Sega CD (Model 2)
The Sega CD Model 2, sold as the Sega CD II in North America and the Mega-CD 2 elsewhere, is Sega's second CD-ROM add-on for the Mega Drive and Genesis. It replaced the Model 1's motorised front-loading tray with a top-loading lid opened by hand, sits beside the console instead of under it, and was designed to cost less to make.[1] To software it is the same machine: the same 68000 sub CPU at 12.5 MHz, the same memory and the same boot ROM functions.[2]
| A Model 2 Sega CD (right) attached to a Model 2 Genesis | |
| Manufacturer | Sega Enterprises, Ltd. |
| Type | CD-ROM add-on for the Mega Drive / Genesis |
| Released | 23 April 1993 (Japan)[1] |
| Intro price | US$229 in North America, bundled with Sewer Shark[1] |
| CPU | 68000 at 12.5 MHz (sub CPU)[2] |
| Memory | 6 Mbit program, picture and sound RAM; 512 kbit PCM waveform RAM; 128 kbit CD-ROM cache; 64 kbit back-up RAM[2] |
| Storage | Top-loading CD drive, 12 cm and 8 cm discs, average access 1.5 s[2] |
| Display | None; video is produced by the console |
| Sound | 8-channel stereo PCM at up to 32 kHz; 16-bit D/A converter with 8× oversampling digital filter[2] |
| Power | External AC adaptor, 10 V DC 1.2 A; 18 W[2][3] |
| Dimensions | 396 × 220 × 84 mm[2] |
| OS / Firmware | 1 Mbit boot ROM: CD game BIOS, CD player software, CD+G[2] |
| Predecessor | Sega CD (Model 1) |
| Model no. | MK-4101 (USA), MK-4101-22 (Canada), MK-4180 and MK-4182 (Mega CD II)[3] |
History
Sega released the Mega-CD 2 in Japan on 23 April 1993. It reached North America several months later at US$229, bundled with Sewer Shark.[1] Sega's parts list gives four model numbers: MK-4101 for the USA, MK-4101-22 for Canada (packed with Sewer Shark), and MK-4180 and MK-4182 for other markets (MK-4180 packed with Road Avenger).[3]
From Sega's service manual.[2]
| Item | Sega CD II | Mega CD II |
| Power input (adaptor) | AC 120 V, 60 Hz | AC 230 or 240 V, 50 Hz |
| Power consumption | 18 W | |
| Operating environment | 0 to 40 °C, 10 to 80 % RH, no condensation | |
| CPU | 68000 at 12.5 MHz | |
| RAM | 6 Mbit program, picture and sound data; 512 kbit PCM waveform; 128 kbit CD-ROM data cache; 64 kbit back-up | |
| Boot ROM | 1 Mbit: CD game BIOS, CD player software, CD+G | |
| PCM | Stereo, 8 channels, sampling frequency up to 32 kHz | |
| D/A conversion | 16-bit, 8× internal oversampling digital filter; PCM and CD sound mixing | |
| Audio | 20 Hz to 20 kHz; S/N over 80 dB at 1 kHz (line out); dynamic range over 90 dB | |
| Back-up retention | About one month | |
| Discs | 12 cm and 8 cm | |
| Access time | Average 1.5 s | |
| Connections | Two RCA line-out jacks; stereo mixing jack; AC adaptor jack | |
Power
The unit runs from its own adaptor, rated 10 V DC 1.2 A: Sega parts 400-5100B and 400-5100B-01 for 120 V mains, 400-5122C for 230 V, and 400-5127A and 400-5128A for 240 V.[3] The DC input goes from jack CN301 through fuse F301 (Pico II, 2.5 A) to IC301, a µPC2405HF 5 V regulator.[4] Sega's servicing flow charts check for 9 V at pins 1, 12 and 13 of IC409, the AN8388 servo driver, and 5 V at pins 10 and 37 of IC403.[5]
Boards
Two different main boards were made. Sega's manuals describe one, the board Console5 calls the Funai board; the other, 171-6528C, Console5 calls the Sony board.[6][7]
| Board | Identification | CD section |
