Module:Protection banner/config
Revision as of 16:15, 15 March 2025 by Josh (talk | contribs) (1 revision imported)
Documentation for this module may be created at Module:Protection banner/config/doc
-- This module provides configuration data for [[Module:Protection banner]].
return {
--                                BANNER DATA
-- Banner data consists of six fields:
-- * text - the main protection text that appears at the top of protection
--   banners.
-- * explanation - the text that appears below the main protection text, used
--   to explain the details of the protection.
-- * tooltip - the tooltip text you see when you move the mouse over a small
--   padlock icon.
-- * link - the page that the small padlock icon links to.
-- * alt - the alt text for the small padlock icon. This is also used as tooltip
--   text for the large protection banners.
-- * image - the padlock image used in both protection banners and small padlock
--   icons.
-- The module checks in three separate tables to find a value for each field.
-- First it checks the banners table, which has values specific to the reason
-- for the page being protected. Then the module checks the defaultBanners
-- table, which has values specific to each protection level. Finally, the
-- module checks the masterBanner table, which holds data for protection
-- templates to use if no data has been found in the previous two tables.
-- The values in the banner data can take parameters. These are specified
-- using ${TEXTLIKETHIS} (a dollar sign preceding a parameter name
-- enclosed in curly braces).
--                          Available parameters:
-- ${CURRENTVERSION} - a link to the page history or the move log, with the
-- display message "current-version-edit-display" or
-- "current-version-move-display".
-- ${EDITREQUEST} - a link to create an edit request for the current page.
-- ${EXPLANATIONBLURB} - an explanation blurb, e.g. "Please discuss any changes
-- on the talk page; you may submit a request to ask an administrator to make
-- an edit if it is minor or supported by consensus."
-- ${IMAGELINK} - a link to set the image to, depending on the protection
-- action and protection level.
-- ${INTROBLURB} - the PROTECTIONBLURB parameter, plus the expiry if an expiry
-- is set. E.g. "Editing of this page by new or unregistered users is currently
-- disabled until dd Month YYYY."
-- ${INTROFRAGMENT} - the same as ${INTROBLURB}, but without final punctuation
-- so that it can be used in run-on sentences.
-- ${PAGETYPE} - the type of the page, e.g. "article" or "template".
-- Defined in the cfg.pagetypes table.
-- ${PROTECTIONBLURB} - a blurb explaining the protection level of the page, e.g.
-- "Editing of this page by new or unregistered users is currently disabled"
-- ${PROTECTIONDATE} - the protection date, if it has been supplied to the
-- template.
-- ${PROTECTIONLEVEL} - the protection level, e.g. "fully protected" or
-- "semi-protected".
-- ${PROTECTIONLOG} - a link to the protection log or the pending changes log,
-- depending on the protection action.
-- ${TALKPAGE} - a link to the talk page. If a section is specified, links
-- straight to that talk page section.
-- ${TOOLTIPBLURB} - uses the PAGETYPE, PROTECTIONTYPE and EXPIRY parameters to
-- create a blurb like "This template is semi-protected", or "This article is
-- move-protected until DD Month YYYY".
-- ${VANDAL} - links for the specified username (or the root page name)
-- using Module:Vandal-m.
--                                 Functions
-- For advanced users, it is possible to use Lua functions instead of strings
-- in the banner config tables. Using functions gives flexibility that is not
-- possible just by using parameters. Functions take two arguments, the
-- protection object and the template arguments, and they must output a string.
-- For example:
-- text = function (protectionObj, args)
--     if protectionObj.level == 'autoconfirmed' then
--         return 'foo'
--     else
--         return 'bar'
--     end
-- end
-- Some protection object properties and methods that may be useful:
-- protectionObj.action - the protection action
-- protectionObj.level - the protection level
-- protectionObj.reason - the protection reason
-- protectionObj.expiry - the expiry. Nil if unset, the string "indef" if set
--     to indefinite, and the protection time in unix time if temporary.
-- protectionObj.protectionDate - the protection date in unix time, or nil if
--     unspecified.
