Macintosh Quadra 700 Troubleshooting
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh Quadra 700'\\. This guide covers the most common problems and their solutions.
Preliminary Checks
- Verify power outlet is working with another device
- Check that the power cable is fully seated
- Ensure the voltage selector (if present) matches your local voltage
- Disconnect all external peripherals except keyboard and mouse
- Remove any NuBus or PDS cards temporarily
Power Supply Specifications
| Parameter | Specification |
| Input Voltage | 100V โ 240V AC |
| Frequency | 50 โ 60 Hz |
| Maximum Power | 50W |
| +5V Rail | 4.85V โ 5.15V |
| +12V Rail | 11.9V โ 12.7V |
No Power (Unit Dead)
| No response when power key pressed | Dead PRAM battery | Replace 3.6V lithium battery |
| No response when power key pressed | Failed power supply | Test PSU output voltages; replace if out of spec |
| No response when power key pressed | Bad power cable | Test with known-good cable |
| Power light on, no startup | Failed soft power circuit | Check keyboard power key circuit on logic board |
| Intermittent power | Loose power connector | Reseat power supply connector; check solder joints |
| Clicking/ticking sound | Power supply overload or short | Disconnect drives; test with minimal configuration |
Power-On Circuit
The Quadra 700 uses soft power, controlled by the power key on the ADB keyboard. If the keyboard power key does not work:
- Test with a different ADB keyboard
- Check the ADB port and cable
- The programmer's switch on the side can force power-on (interrupt button held during plug-in)
Startup Chime but No Video
| Chime, no video on internal | VRAM failure | Reseat VRAM SIMMs; test with 512 KB onboard only |
| Chime, no video on internal | Video circuit failure | Test with NuBus video card |
| Chime, no video on internal | Monitor or cable issue | Test monitor with another source |
| Garbled or distorted video | Bad VRAM SIMM | Remove expansion VRAMs; test individually |
| Incorrect colors | VRAM configuration issue | Verify all 6 VRAM slots populated identically |
Video Output Configuration
The Quadra 700 outputs video through a DB-15 connector. Ensure you are using the correct adapter for your monitor type. The system can detect monitor type through sense pins in the connector.
| Random freezes | Bad RAM | Test RAM modules individually; replace faulty SIMMs |
| Freezes during disk access | SCSI termination issue | Verify proper termination at end of SCSI chain |
| Freezes during disk access | Failing hard drive | Run disk diagnostics; backup and replace drive |
| Freeze after warmup | Thermal issue | Check fan operation; clean dust from heatsink |
| Intermittent startup | Dirty contacts | Clean SIMM and expansion card contacts with DeoxIT |
Sad Mac Error Codes
See the Sad Mac Error Codes page for a full list. Common codes for the Quadra 700:
| Error Code | Meaning |
| 0000000F 00000001 | ROM test failed |
| 0000000F 00000002 | Memory (RAM) test failed |
| 0000000F 00000003 | Memory addressing test failed |
| 0000000F 00000004 | Memory cell test failed |
| 0000000F 00000005 | Memory odd/even logic test failed |
| 0000000E xxxxxxxx | SCSI chip failure or conflict |
For RAM-related Sad Mac errors, try:
- Removing expansion SIMMs and testing with onboard RAM only
- Reseating SIMM modules
- Testing each SIMM bank individually
- Cleaning SIMM contacts
Floppy Drive Issues
| Disk not ejecting | Failed eject motor | Replace eject motor or entire drive |
| Disk not ejecting | Mechanical obstruction | Check for debris; clean mechanism |
| Read/write errors | Dirty heads | Clean heads with isopropyl alcohol |
| Drive not recognized | Cable issue | Reseat or replace internal ribbon cable |
| Constant disk grinding | Drive failure | Replace SuperDrive mechanism |
SCSI Issues
The Quadra 700 uses the NCR 53C96 SCSI controller.
| External drives not seen | Improper termination | Terminate last device in chain only |
| SCSI ID conflicts | Duplicate IDs | Ensure each device has unique ID (0-6) |
| Slow performance | Poor cable quality | Use quality shielded SCSI cables |
| Intermittent access | Loose connections | Check all SCSI connectors |
The internal hard drive should be set to SCSI ID 0. External devices should use IDs 1-6 (ID 7 is reserved for the host).