| "Funai" board, Sega 837-9615 (Sega CD II, USA) or 837-9616 (Mega CD II, multi); later 837-10210, -10211, -10213 and -10214[4][8] | Silkscreened BE2200G02 with a revision suffix (A02, B02, C02 or C22)[6] | IC401 CXD1167Q signal processor, IC402 CXA1081M RF amplifier, IC403 CXA1082BQ servo signal processor, IC404 µPD75006 mechanism controller, IC409 AN8388 servo driver[4] |
| "Sony" board, 171-6528C | Boot ROM MPR-15764-T at IC111[7] | IC401 CXD2500BQ, IC402 CXP5084; the drive's own PCB carries the servo[7] |
On the Funai board, units from serial number T30282001 have larger chip parts (2.0 × 1.25 mm instead of 1.6 × 0.8 mm), a changed board pattern, IC001 and IC002 renumbered IC951 and IC952, and no PCM board 837-9798 at IC110.[8] On earlier boards IC001 and IC002 are on a small add-on board, BE2200F01003, wired to the top of the main board.[6]
| Position | Part | Function |
| IC101 | 315-5632, custom chip MCE3 | Gate array |
| IC102, IC103 | TC511664BJ-80 or µPD421664 | Word RAM |
| IC104, IC105 | CXK5864BM-70 | CD-ROM buffer RAM |
| IC106 | LC89515 | CD-ROM decoder |
| IC107 | µPD424270, HM514270AJ, M5M44270AJ or MN414270SJ | Program RAM, 4 Mbit |
| IC108, IC109 | LH5P832N-10 or TC51832FL-10 | PCM waveform RAM |
| IC110 | 315-5476A, RF5C164A | PCM sound |
| IC111 | EPR-15511 or MPR-15511A (Sega CD II); EPR-15512 or MPR-15512A (Mega CD II) | Boot ROM |
| IC112 | MB8464A-10LL | Back-up RAM |
| IC113 | MC68HC000FN12, HD68HC000CP-12 or TMP68HC000T-12 | Sub CPU |
| IC114 | MB3790 | Battery back-up |
| IC201 | LC7883KM | CD audio D/A converter |
| IC202 | LC78815M | PCM D/A converter |
| IC203 to IC205 | NJM3403AM, NJM3404AM | Op-amps |
| IC301 | µPC2405HF | 5 V regulator |
Clocks are X101, a 50.000 MHz oscillator; X401, a 16.9344 MHz crystal; and X702, a 4.19 MHz ceramic resonator. The connector to the console, CN101, is a 60-pin edge connector.[4]
Drive units
The supplement lists two drive units for the Funai board, told apart by the label on the mechanism: 610-5608, labelled KSS-210A, and 610-5603, labelled SOHOT4. Ten resistors and three capacitors around the drive differ between them, C412 among them, and the tracking gain adjustment value is 1 kHz/0 dB for 610-5608 and 800 Hz/0 dB for 610-5603.[8] The Sony board uses a KSK-1310A (KSM2401AAN mechanism, KSS-240A pickup) or an Optima 6S drive.[7]
Servicing
Sega's guides for servicing are flowcharts for the focus, tracking, disc and feed circuits, each starting with the 9 V check at IC409. Among the figures they give: laser power 90 to 120 µW; an RF waveform of about 1.5 Vp-p at IC402 pin 2 (TP-RF); about 7 V focus drive between IC409 pins 7 and 8; and about 3 V focus error output between IC403 pins 7 and 5.[5] Setting the door switch SW401 from off to on should light the laser for about two seconds and move the lens up and down.[5]
The drive has three adjustments: VR403 sets the VCO to 4.320 ± 0.05 MHz at TP-PLCK, VR401 sets EF balance and VR402 sets tracking gain. The procedure needs Sega's adjustment jig on CN403, a Sony TYPE-4 test disc, a frequency counter, an oscilloscope, an audio generator and two voltmeters.[10]
See the Sega CD (Model 2) Troubleshooting Guide for fault finding, the Sega CD (Model 2) Maintenance Guide for strip-down and cleaning, and the Sega CD (Model 2) Capacitor Replacement Guide for the capacitor lists by board.
