Module:String
Revision as of 16:15, 15 March 2025 by Josh (talk | contribs) (1 revision imported)
Documentation for this module may be created at Module:String/doc
This module is intended to provide access to basic string functions.
Most of the functions provided here can be invoked with named parameters,
unnamed parameters, or a mixture.  If named parameters are used, Mediawiki will
automatically remove any leading or trailing whitespace from the parameter.
Depending on the intended use, it may be advantageous to either preserve or
remove such whitespace.
Global options
    ignore_errors: If set to 'true' or 1, any error condition will result in
        an empty string being returned rather than an error message.
    error_category: If an error occurs, specifies the name of a category to
        include with the error message.  The default category is
        [Category:Errors reported by Module String].
    no_category: If set to 'true' or 1, no category will be added if an error
        is generated.
Unit tests for this module are available at Module:String/tests.
local str = {}
len
This function returns the length of the target string.
Usage:
{{#invoke:String|len|target_string|}}
OR
{{#invoke:String|len|s=target_string}}
Parameters
    s: The string whose length to report
If invoked using named parameters, Mediawiki will automatically remove any leading or
trailing whitespace from the target string.
function str.len( frame )
	local new_args = str._getParameters( frame.args, {'s'} )
	local s = new_args['s'] or ''
	return mw.ustring.len( s )
end
sub
This function returns a substring of the target string at specified indices.
Usage:
{{#invoke:String|sub|target_string|start_index|end_index}}
OR
{{#invoke:String|sub|s=target_string|i=start_index|j=end_index}}
Parameters
    s: The string to return a subset of
    i: The first index of the substring to return, defaults to 1.
    j: The last index of the string to return, defaults to the last character.
The first character of the string is assigned an index of 1.  If either i or j
is a negative value, it is interpreted the same as selecting a character by
counting from the end of the string.  Hence, a value of -1 is the same as
selecting the last character of the string.
If the requested indices are out of range for the given string, an error is
reported.
function str.sub( frame )
	local new_args = str._getParameters( frame.args, { 's', 'i', 'j' } )
	local i = tonumber( new_args['i'] ) or 1
	local j = tonumber( new_args['j'] ) or -1
	local len = mw.ustring.len( s )
	-- Convert negatives for range checking
	if i < 0 then
		i = len + i + 1
	end
	if j < 0 then
		j = len + j + 1
	end
	if i > len or j > len or i < 1 or j < 1 then
		return str._error( 'String subset index out of range' )
	end
	if j < i then
		return str._error( 'String subset indices out of order' )
	end
	return mw.ustring.sub( s, i, j )
end
This function implements that features of {{str sub old}} and is kept in order
to maintain these older templates.
function str.sublength( frame )
	local i = tonumber( frame.args.i ) or 0
	local len = tonumber( frame.args.len )
	return mw.ustring.sub( frame.args.s, i + 1, len and ( i + len ) )
end
_match
This function returns a substring from the source string that matches a
specified pattern. It is exported for use in other modules
Usage:
strmatch = require("Module:String")._match
sresult = strmatch( s, pattern, start, match, plain, nomatch )
Parameters
    s: The string to search
    pattern: The pattern or string to find within the string
    start: The index within the source string to start the search.  The first
        character of the string has index 1.  Defaults to 1.
    match: In some cases it may be possible to make multiple matches on a single
        string.  This specifies which match to return, where the first match is
        match= 1.  If a negative number is specified then a match is returned
        counting from the last match.  Hence match = -1 is the same as requesting
        the last match.  Defaults to 1.
    plain: A flag indicating that the pattern should be understood as plain
        text.  Defaults to false.
    nomatch: If no match is found, output the "nomatch" value rather than an error.
For information on constructing Lua patterns, a form of [regular expression], see:
* http://www.lua.org/manual/5.1/manual.html#5.4.1
* http://www.mediawiki.org/wiki/Extension:Scribunto/Lua_reference_manual#Patterns
* http://www.mediawiki.org/wiki/Extension:Scribunto/Lua_reference_manual#Ustring_patterns
-- This sub-routine is exported for use in other modules
function str._match( s, pattern, start, match_index, plain_flag, nomatch )
	if s == '' then
		return str._error( 'Target string is empty' )
	end
	if pattern == '' then
		return str._error( 'Pattern string is empty' )
	end
	start = tonumber(start) or 1
	if math.abs(start) < 1 or math.abs(start) > mw.ustring.len( s ) then
		return str._error( 'Requested start is out of range' )
	end
	if match_index == 0 then
		return str._error( 'Match index is out of range' )
	end
	if plain_flag then
		pattern = str._escapePattern( pattern )
	end
	local result
	if match_index == 1 then
		-- Find first match is simple case
		result = mw.ustring.match( s, pattern, start )
	else
		if start > 1 then
			s = mw.ustring.sub( s, start )
		end
		local iterator = mw.ustring.gmatch(s, pattern)
		if match_index > 0 then
			-- Forward search
			for w in iterator do
				match_index = match_index - 1
					result = w
					break
				end
			end
		else
			-- Reverse search
			local result_table = {}
			local count = 1
				result_table[count] = w
				count = count + 1
			end
			result = result_table[ count + match_index ]
		end
	end
	if result == nil then
		if nomatch == nil then
			return str._error( 'Match not found' )
		else
			return nomatch
		end
	else
		return result
	end
end
match
specified pattern.
