Module:TableTools
Revision as of 16:15, 15 March 2025 by Josh (talk | contribs) (1 revision imported)
Documentation for this module may be created at Module:TableTools/doc
--                                   TableTools                                   --
-- This module includes a number of functions for dealing with Lua tables.        --
-- It is a meta-module, meant to be called from other Lua modules, and should not --
-- be called directly from #invoke.                                               --
local libraryUtil = require('libraryUtil')
local p = {}
-- Define often-used variables and functions.
local floor = math.floor
local infinity = math.huge
local checkType = libraryUtil.checkType
local checkTypeMulti = libraryUtil.checkTypeMulti
-- isPositiveInteger
-- This function returns true if the given value is a positive integer, and false
-- if not. Although it doesn't operate on tables, it is included here as it is
-- useful for determining whether a given table key is in the array part or the
-- hash part of a table.
function p.isPositiveInteger(v)
	return type(v) == 'number' and v >= 1 and floor(v) == v and v < infinity
end
-- isNan
-- This function returns true if the given number is a NaN value, and false if
-- not. Although it doesn't operate on tables, it is included here as it is useful
-- for determining whether a value can be a valid table key. Lua will generate an
-- error if a NaN is used as a table key.
function p.isNan(v)
	return type(v) == 'number' and v ~= v
end
-- shallowClone
-- This returns a clone of a table. The value returned is a new table, but all
-- subtables and functions are shared. Metamethods are respected, but the returned
-- table will have no metatable of its own.
function p.shallowClone(t)
	checkType('shallowClone', 1, t, 'table')
	local ret = {}
	for k, v in pairs(t) do
		ret[k] = v
	end
	return ret
end
-- removeDuplicates
-- This removes duplicate values from an array. Non-positive-integer keys are
-- ignored. The earliest value is kept, and all subsequent duplicate values are
-- removed, but otherwise the array order is unchanged.
function p.removeDuplicates(arr)
	checkType('removeDuplicates', 1, arr, 'table')
	local isNan = p.isNan
	local ret, exists = {}, {}
	for _, v in ipairs(arr) do
		if isNan(v) then
			-- NaNs can't be table keys, and they are also unique, so we don't need to check existence.
			ret[#ret + 1] = v
		elseif not exists[v] then
			ret[#ret + 1] = v
			exists[v] = true
		end
	end
	return ret
end
-- numKeys
-- This takes a table and returns an array containing the numbers of any numerical
-- keys that have non-nil values, sorted in numerical order.
function p.numKeys(t)
	checkType('numKeys', 1, t, 'table')
	local isPositiveInteger = p.isPositiveInteger
	local nums = {}
	for k in pairs(t) do
		if isPositiveInteger(k) then
			nums[#nums + 1] = k
		end
	end
	table.sort(nums)
	return nums
end
-- affixNums
-- This takes a table and returns an array containing the numbers of keys with the
-- specified prefix and suffix. For example, for the table
-- {a1 = 'foo', a3 = 'bar', a6 = 'baz'} and the prefix "a", affixNums will return
-- {1, 3, 6}.
function p.affixNums(t, prefix, suffix)
	checkType('affixNums', 1, t, 'table')
	checkType('affixNums', 2, prefix, 'string', true)
	checkType('affixNums', 3, suffix, 'string', true)
	local function cleanPattern(s)
		-- Cleans a pattern so that the magic characters ()%.[]*+-?^$ are interpreted literally.
		return s:gsub('([%(%)%%%.%[%]%*%+%-%?%^%$])', '%%%1')
	end
	prefix = prefix or ''
	suffix = suffix or ''
	prefix = cleanPattern(prefix)
	suffix = cleanPattern(suffix)
	local pattern = '^' .. prefix .. '([1-9]%d*)' .. suffix .. '$'
	local nums = {}
		if type(k) == 'string' then
			local num = mw.ustring.match(k, pattern)
			if num then
				nums[#nums + 1] = tonumber(num)
			end
		end
	end
	table.sort(nums)
	return nums
end
-- numData
-- Given a table with keys like {"foo1", "bar1", "foo2", "baz2"}, returns a table
-- of subtables in the format
-- {[1] = {foo = 'text', bar = 'text'}, [2] = {foo = 'text', baz = 'text'}}.