-- protectionObj.bannerConfig - the banner config found by the module. Beware
--     of editing the config field used by the function, as it could create an
--     infinite loop.
-- protectionObj:isProtected - returns a boolean showing whether the page is
--     protected.
-- protectionObj:isTemporary - returns a boolean showing whether the expiry is
--     temporary.
-- protectionObj:isIncorrect - returns a boolean showing whether the protection
--     template is incorrect.
-- The master banner data, used if no values have been found in banners or
-- defaultBanners.
masterBanner = {
	text = '${INTROBLURB}',
	explanation = '${EXPLANATIONBLURB}',
	tooltip = '${TOOLTIPBLURB}',
	link = '${IMAGELINK}',
	alt = 'Page ${PROTECTIONLEVEL}'
-- The default banner data. This holds banner data for different protection
-- levels.
-- *required* - this table needs edit, move, autoreview and upload subtables.
defaultBanners = {
	edit = {},
	move = {},
	autoreview = {
		default = {
			alt = 'Page protected with pending changes',
			tooltip = 'All edits by unregistered and new users are subject to review prior to becoming visible to unregistered users',
			image = 'Pending-protection-shackle.svg'
	upload = {}
-- The banner data. This holds banner data for different protection reasons.
-- In fact, the reasons specified in this table control which reasons are
-- valid inputs to the first positional parameter.
-- There is also a non-standard "description" field that can be used for items
-- in this table. This is a description of the protection reason for use in the
-- module documentation.
banners = {
	edit = {
		blp = {
			description = 'For pages protected to promote compliance with the'
				.. ' [[Wikipedia:Biographies of living persons'
				.. '|biographies of living persons]] policy',
			text = '${INTROFRAGMENT} to promote compliance with'
				.. "|Wikipedia's policy on the biographies"
				.. ' of living people]].',
			tooltip = '${TOOLTIPFRAGMENT} to promote compliance with the policy on'
				.. ' biographies of living persons',
		dmca = {
			description = 'For pages protected by the Wikimedia Foundation'
				.. ' due to [[Digital Millennium Copyright Act]] takedown requests',
			explanation = function (protectionObj, args)
				local ret = 'Pursuant to a rights owner notice under the Digital'
					.. ' Millennium Copyright Act (DMCA) regarding some content'
					.. ' in this article, the Wikimedia Foundation acted under'
					.. ' applicable law and took down and restricted the content'
					.. ' in question.'
				if args.notice then
					ret = ret .. ' A copy of the received notice can be found here: '
						.. args.notice .. '.'
				end
				ret = ret .. ' For more information, including websites discussing'
					.. ' how to file a counter-notice, please see'
					.. " [[Wikipedia:Office actions]] and the article's ${TALKPAGE}."
					.. "'''Do not remove this template from the article until the"
					.. " restrictions are withdrawn'''."
				return ret
			end,
			image = 'Office-protection-shackle.svg',
			link = 'Wikipedia:Protection policy#office',
		dispute = {
			description = 'For pages protected due to editing disputes',
				-- Find the value of "disputes".
				local display = 'disputes'
				local disputes
				if args.section then
					disputes = string.format(
						'[[%s:%s#%s|%s]]',
						mw.site.namespaces[protectionObj.title.namespace].talk.name,
						protectionObj.title.text,
						args.section,
						display
				else
					disputes = display
				end
				-- Make the blurb, depending on the expiry.
				local msg
				if type(protectionObj.expiry) == 'number' then
					msg = '${INTROFRAGMENT} or until editing %s have been resolved.'
				else
					msg = '${INTROFRAGMENT} until editing %s have been resolved.'