Networking Issues
| No Ethernet connectivity | Missing transceiver | AAUI port requires external transceiver |
| Intermittent connection | Bad transceiver | Test with known-good AAUI transceiver |
| No LocalTalk | Cable/termination issue | Check LocalTalk connectors and termination |
NuBus/PDS Card Issues
| Card not recognized | Poor contact | Reseat card firmly; clean edge connector |
| System crash with card | Card conflict | Test card alone; check for resource conflicts |
| PDS card blocks NuBus | Physical interference | PDS slot blocks one NuBus slot by design |
โ ๏ธ PRAM battery โ remove it now
The Quadra 700 carries a 3.6 V 1/2AA lithium PRAM battery. These leak and can burst, spraying corrosive electrolyte across the logic board and destroying nearby components — often while the machine simply sits in storage. Remove the PRAM battery from any un-serviced unit. If one has leaked, neutralise and clean the residue and repair corroded traces and vias before troubleshooting.[1]
Unlike the LC and Mac II surface-mount-electrolytic boards, the 68040-family Quadra 700 logic board uses tantalum capacitors, which do not leak with age — the logic board does not normally need recapping. If the board misbehaves, look to leaked-PRAM-battery corrosion, socket/connector contacts and the power supply rather than to board capacitors.[2]
- โ "Warning! Exploding Maxell PRAM Batteries", 68kMLA; and MacDat — Macintosh II family. Source for the leaking/exploding lithium PRAM battery that destroys nearby components.
- โ "Apple Macintosh Quadra 650", Retro Viator; and the Apple Macintosh Quadra/Centris 650 Service Source. Source for the 68040-family logic boards using tantalum capacitors (no logic-board recap needed) while the power supply uses electrolytics that do need replacing.
- โ "Compact/Desktop Power Supply Capacitor Lists (by make and model)", 68kMLA; and "Capacitor Replacement in a Vintage Power Supply", Big Mess o' Wires. Source for the shared desktop PSU form factor (IIci/IIcx/IIvi/IIvx/Performa 600/Quadra 650/Quadra 700), the electrolytic failure symptoms and the PSU capacitor lists.
Surface-mount capacitor leakage
The Macintosh Quadra 700 logic board uses surface-mount electrolytic capacitors whose electrolyte turns corrosive with age and creeps across the board, eating through traces, pads and IC pins. Typical signatures are a machine that will not chime, chimes but shows no video, plays distorted or missing audio, or shows a garbled or checkerboard screen. Wash the affected area and replace every electrolytic with a tantalum or polymer part, then repair any lifted traces. Apple fitted tantalum capacitors on the Macintosh Quadra 700 logic board, so board-level leakage is unusual on this model, but the electrolytic supply still needs it. The switch-mode power supply (ASTEC or TDK on the LC-family machines) holds its own electrolytics and fails the same way, so recap it alongside the board.[1]
PRAM battery
The Macintosh Quadra 700 backs up its clock and Parameter RAM from a 3.6 V ½AA lithium cell. These cells — red Maxell parts especially — leak or burst and corrode the board, so remove an aged one on sight. A flat cell can also stop a soft-power machine booting or disturb the video; left plugged in, trickle power preserves the settings, but a machine switched off at the wall with a dead cell loses them. Clean the area and fit a fresh 3.6 V cell.[2]
Boot chime and Sad Mac
Related Pages
- Macintosh Quadra 700 General Maintenance
- Macintosh Quadra 700 Capacitor Replacement Guide
- Sad Mac Error Codes
- โ Mac84, Macintosh LC series power-supply recapping guide; the MacCaps capacitor reference; and iFixit. Source for surface-mount electrolytic leakage eating traces, pads and pins, the ASTEC/TDK LC power-supply cap failures, and Apple's use of tantalum (non-leaking) capacitors on the Quadra 700/900 logic boards.
- โ Warning! Exploding Maxell PRAM batteries, 68kMLA; and Mac Battery Leaks, MacDat. Source for the 3.6 V ½AA lithium PRAM cell, the Maxell leak/explosion board damage, and soft- versus hard-power PRAM retention.