Things that are not faults
- No drive belt or tray motor. The lid is opened by hand.
- Its own adaptor. The add-on is powered separately from the console.
- No video of its own. The picture comes from the console.
- The mixing jack. It is for the original Mega Drive and Genesis, whose sound is cabled into it; the Model 2 console does not need the cable.[11][1]
- Saves lost after about a month without power. Sega's back-up retention figure is about one month.[2]
- Sega CD 2 / Mega CD 2 - Service Manual: No. 002, August 1993.
- Sega CD 2 / Mega CD 2 - Service Manual Supplement: No. 002-2, June 1994, for units from serial number T30282001.
- Mega CD / Sega CD Schematics: larger A3 scans of the schematic and board pages from both.
Gallery
An early Funai main board, with the add-on board for IC001 and IC002 wired on
A main board with boot ROM MPR-15764-T, which Console5 lists on the 171-6528C board
Sega's circuit board diagram for the main board
- ↑ 1.0 1.1 1.2 1.3 1.4 Sega CD—link(accessed 2026-10-01) Secondary source; the Japanese date is cited there to Sega's own Mega-CD 2 page and the North American price to GamePro issue 52.
- ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 Sega Enterprises, Ltd., Service Manual, Sega CD II / Mega CD II, No. 002, August 1993, section 1, specifications, p. 2. See Sega CD 2 / Mega CD 2 - Service Manual.
- ↑ 3.0 3.1 3.2 3.3 Sega Enterprises, Ltd., Service Manual, Sega CD II / Mega CD II, No. 002, August 1993, section 13-4, accessories and package list, p. 42. See Sega CD 2 / Mega CD 2 - Service Manual.
- ↑ 4.0 4.1 4.2 4.3 4.4 Sega Enterprises, Ltd., Service Manual, Sega CD II / Mega CD II, No. 002, August 1993, section 13-3, electrical parts list, pp. 39-42. See Sega CD 2 / Mega CD 2 - Service Manual.
- ↑ 5.0 5.1 5.2 Sega Enterprises, Ltd., Service Manual, Sega CD II / Mega CD II, No. 002, August 1993, section 8, guides for servicing: overall chart (p. 11), focus (p. 12), tracking (p. 12), disc (p. 13) and feed (p. 14) circuit flowcharts. See Sega CD 2 / Mega CD 2 - Service Manual.
- ↑ 6.0 6.1 6.2 Sega CD v2: Funai—link(accessed 2026-10-01) Secondary source; IC and capacitor lists read off real boards.
- ↑ 7.0 7.1 7.2 7.3 Sega CD v2: Sony—link(accessed 2026-10-01) Secondary source; IC and capacitor lists read off real boards.
- ↑ 8.0 8.1 8.2 Sega Enterprises, Ltd., Service Manual Supplement, Sega CD II / Mega CD II, No. 002-2, June 1994. See Sega CD 2 / Mega CD 2 - Service Manual Supplement.
- ↑ Sega Enterprises, Ltd., Service Manual, Sega CD II / Mega CD II, No. 002, August 1993, section 9, block diagram, p. 15. See Sega CD 2 / Mega CD 2 - Service Manual.
- ↑ Sega Enterprises, Ltd., Service Manual, Sega CD II / Mega CD II, No. 002, August 1993, section 4, CD drive adjustment, pp. 6-7. See Sega CD 2 / Mega CD 2 - Service Manual.
- ↑ Sega Enterprises, Ltd., Service Manual, Sega CD II / Mega CD II, No. 002, August 1993, section 2, identifying parts and accessories, p. 3. See Sega CD 2 / Mega CD 2 - Service Manual.