Usage:
{{#invoke:String|match|source_string|pattern_string|start_index|match_number|plain_flag|nomatch_output}}
OR
{{#invoke:String|match|s=source_string|pattern=pattern_string|start=start_index
    |match=match_number|plain=plain_flag|nomatch=nomatch_output}}
Parameters
trailing whitespace from each string.  In some circumstances this is desirable, in
other cases one may want to preserve the whitespace.
If the match_number or start_index are out of range for the string being queried, then
this function generates an error.  An error is also generated if no match is found.
If one adds the parameter ignore_errors=true, then the error will be suppressed and
an empty string will be returned on any failure.
-- This is the entry point for #invoke:String|match
function str.match( frame )
	local new_args = str._getParameters( frame.args, {'s', 'pattern', 'start', 'match', 'plain', 'nomatch'} )
	local start = tonumber( new_args['start'] ) or 1
	local plain_flag = str._getBoolean( new_args['plain'] or false )
	local pattern = new_args['pattern'] or ''
	local match_index = math.floor( tonumber(new_args['match']) or 1 )
	local nomatch = new_args['nomatch']
	return str._match( s, pattern, start, match_index, plain_flag, nomatch )
end
pos
This function returns a single character from the target string at position pos.
Usage:
{{#invoke:String|pos|target_string|index_value}}
OR
{{#invoke:String|pos|target=target_string|pos=index_value}}
Parameters
    target: The string to search
    pos: The index for the character to return
trailing whitespace from the target string.  In some circumstances this is desirable, in
The first character has an index value of 1.
If one requests a negative value, this function will select a character by counting backwards
from the end of the string.  In other words pos = -1 is the same as asking for the last character.
A requested value of zero, or a value greater than the length of the string returns an error.
function str.pos( frame )
	local new_args = str._getParameters( frame.args, {'target', 'pos'} )
	local target_str = new_args['target'] or ''
	local pos = tonumber( new_args['pos'] ) or 0
	if pos == 0 or math.abs(pos) > mw.ustring.len( target_str ) then
		return str._error( 'String index out of range' )
	end
	return mw.ustring.sub( target_str, pos, pos )
end
str_find
This function duplicates the behavior of {{str_find}}, including all of its quirks.
This is provided in order to support existing templates, but is NOT RECOMMENDED for
new code and templates.  New code is recommended to use the "find" function instead.
Returns the first index in "source" that is a match to "target".  Indexing is 1-based,
and the function returns -1 if the "target" string is not present in "source".
Important Note: If the "target" string is empty / missing, this function returns a
value of "1", which is generally unexpected behavior, and must be accounted for
separatetly.
function str.str_find( frame )
	local new_args = str._getParameters( frame.args, {'source', 'target'} )
	local source_str = new_args['source'] or ''
	if target_str == '' then
		return 1
	end
	local start = mw.ustring.find( source_str, target_str, 1, true )
	if start == nil then
		start = -1
	end
	return start
end
find
This function allows one to search for a target string or pattern within another
string.
Usage:
{{#invoke:String|find|source_str|target_string|start_index|plain_flag}}
OR
{{#invoke:String|find|source=source_str|target=target_str|start=start_index|plain=plain_flag}}
Parameters
    source: The string to search
    target: The string or pattern to find within source
    start: The index within the source string to start the search, defaults to 1
    plain: Boolean flag indicating that target should be understood as plain
        text and not as a Lua style regular expression, defaults to true
trailing whitespace from the parameter.  In some circumstances this is desirable, in
This function returns the first index >= "start" where "target" can be found
within "source".  Indices are 1-based.  If "target" is not found, then this
function returns 0.  If either "source" or "target" are missing / empty, this
function also returns 0.
This function should be safe for UTF-8 strings.
function str.find( frame )
	local new_args = str._getParameters( frame.args, {'source', 'target', 'start', 'plain' } )
	local pattern = new_args['target'] or ''
	local start_pos = tonumber(new_args['start']) or 1
	local plain = new_args['plain'] or true
	if source_str == '' or pattern == '' then
		return 0
	end
	plain = str._getBoolean( plain )
	local start = mw.ustring.find( source_str, pattern, start_pos, plain )
		start = 0
	end
	return start
end
replace
This function allows one to replace a target string or pattern within another
string.