-- Keys that don't end with an integer are stored in a subtable named "other". The
-- compress option compresses the table so that it can be iterated over with
-- ipairs.
function p.numData(t, compress)
	checkType('numData', 1, t, 'table')
	checkType('numData', 2, compress, 'boolean', true)
	local ret = {}
		local prefix, num = mw.ustring.match(tostring(k), '^([^0-9]*)([1-9][0-9]*)$')
		if num then
			num = tonumber(num)
			local subtable = ret[num] or {}
			if prefix == '' then
				-- Positional parameters match the blank string; put them at the start of the subtable instead.
				prefix = 1
			end
			subtable[prefix] = v
			ret[num] = subtable
		else
			local subtable = ret.other or {}
			subtable[k] = v
			ret.other = subtable
		end
	end
	if compress then
		local other = ret.other
		ret = p.compressSparseArray(ret)
		ret.other = other
	end
	return ret
end
-- compressSparseArray
-- This takes an array with one or more nil values, and removes the nil values
-- while preserving the order, so that the array can be safely traversed with
-- ipairs.
function p.compressSparseArray(t)
	checkType('compressSparseArray', 1, t, 'table')
	local ret = {}
	local nums = p.numKeys(t)
	for _, num in ipairs(nums) do
		ret[#ret + 1] = t[num]
	end
	return ret
end
-- sparseIpairs
-- This is an iterator for sparse arrays. It can be used like ipairs, but can
-- handle nil values.
function p.sparseIpairs(t)
	checkType('sparseIpairs', 1, t, 'table')
	local i = 0
	local lim = #nums
	return function ()
		i = i + 1
		if i <= lim then
			local key = nums[i]
			return key, t[key]
		else
			return nil, nil
		end
	end
end
-- size
-- This returns the size of a key/value pair table. It will also work on arrays,
-- but for arrays it is more efficient to use the # operator.
function p.size(t)
	checkType('size', 1, t, 'table')
	local i = 0
	for _ in pairs(t) do
		i = i + 1
	end
	return i
end
local function defaultKeySort(item1, item2)
	-- "number" < "string", so numbers will be sorted before strings.
	local type1, type2 = type(item1), type(item2)
	if type1 ~= type2 then
		return type1 < type2
	elseif type1 == 'table' or type1 == 'boolean' or type1 == 'function' then
		return tostring(item1) < tostring(item2)
	else
		return item1 < item2
	end
end
-- keysToList
-- Returns an array of the keys in a table, sorted using either a default
-- comparison function or a custom keySort function.
function p.keysToList(t, keySort, checked)
	if not checked then
		checkType('keysToList', 1, t, 'table')
		checkTypeMulti('keysToList', 2, keySort, {'function', 'boolean', 'nil'})
	end
	local arr = {}
	local index = 1
		arr[index] = k
		index = index + 1
	end
	if keySort ~= false then
		keySort = type(keySort) == 'function' and keySort or defaultKeySort
		table.sort(arr, keySort)
	end
	return arr
end
-- sortedPairs
-- Iterates through a table, with the keys sorted using the keysToList function.
-- If there are only numerical keys, sparseIpairs is probably more efficient.
function p.sortedPairs(t, keySort)
	checkType('sortedPairs', 1, t, 'table')
	checkType('sortedPairs', 2, keySort, 'function', true)
	local arr = p.keysToList(t, keySort, true)
	local i = 0
	return function ()
		i = i + 1
		local key = arr[i]
		if key ~= nil then
			return key, t[key]
		else
			return nil, nil
		end
	end
end
-- isArray
-- Returns true if the given value is a table and all keys are consecutive
-- integers starting at 1.
function p.isArray(v)
	if type(v) ~= 'table' then
		return false
	end
	local i = 0
	for _ in pairs(v) do
		i = i + 1
		if v[i] == nil then
			return false
		end
	end
	return true
end
-- isArrayLike
-- Returns true if the given value is iterable and all keys are consecutive
function p.isArrayLike(v)
	if not pcall(pairs, v) then
		return false
	end
	local i = 0
		i = i + 1
		if v[i] == nil then
			return false
		end
	end
	return true
end
-- invert
-- Transposes the keys and values in an array. For example, {"a", "b", "c"} ->
-- {a = 1, b = 2, c = 3}. Duplicates are not supported (result values refer to
-- the index of the last duplicate) and NaN values are ignored.