				end
				return string.format(msg, disputes)
			end,
			explanation = "This protection is '''not''' an endorsement of the"
				.. ' ${CURRENTVERSION}. ${EXPLANATIONBLURB}',
			tooltip = '${TOOLTIPFRAGMENT} due to editing disputes',
		ecp = {
			description = 'For articles in topic areas authorized by'
				.. ' [[Wikipedia:Arbitration Committee|ArbCom]] or'
				.. ' meets the criteria for community use',
			tooltip = 'This ${PAGETYPE} is ${PROTECTIONLEVEL}',
			alt = 'Extended-protected ${PAGETYPE}',
		mainpage = {
			description = 'For pages protected for being displayed on the [[Main Page]]',
			text = 'This file is currently'
				.. ' [[Wikipedia:This page is protected|protected]] from'
				.. ' editing because it is currently or will soon be displayed'
				.. ' on the [[Main Page]].',
			explanation = 'Images on the Main Page are protected due to their high'
				.. ' visibility. Please discuss any necessary changes on the ${TALKPAGE}.'
				.. '<br /><span style="font-size:90%;">'
				.. "'''Administrators:''' Once this image is definitely off the Main Page,"
				.. ' please unprotect this file, or reduce to semi-protection,'
				.. ' as appropriate.</span>',
		office = {
			description = 'For pages protected by the Wikimedia Foundation',
				local ret = 'This ${PAGETYPE} is currently under the'
					.. ' scrutiny of the'
					.. ' [[Wikipedia:Office actions|Wikimedia Foundation Office]]'
					.. ' and is protected.'
				if protectionObj.protectionDate then
					ret = ret .. ' It has been protected since ${PROTECTIONDATE}.'
				end
				return ret
			end,
			explanation = "If you can edit this page, please discuss all changes and"
				.. " additions on the ${TALKPAGE} first. '''Do not remove protection from this"
				.. " page unless you are authorized by the Wikimedia Foundation to do"
				.. " so.'''",
		reset = {
			description = 'For pages protected by the Wikimedia Foundation and'
				.. ' "reset" to a bare-bones version',
 			text = 'This ${PAGETYPE} is currently under the'
					.. ' and is protected.',
				local ret = ''
					ret = ret .. 'On ${PROTECTIONDATE} this ${PAGETYPE} was'
				else
					ret = ret .. 'This ${PAGETYPE} has been'
				end
				ret = ret .. ' reduced to a'
				.. ' simplified, "bare bones" version so that it may be completely'
				.. ' rewritten to ensure it meets the policies of'
				.. ' [[WP:NPOV|Neutral Point of View]] and [[WP:V|Verifiability]].'
				.. ' Standard Wikipedia policies will apply to its rewriting—which'
				.. ' will eventually be open to all editors—and will be strictly'
				.. ' enforced. The ${PAGETYPE} has been ${PROTECTIONLEVEL} while'
				.. ' it is being rebuilt.\n\n'
				.. 'Any insertion of material directly from'
				.. ' pre-protection revisions of the ${PAGETYPE} will be removed, as'
				.. ' will any material added to the ${PAGETYPE} that is not properly'
				.. ' sourced. The associated talk page(s) were also cleared on the'
				.. " same date.\n\n"
				.. "If you can edit this page, please discuss all changes and"
				.. " additions on the ${TALKPAGE} first. '''Do not override"
				.. " this action, and do not remove protection from this page,"
				.. " unless you are authorized by the Wikimedia Foundation"
				.. " to do so. No editor may remove this notice.'''"
