Power Macintosh 6100 Troubleshooting
Revision as of 13:21, 16 July 2026 by Josh (talk | contribs) (Deep dive: SMD cap leakage signatures, PRAM battery, analog/sound specifics, chime/Sad Mac; cited)
Troubleshooting is essential for diagnosing and resolving issues with your Power Macintosh 6100. This guide covers common problems and their solutions.
Preliminary Checks
  • Power cable is securely connected
  • Monitor is connected to DB-15 port and powered on
  • Keyboard and mouse are connected to ADB port
  • No disks are in the floppy or CD-ROM drives during startup
  • SCSI chain is properly terminated (if external devices connected)
No Power
Power Macintosh 6100. Source: Wikimedia Commons.
Power Issues
No response when power button pressed Failed power supply Check power outlet; test with known-good cable; inspect PSU capacitors
Power light on but no startup Logic board failure Reseat RAM; check for capacitor leakage; reset CUDA
System powers off unexpectedly Overheating or PSU failure Clean dust from vents; check fan operation; inspect capacitors
Startup Issues
Startup Problems
Chime but no video Video circuit failure or RAM issue Reseat RAM; test with different monitor; check video port
No chime, no video Dead logic board or RAM failure Remove all RAM and test; reset PRAM (Cmd+Opt+P+R)
Flashing question mark No bootable system found Check SCSI drive connections; verify SCSI termination; boot from CD
Sad Mac icon Hardware failure Note error code; see Sad Mac Error Codes
Death chimes RAM or ROM failure Reseat or replace RAM; test each SIMM pair individually
Sad Mac Error Codes
The 6100 may display Sad Mac codes indicating hardware failures. See Sad Mac Error Codes for a complete reference.
Common codes:
  • 0000000F / 00000001: RAM failure
  • 0000000F / 00000005: ROM checksum failure
  • 00000003 / xxxxxxxx: Bus error
RAM Issues
Memory Problems
System reports less RAM than installed Bad SIMM or mismatched pair SIMMs must be in matched pairs; test each pair
Random crashes or freezes Faulty RAM Run memory test software; try known-good SIMMs
Death chimes at startup RAM not recognized Reseat SIMMs; clean contacts; verify 80 ns or faster
SCSI Issues
SCSI Problems
Drive not recognized Termination or ID conflict Verify SCSI termination at end of chain; check unique SCSI IDs
Slow performance Cable or termination issues Use quality SCSI cables; proper termination
Clicking sounds from drive Imminent drive failure Back up data immediately; replace drive
External devices not seen Termination or power issue Only terminate at end of chain; verify external device power
SCSI Termination
  • Internal drive should NOT be terminated (the logic board provides termination)
  • The last device in any external chain MUST be terminated
  • SCSI IDs must be unique (0-6, with 7 reserved for the Mac)
  • Internal hard drive typically uses ID 0
Video and Display Issues
Display Problems
No video output Bad connection or video circuit failure Check monitor cable; test with different monitor
Distorted display Refresh rate mismatch Adjust monitor settings; use correct adapter if needed
Limited resolution options No dedicated VRAM Integrated video limited to 640 KB; add NuBus video card for better resolution
Audio Issues
Sound Problems
No audio output Muted or wrong output selected Check Sound control panel; verify speaker connections
Distorted audio Bad capacitors Recap if necessary; test with headphones
No startup chime Logic board or speaker issue Check internal speaker connection; may indicate deeper problem
PRAM and Settings Issues
If the system loses settings, displays wrong date/time, or has unusual startup behavior:
  • Reset PRAM: Hold Cmd+Option+P+R during startup until you hear a second chime
  • Reset CUDA: Press the CUDA reset button on the logic board (small button near battery)
  • Replace PRAM Battery: The 3.6V lithium battery may be depleted
DOS Card Issues (PC Compatible Models)
DOS Card Problems
DOS card not recognized Card not seated properly Reseat the NuBus card
Windows won't start RAM or configuration issue Check DOS card RAM; verify DOS/Windows installation
No video in DOS mode Monitor adapter issue Use correct adapter; check PC Setup control panel
⚠️ PRAM battery
The Power Macintosh 6100 uses a 3.6 V 1/2AA lithium PRAM battery that leaks and can burst, corroding the logic board. Remove it from any un-serviced unit and clean/repair any leakage before troubleshooting.[1]
⚠️ Recap (logic board and PSU)
The Power Macintosh 6100 uses aluminium electrolytic capacitors on both the logic board and the power supply, and they leak with age. Recap and clean both boards as a first step; the large 2200 uF PSU filter capacitors in particular are a known failure point, giving a dead machine, failure to power on, or instability.[2]
  1. 68kMLA — Exploding Maxell PRAM Batteries. Source for the leaking/exploding 3.6 V lithium PRAM battery.
  2. Recap-a-Mac — Power Macintosh 6100; Badcaps "Macintosh 6100 power supply"; and the Apple Performa/Power Macintosh 6400/6500 Service Source. Source for the logic-board and power-supply electrolytic failures (including the 2200 uF PSU capacitors) and the recap.
Surface-mount capacitor leakage
The Power Macintosh 6100 logic board uses surface-mount electrolytic capacitors whose electrolyte turns corrosive with age and creeps across the board, eating through traces, pads and IC pins. Typical signatures are a machine that will not chime, chimes but shows no video, plays distorted or missing audio, or shows a garbled or checkerboard screen. Wash the affected area and replace every electrolytic with a tantalum or polymer part, then repair any lifted traces. The switch-mode power supply (ASTEC or TDK on the LC-family machines) holds its own electrolytics and fails the same way, so recap it alongside the board.[1]
PRAM battery
The Power Macintosh 6100 backs up its clock and Parameter RAM from a 3.6 V ½AA lithium cell. These cells — red Maxell parts especially — leak or burst and corrode the board, so remove an aged one on sight. A flat cell can also stop a soft-power machine booting or disturb the video; left plugged in, trickle power preserves the settings, but a machine switched off at the wall with a dead cell loses them. Clean the area and fit a fresh 3.6 V cell.[2]
Boot chime and Sad Mac
  1. Mac84, Macintosh LC series power-supply recapping guide; the MacCaps capacitor reference; and iFixit. Source for surface-mount electrolytic leakage eating traces, pads and pins, the ASTEC/TDK LC power-supply cap failures, and Apple's use of tantalum (non-leaking) capacitors on the Quadra 700/900 logic boards.
  2. Warning! Exploding Maxell PRAM batteries, 68kMLA; and Mac Battery Leaks, MacDat. Source for the 3.6 V ½AA lithium PRAM cell, the Maxell leak/explosion board damage, and soft- versus hard-power PRAM retention.