Usage:
{{#invoke:String|replace|source_str|pattern_string|replace_string|replacement_count|plain_flag}}
OR
{{#invoke:String|replace|source=source_string|pattern=pattern_string|replace=replace_string|
   count=replacement_count|plain=plain_flag}}
Parameters
    pattern: The string or pattern to find within source
    replace: The replacement text
    count: The number of occurences to replace, defaults to all.
    plain: Boolean flag indicating that pattern should be understood as plain
function str.replace( frame )
	local new_args = str._getParameters( frame.args, {'source', 'pattern', 'replace', 'count', 'plain' } )
	local replace = new_args['replace'] or ''
	local count = tonumber( new_args['count'] )
		return source_str
	end
	if plain then
		replace = string.gsub( replace, "%%", "%%%%" ) --Only need to escape replacement sequences.
	end
	local result
	if count ~= nil then
		result = mw.ustring.gsub( source_str, pattern, replace, count )
	else
		result = mw.ustring.gsub( source_str, pattern, replace )
	end
	return result
end
    simple function to pipe string.rep to templates.
function str.rep( frame )
	local repetitions = tonumber( frame.args[2] )
	if not repetitions then
		return str._error( 'function rep expects a number as second parameter, received "' .. ( frame.args[2] or '' ) .. '"' )
	end
	return string.rep( frame.args[1] or '', repetitions )
end
escapePattern
This function escapes special characters from a Lua string pattern. See [1]
for details on how patterns work.
[1] https://www.mediawiki.org/wiki/Extension:Scribunto/Lua_reference_manual#Patterns
Usage:
{{#invoke:String|escapePattern|pattern_string}}
Parameters
    pattern_string: The pattern string to escape.
function str.escapePattern( frame )
	local pattern_str = frame.args[1]
	if not pattern_str then
		return str._error( 'No pattern string specified' )
	end
	local result = str._escapePattern( pattern_str )
	return result
end
count
This function counts the number of occurrences of one string in another.
function str.count(frame)
	local args = str._getParameters(frame.args, {'source', 'pattern', 'plain'})
	local source = args.source or ''
	local pattern = args.pattern or ''
	local plain = str._getBoolean(args.plain or true)
	if plain then
		pattern = str._escapePattern(pattern)
	end
	local _, count = mw.ustring.gsub(source, pattern, '')
	return count
end
endswith
This function determines whether a string ends with another string.
function str.endswith(frame)
	local args = str._getParameters(frame.args, {'source', 'pattern'})
		-- All strings end with the empty string.
		return "yes"
	end
	if mw.ustring.sub(source, -mw.ustring.len(pattern), -1) == pattern then
		return "yes"
	else
		return ""
	end
end
join
Join all non empty arguments together; the first argument is the separator.
Usage:
{{#invoke:String|join|sep|one|two|three}}
function str.join(frame)
	local args = {}
	local sep
	for _, v in ipairs( frame.args ) do
		if sep then
			if v ~= '' then
				table.insert(args, v)
			end
		else
			sep = v
		end
	end
	return table.concat( args, sep or '' )
end
Helper function that populates the argument list given that user may need to use a mix of
named and unnamed parameters.  This is relevant because named parameters are not
identical to unnamed parameters due to string trimming, and when dealing with strings
we sometimes want to either preserve or remove that whitespace depending on the application.
function str._getParameters( frame_args, arg_list )
	local new_args = {}
	local index = 1
	local value
	for _, arg in ipairs( arg_list ) do
		value = frame_args[arg]
		if value == nil then
			value = frame_args[index]
			index = index + 1
		end
		new_args[arg] = value
	end
	return new_args
end
Helper function to handle error messages.
function str._error( error_str )
	local error_category = frame.args.error_category or 'Errors reported by Module String'
	local ignore_errors = frame.args.ignore_errors or false
	local no_category = frame.args.no_category or false
	if str._getBoolean(ignore_errors) then
		return ''
	end
	local error_str = '<strong class="error">String Module Error: ' .. error_str .. '</strong>'
	if error_category ~= '' and not str._getBoolean( no_category ) then
		error_str = '[[Category:' .. error_category .. ']]' .. error_str
	end
	return error_str
end
Helper Function to interpret boolean strings
function str._getBoolean( boolean_str )
	local boolean_value
	if type( boolean_str ) == 'string' then
		boolean_str = boolean_str:lower()
		if boolean_str == 'false' or boolean_str == 'no' or boolean_str == '0'
				or boolean_str == '' then
			boolean_value = false
		else
			boolean_value = true
		end
	elseif type( boolean_str ) == 'boolean' then
		boolean_value = boolean_str
	else
		error( 'No boolean value found' )
	end
	return boolean_value
end
Helper function that escapes all pattern characters so that they will be treated
as plain text.
function str._escapePattern( pattern_str )
	return ( string.gsub( pattern_str, "[%(%)%.%%%+%-%*%?%[%^%$%]]", "%%%0" ) )
end
return str