				return ret
			end,
		sock = {
			description = 'For pages protected due to'
				.. ' [[Wikipedia:Sock puppetry|sock puppetry]]',
			text = '${INTROFRAGMENT} to prevent [[Wikipedia:Sock puppetry|sock puppets]] of'
				.. ' [[Wikipedia:Blocking policy|blocked]] or'
				.. ' [[Wikipedia:Banning policy|banned users]]'
				.. ' from editing it.',
			tooltip = '${TOOLTIPFRAGMENT} to prevent sock puppets of blocked or banned users from'
				.. ' editing it',
		template = {
			description = 'For [[Wikipedia:High-risk templates|high-risk]]'
				.. ' templates and Lua modules',
			text = 'This is a permanently [[Help:Protection|protected]] ${PAGETYPE},'
				.. ' as it is [[Wikipedia:High-risk templates|high-risk]].',
			explanation = 'Please discuss any changes on the ${TALKPAGE}; you may'
				.. ' ${EDITREQUEST} to ask an'
				.. ' [[Wikipedia:Administrators|administrator]] or'
				.. ' [[Wikipedia:Template editor|template editor]] to make an edit if'
				.. ' it is [[Help:Minor edit#When to mark an edit as a minor edit'
				.. '|uncontroversial]] or supported by'
				.. ' [[Wikipedia:Consensus|consensus]]. You can also'
				.. ' [[Wikipedia:Requests for page protection|request]] that the page be'
				.. ' unprotected.',
			tooltip = 'This high-risk ${PAGETYPE} is permanently ${PROTECTIONLEVEL}'
				.. ' to prevent vandalism',
			alt = 'Permanently protected ${PAGETYPE}',
		usertalk = {
			description = 'For pages protected against disruptive edits by a'
				.. ' particular user',
			text = '${INTROFRAGMENT} to prevent ${VANDAL} from using it to make disruptive edits,'
				.. ' such as abusing the'
				.. ' &#123;&#123;[[Template:unblock|unblock]]&#125;&#125; template.',
			explanation = 'If you cannot edit this user talk page and you need to'
				.. ' make a change or leave a message, you can'
				.. ' [[Wikipedia:Requests for page protection'
				.. '#Current requests for edits to a protected page'
				.. '|request an edit]],'
				.. '#Current requests for reduction in protection level'
				.. '|request unprotection]],'
				.. ' [[Special:Userlogin|log in]],'
				.. ' or [[Special:UserLogin/signup|create an account]].',
		vandalism = {
			description = 'For pages protected against'
				.. ' [[Wikipedia:Vandalism|vandalism]]',
			text = '${INTROFRAGMENT} due to [[Wikipedia:Vandalism|vandalism]].',
				local ret = ''
				if protectionObj.level == 'sysop' then
					ret = ret .. "This protection is '''not''' an endorsement of the"
						.. ' ${CURRENTVERSION}. '
				end
				return ret .. '${EXPLANATIONBLURB}'
			end,
			tooltip = '${TOOLTIPFRAGMENT} due to vandalism',
	move = {
		dispute = {
			description = 'For pages protected against page moves due to'
				.. ' disputes over the page title',
			image = 'Move-protection-shackle.svg'
		vandalism = {
				.. ' [[Wikipedia:Vandalism#Page-move vandalism'
				.. ' |page-move vandalism]]'
	autoreview = {},
	upload = {}
--                            GENERAL DATA TABLES
-- Protection blurbs
-- This table produces the protection blurbs available with the
-- ${PROTECTIONBLURB} parameter. It is sorted by protection action and
-- protection level, and is checked by the module in the following order:
-- 1. page's protection action, page's protection level
-- 2. page's protection action, default protection level
-- 3. "edit" protection action, default protection level
-- It is possible to use banner parameters inside this table.
