA-type suppression capacitors crack and fail with smoke and loud bangs shortly after power-on, and the large filter electrolytics dry out after 40+ years — prioritise the 4700 uF, 2200 uF and 1000 uF filter capacitors. A faulty disk drive can also overload the +12 V rail and cause crashes, so check the drives if the supply sags under load.[1]
No video / CRT
The Osborne 1 has a small built-in CRT. For a dark screen: confirm the CRT filament glows faintly (in a dark room), check for EHT (high voltage) at the tube, and inspect the CRT/neck board for burnt resistors, a failed flyback transformer or a cracked neck board. A rolling display is set with the vertical/horizontal hold potentiometers; if adjusting them does nothing, suspect the timing ICs.[1]
Garbage screen / no boot
A non-boot with garbage characters is commonly a dynamic RAM (DRAM) failure. Piggy-back a known-good DRAM on each suspect chip to isolate the bad one, and replace it with anti-static precautions. Because the Osborne uses many socketed ICs and board-to-board ribbon cables that corrode, first reseat every socketed IC and every ribbon (especially the logic-to-CRT-board ribbon) and clean the pins with isopropyl alcohol.[1]
Disk drives
Both floppy drives and their controller take part in booting. At power-on, listen for drive spin-up and head movement, and check the drive power and data cables. A drive that is mechanically stuck or electrically shorted loads down the +12 V rail and takes the whole machine down with it.[1]
- ↑ 1.0 1.1 1.2 1.3 Repairs to an old Osborne 1, Tezza's Classic Computers; Osborne Restoration: PSU and disk drives, Richard Loxley; and the EEVblog Osborne 1 repair thread. Source for the PSU capacitor failures (RIFA smoke/bangs and the 4700/2200/1000 uF filter caps), the CRT/no-video checks, the disk-drive 12 V overload, the DRAM garbage-screen piggy-back test, and the socket/ribbon reseating.