function p.invert(arr)
	checkType("invert", 1, arr, "table")
	local map = {}
	for i, v in ipairs(arr) do
		if not isNan(v) then
			map[v] = i
		end
	end
	return map
end
-- listToSet
-- Creates a set from the array part of the table. Indexing the set by any of the
-- values of the array returns true. For example, {"a", "b", "c"} ->
-- {a = true, b = true, c = true}. NaN values are ignored as Lua considers them
-- never equal to any value (including other NaNs or even themselves).
function p.listToSet(arr)
	checkType("listToSet", 1, arr, "table")
	local set = {}
			set[v] = true
		end
	end
	return set
end
-- deepCopy
-- Recursive deep copy function. Preserves identities of subtables.
local function _deepCopy(orig, includeMetatable, already_seen)
	if type(orig) ~= "table" then
		return orig
	end
	-- already_seen stores copies of tables indexed by the original table.
	local copy = already_seen[orig]
	if copy ~= nil then
		return copy
	end
	copy = {}
	already_seen[orig] = copy -- memoize before any recursion, to avoid infinite loops
	for orig_key, orig_value in pairs(orig) do
		copy[_deepCopy(orig_key, includeMetatable, already_seen)] = _deepCopy(orig_value, includeMetatable, already_seen)
	end
	if includeMetatable then
		local mt = getmetatable(orig)
		if mt ~= nil then
			setmetatable(copy, _deepCopy(mt, true, already_seen))
		end
	end
	return copy
end
function p.deepCopy(orig, noMetatable, already_seen)
	checkType("deepCopy", 3, already_seen, "table", true)
	return _deepCopy(orig, not noMetatable, already_seen or {})
end
-- sparseConcat
-- Concatenates all values in the table that are indexed by a number, in order.
-- sparseConcat{a, nil, c, d}  =>  "acd"
-- sparseConcat{nil, b, c, d}  =>  "bcd"
function p.sparseConcat(t, sep, i, j)
	local arr = {}
	local arr_i = 0
	for _, v in p.sparseIpairs(t) do
		arr_i = arr_i + 1
		arr[arr_i] = v
	end
	return table.concat(arr, sep, i, j)
end
-- length
-- Finds the length of an array, or of a quasi-array with keys such as "data1",
-- "data2", etc., using an exponential search algorithm. It is similar to the
-- operator #, but may return a different value when there are gaps in the array
-- portion of the table. Intended to be used on data loaded with mw.loadData. For
-- other tables, use #.
-- Note: #frame.args in frame object always be set to 0, regardless of  the number
-- of unnamed template parameters, so use this function for frame.args.
function p.length(t, prefix)
	-- requiring module inline so that [[Module:Exponential search]] which is
	-- only needed by this one function doesn't get millions of transclusions
	local expSearch = require("Module:Exponential search")
	checkType('length', 1, t, 'table')
	checkType('length', 2, prefix, 'string', true)
	return expSearch(function (i)
		local key
		if prefix then
			key = prefix .. tostring(i)
		else
			key = i
		end
		return t[key] ~= nil
	end) or 0
end
-- inArray
-- Returns true if searchElement is a member of the array, and false otherwise.
-- Equivalent to JavaScript array.includes(searchElement) or
-- array.includes(searchElement, fromIndex), except fromIndex is 1 indexed
function p.inArray(array, searchElement, fromIndex)
	checkType("inArray", 1, array, "table")
	-- if searchElement is nil, error?
	fromIndex = tonumber(fromIndex)
	if fromIndex then
		if (fromIndex < 0) then
			fromIndex = #array + fromIndex + 1
		end
		if fromIndex < 1 then fromIndex = 1 end
		for _, v in ipairs({unpack(array, fromIndex)}) do
			if v == searchElement then
				return true
			end
		end
	else
		for _, v in pairs(array) do
				return true
			end
		end
	end
	return false
end
-- merge
-- Given the arrays, returns an array containing the elements of each input array
-- in sequence.
function p.merge(...)
	local arrays = {...}
	local ret = {}
	for i, arr in ipairs(arrays) do
		checkType('merge', i, arr, 'table')
			ret[#ret + 1] = v
		end
	end
	return ret
end
-- extend
-- Extends the first array in place by appending all elements from the second
-- array.
function p.extend(arr1, arr2)
	checkType('extend', 1, arr1, 'table')
	checkType('extend', 2, arr2, 'table')
	for _, v in ipairs(arr2) do
		arr1[#arr1 + 1] = v
	end
end
return p