protectionBlurbs = {
	edit = {
		default = 'This ${PAGETYPE} is currently [[Help:Protection|'
			.. 'protected]] from editing',
		autoconfirmed = 'Editing of this ${PAGETYPE} by [[Wikipedia:User access'
			.. ' levels#New users|new]] or [[Wikipedia:User access levels#Unregistered'
			.. ' users|unregistered]] users is currently [[Help:Protection|disabled]]',
		extendedconfirmed = 'This ${PAGETYPE} is currently under extended confirmed protection',
	move = {
		default = 'This ${PAGETYPE} is currently [[Help:Protection|protected]]'
			.. ' from [[Help:Moving a page|page moves]]'
	autoreview = {
		default = 'All edits made to this ${PAGETYPE} by'
			.. ' [[Wikipedia:User access levels#New users|new]] or'
			.. ' [[Wikipedia:User access levels#Unregistered users|unregistered]]'
			.. ' users are currently'
			.. ' [[Wikipedia:Pending changes|subject to review]]'
	upload = {
		default = 'Uploading new versions of this ${PAGETYPE} is currently disabled'
-- Explanation blurbs
-- This table produces the explanation blurbs available with the
-- ${EXPLANATIONBLURB} parameter. It is sorted by protection action,
-- protection level, and whether the page is a talk page or not. If the page is
-- a talk page it will have a talk key of "talk"; otherwise it will have a talk
-- key of "subject". The table is checked in the following order:
-- 1. page's protection action, page's protection level, page's talk key
-- 2. page's protection action, page's protection level, default talk key
-- 3. page's protection action, default protection level, page's talk key
-- 4. page's protection action, default protection level, default talk key
explanationBlurbs = {
	edit = {
		autoconfirmed = {
			subject = 'See the [[Wikipedia:Protection policy|'
				.. 'protection policy]] and ${PROTECTIONLOG} for more details. If you'
				.. ' cannot edit this ${PAGETYPE} and you wish to make a change, you can'
				.. ' ${EDITREQUEST}, discuss changes on the ${TALKPAGE},'
				.. '|request unprotection]], [[Special:Userlogin|log in]], or'
				.. ' [[Special:UserLogin/signup|create an account]].',
			default = 'See the [[Wikipedia:Protection policy|'
		extendedconfirmed = {
			default = 'Extended confirmed protection prevents edits from all unregistered editors'
				.. ' and registered users with fewer than 30 days tenure and 500 edits.'
				.. ' The [[Wikipedia:Protection policy#extended|policy on community use]]'
				.. ' specifies that extended confirmed protection can be applied to combat'
				.. ' disruption, if semi-protection has proven to be ineffective.'
				.. ' Extended confirmed protection may also be applied to enforce'
				.. ' [[Wikipedia:Arbitration Committee|arbitration sanctions]].'
				.. ' Please discuss any changes on the ${TALKPAGE}; you may'
				.. ' ${EDITREQUEST} to ask for uncontroversial changes supported by'
				.. ' [[Wikipedia:Consensus|consensus]].'
		default = {
				.. 'protection policy]] and ${PROTECTIONLOG} for more details.'
				.. ' Please discuss any changes on the ${TALKPAGE}; you'
				.. ' may ${EDITREQUEST} to ask an'
				.. ' [[Wikipedia:Administrators|administrator]] to make an edit if it'
				.. ' is [[Help:Minor edit#When to mark an edit as a minor edit'
				.. '|uncontroversial]] or supported by [[Wikipedia:Consensus'
				.. '|consensus]]. You may also [[Wikipedia:Requests for'
				.. ' page protection#Current requests for reduction in protection level'
				.. '|request]] that this page be unprotected.',
				.. ' You may [[Wikipedia:Requests for page'
				.. ' protection#Current requests for edits to a protected page|request an'
				.. ' edit]] to this page, or [[Wikipedia:Requests for'
				.. '|ask]] for it to be unprotected.'
	move = {
		default = {
				.. ' The page may still be edited but cannot be moved'
				.. ' until unprotected. Please discuss any suggested moves on the'
				.. ' ${TALKPAGE} or at [[Wikipedia:Requested moves]]. You can also'
				.. ' unprotected.',
				.. ' until unprotected. Please discuss any suggested moves at'
				.. ' [[Wikipedia:Requested moves]]. You can also'
				.. ' unprotected.'
	autoreview = {
		default = {
				.. ' Edits to this ${PAGETYPE} by new and unregistered users'
				.. ' will not be visible to readers until they are accepted by'
				.. ' a reviewer. To avoid the need for your edits to be'
				.. ' reviewed, you may'
	upload = {
		default = {
				.. ' The page may still be edited but new versions of the file'
				.. ' cannot be uploaded until it is unprotected. You can'
				.. ' request that a new version be uploaded by using a'
				.. ' [[Wikipedia:Edit requests|protected edit request]], or you'
				.. ' can  [[Wikipedia:Requests for page protection|request]]'
				.. ' that the file be unprotected.'
