Macintosh Classic / Classic II Troubleshooting
Revision as of 22:00, 7 April 2025 by Josh (talk | contribs)
This guide provides targeted diagnostic and repair instructions for the Macintosh Classic and Macintosh Classic II. Though similar externally, these machines differ significantly in their logic board designs and capabilities. Use this guide to diagnose power issues, video faults, audio failure, and storage problems specific to these compact Macs.
๐Ÿ”Œ Preliminary Checks and Power Delivery
Begin by confirming power output from the analog board. Use a multimeter to check voltage at the floppy or SCSI power connector:
  • +5V rail: Should measure between 4.90V and 5.10V
  • +12V rail: Should measure between 11.9V and 12.7V
If there are no signs of life (no fan, CRT glow, or chime), check the following:
Analog Board Components
  • Fuse (F1)
  • Rectifiers CR2 and CR3
  • Transistor Q2
  • Resistor R22
  • Startup circuit near the power input section
  • Analog board solder joints (especially around the flyback transformer)
Logic Board Checks
  • Inspect the logic board for capacitor leakage (both models use surface-mount electrolytics)
  • Remove and test the PRAM battery (3.6V lithium, often Tadiran)
  • Check for corrosion or broken traces caused by battery or capacitor leakage
๐Ÿ“บ Video Failures
No Video, But Startup Chime Present
This is often due to failure in the analog board or a disconnected CRT yoke. Check:
  • CRT glow โ€” verify filament voltage at CRT neck board
  • Brightness knob is not turned all the way down
  • Analog board flyback transformer (check for ticking or arcing)
  • Socketed video ICs on Classic II (e.g., UB10) โ€” clean and reseat
  • Reflow cracked solder joints around the yoke connector and flyback
Vertical or Horizontal Line Only
  • Horizontal line: Indicates vertical deflection failure. Common causes:
    • Bad TDA1170A vertical deflection IC
    • Cracked solder joints at P1 connector or vertical yoke coil
    • Bad C15 capacitor (electrolytic)
  • Vertical line: Indicates horizontal deflection failure. Check:
    • Q2 transistor
    • Horizontal output section of analog board
"Simasimac" โ€“ Horizontal Stripe Pattern
A screen filled with evenly spaced horizontal lines with no startup chime indicates:
  • Failed reset circuitry due to capacitor leakage
  • Broken traces near the VIA or reset line to the 68000 CPU
  • Dead or corroded PRAM battery causing boot hang
  • Damaged ROM chip or ROM socket (Classic II)
๐Ÿ’€ Chimes of Death & Sad Mac Codes
The "chimes of death" or Sad Mac icons indicate early system failure. Common causes:
RAM Errors
  • Classic: 1 MB onboard RAM (non-upgradable)
  • Classic II: 2 MB onboard + SIMM slot (expandable to 10 MB)
  • Dirty, corroded, or incompatible RAM SIMMs
  • Reflow or replace 74-series multiplexers near RAM
  • Use matched pairs of 30-pin SIMMs (Classic II)
ROM Issues
  • Reseat or clean ROM chips (socketed on Classic II)
  • Replace with known-good ROM from identical model
  • Corroded socket or damaged trace under ROM
See: Sad Mac Error Codes for full code listings.
๐Ÿ’พ Floppy and SCSI Drive Faults
Floppy Drive Not Reading or Ejecting Disks
  • Dirty or misaligned drive heads โ€” clean with isopropyl alcohol
  • Failed eject motor โ€” test with external 5V source
  • Worn or cracked eject gears (replace or 3D print replacements)
  • Bad SWIM IC (Sony controller chip)
See: Macintosh Floppy Drive Maintenance for step-by-step cleaning and alignment.
SCSI Drive Not Detected or Boot Hangs
  • Dead SCSI hard drive (stiction or failed logic board)
  • Failed termination resistors or SCSI bus shorts
  • Dirty or bent SCSI connector pins on logic board
  • ROM not recognizing attached SCSI device
Try booting from a known-good external SCSI hard drive or CD-ROM.
๐Ÿ”Š Audio and ADB Problems
No Sound from Speaker or Headphones
  • Audio amplifier failure on analog board
  • Dirty or broken headphone jack disconnect switch
  • Failed ASC (Apple Sound Chip) โ€” more common on Classic II
Test with headphones โ€” if sound is present, check speaker wiring or amp.
Keyboard or Mouse Not Working (ADB)
  • Blown fuse (F1) on logic board
  • Failed Egret or VIA chip (Classic II)
  • Corrosion around ADB jack or microcontroller
  • Use known-good ADB keyboard and mouse for testing
โฑ๏ธ Clock & Reset Circuit Failures
  • Random resets: Often due to power instability or failed capacitors near Egret (Classic II)
  • Date/time not saved: Dead PRAM battery
  • 32.768 kHz crystal failure will prevent RTC operation and cause boot hangs
Use an oscilloscope or frequency counter to check for crystal oscillation.
โšก Analog Board Instability
The analog board provides video, power, and audio, and is a common point of failure.
Common Faults
  • Failing capacitors leading to distorted video or unstable voltages
  • Clicking or pulsing: Failed CR2/CR3 diodes, Q2 transistor, or R22
  • No video or sound despite fan: Bad flyback transformer or failed analog board controller
๐Ÿ”Ž Advanced Diagnostic Tips
  • Always recap both the logic and analog boards before troubleshooting
  • Use a logic probe or oscilloscope to verify reset, clock, and video sync signals
  • If the screen shows garbage or freezes early in boot, check for shorted capacitors
  • Trace repair may be required for extensive battery leakage (especially under RAM and ROM sockets)