-- Protection levels
-- This table provides the data for the ${PROTECTIONLEVEL} parameter, which
-- produces a short label for different protection levels. It is sorted by
-- protection action and protection level, and is checked in the following
-- order:
protectionLevels = {
	edit = {
		default = 'protected',
		templateeditor = 'template-protected',
		extendedconfirmed = 'extended-confirmed-protected',
		autoconfirmed = 'semi-protected',
	move = {
		default = 'move-protected'
	autoreview = {
	upload = {
		default = 'upload-protected'
-- Images
-- This table lists different padlock images for each protection action and
-- protection level. It is used if an image is not specified in any of the
-- banner data tables, and if the page does not satisfy the conditions for using
-- the ['image-filename-indef'] image. It is checked in the following order:
images = {
	edit = {
		default = 'Full-protection-shackle.svg',
		templateeditor = 'Template-protection-shackle.svg',
		extendedconfirmed = 'Extended-protection-shackle.svg',
		autoconfirmed = 'Semi-protection-shackle.svg'
	move = {
		default = 'Move-protection-shackle.svg',
	autoreview = {
		default = 'Pending-protection-shackle.svg'
	upload = {
		default = 'Upload-protection-shackle.svg'
-- Pages with a reason specified in this table will show the special "indef"
-- padlock, defined in the 'image-filename-indef' message, if no expiry is set.
indefImageReasons = {
	template = true
-- Image links
-- This table provides the data for the ${IMAGELINK} parameter, which gets
-- the image link for small padlock icons based on the page's protection action
-- and protection level. It is checked in the following order:
imageLinks = {
	edit = {
		default = 'Wikipedia:Protection policy#full',
		templateeditor = 'Wikipedia:Protection policy#template',
		extendedconfirmed = 'Wikipedia:Protection policy#extended',
		autoconfirmed = 'Wikipedia:Protection policy#semi'
	move = {
		default = 'Wikipedia:Protection policy#move'
	autoreview = {
		default = 'Wikipedia:Protection policy#pending'
	upload = {
		default = 'Wikipedia:Protection policy#upload'
-- Padlock indicator names
-- This table provides the "name" attribute for the <indicator> extension tag
-- with which small padlock icons are generated. All indicator tags on a page
-- are displayed in alphabetical order based on this attribute, and with
-- indicator tags with duplicate names, the last tag on the page wins.
-- The attribute is chosen based on the protection action; table keys must be a
-- protection action name or the string "default".
padlockIndicatorNames = {
	autoreview = 'pp-autoreview',
	default = 'pp-default'
-- Protection categories
-- The protection categories are stored in the protectionCategories table.
-- Keys to this table are made up of the following strings:
-- 1. the expiry date
-- 2. the namespace
-- 3. the protection reason (e.g. "dispute" or "vandalism")
-- 4. the protection level (e.g. "sysop" or "autoconfirmed")
-- 5. the action (e.g. "edit" or "move")
-- When the module looks up a category in the table, first it will will check to
-- see a key exists that corresponds to all five parameters. For example, a
-- user page semi-protected from vandalism for two weeks would have the key
-- "temp-user-vandalism-autoconfirmed-edit". If no match is found, the module
-- changes the first part of the key to "all" and checks the table again. It
-- keeps checking increasingly generic key combinations until it finds the
-- field, or until it reaches the key "all-all-all-all-all".
-- The module uses a binary matrix to determine the order in which to search.
-- This is best demonstrated by a table. In this table, the "0" values
-- represent "all", and the "1" values represent the original data (e.g.
-- "indef" or "file" or "vandalism").
--        expiry    namespace reason   level     action
-- order
-- 1      1         1         1        1         1
-- 2      0         1         1        1         1
-- 3      1         0         1        1         1
-- 4      0         0         1        1         1
-- 5      1         1         0        1         1
-- 6      0         1         0        1         1
-- 7      1         0         0        1         1
-- 8      0         0         0        1         1
-- 9      1         1         1        0         1
-- 10     0         1         1        0         1
-- 11     1         0         1        0         1
-- 12     0         0         1        0         1
-- 13     1         1         0        0         1
-- 14     0         1         0        0         1
-- 15     1         0         0        0         1
-- 16     0         0         0        0         1
-- 17     1         1         1        1         0
-- 18     0         1         1        1         0
-- 19     1         0         1        1         0
-- 20     0         0         1        1         0
-- 21     1         1         0        1         0
-- 22     0         1         0        1         0
-- 23     1         0         0        1         0
-- 24     0         0         0        1         0
-- 25     1         1         1        0         0
-- 26     0         1         1        0         0
-- 27     1         0         1        0         0
-- 28     0         0         1        0         0
-- 29     1         1         0        0         0
-- 30     0         1         0        0         0
-- 31     1         0         0        0         0
-- 32     0         0         0        0         0
-- In this scheme the action has the highest priority, as it is the last
-- to change, and the expiry has the least priority, as it changes the most.
-- The priorities of the expiry, the protection level and the action are
-- fixed, but the priorities of the reason and the namespace can be swapped
-- through the use of the cfg.bannerDataNamespaceHasPriority table.
-- If the reason specified to the template is listed in this table,
-- namespace data will take priority over reason data in the protectionCategories
-- table.
reasonsWithNamespacePriority = {
	vandalism = true,
-- The string to use as a namespace key for the protectionCategories table for each
-- namespace number.
categoryNamespaceKeys = {
	[  2] = 'user',
	[  3] = 'user',
	[  4] = 'project',
	[  6] = 'file',
	[  8] = 'mediawiki',
	[ 10] = 'template',
	[ 12] = 'project',
	[ 14] = 'category',
	[100] = 'portal',
	[828] = 'module',
protectionCategories = {
	['all|all|all|all|all']                     = 'Wikipedia fully protected pages',
	['all|all|office|all|all']                  = 'Wikipedia Office-protected pages',
	['all|all|reset|all|all']                   = 'Wikipedia Office-protected pages',
	['all|all|dmca|all|all']                    = 'Wikipedia Office-protected pages',
	['all|all|mainpage|all|all']                = 'Wikipedia fully protected main page files',
	['all|all|all|extendedconfirmed|all']       = 'Wikipedia extended-confirmed-protected pages',
	['all|all|ecp|extendedconfirmed|all']       = 'Wikipedia extended-confirmed-protected pages',
	['all|template|all|all|edit']               = 'Wikipedia fully protected templates',
	['all|all|all|autoconfirmed|edit']          = 'Wikipedia semi-protected pages',
	['indef|all|all|autoconfirmed|edit']        = 'Wikipedia indefinitely semi-protected pages',
	['all|all|blp|autoconfirmed|edit']          = 'Wikipedia indefinitely semi-protected biographies of living people',
	['temp|all|blp|autoconfirmed|edit']         = 'Wikipedia temporarily semi-protected biographies of living people',
	['all|all|dispute|autoconfirmed|edit']      = 'Wikipedia pages semi-protected due to dispute',
	['all|all|sock|autoconfirmed|edit']         = 'Wikipedia pages semi-protected from banned users',
	['all|all|vandalism|autoconfirmed|edit']    = 'Wikipedia pages semi-protected against vandalism',
	['all|category|all|autoconfirmed|edit']     = 'Wikipedia semi-protected categories',
	['all|file|all|autoconfirmed|edit']         = 'Wikipedia semi-protected files',
	['all|portal|all|autoconfirmed|edit']       = 'Wikipedia semi-protected portals',
	['all|project|all|autoconfirmed|edit']      = 'Wikipedia semi-protected project pages',
	['all|talk|all|autoconfirmed|edit']         = 'Wikipedia semi-protected talk pages',
	['all|template|all|autoconfirmed|edit']     = 'Wikipedia semi-protected templates',
	['all|user|all|autoconfirmed|edit']         = 'Wikipedia semi-protected user and user talk pages',
	['all|all|all|templateeditor|move']         = 'Wikipedia template-protected pages other than templates and modules',
	['all|all|all|templateeditor|edit']         = 'Wikipedia template-protected pages other than templates and modules',
	['all|template|all|templateeditor|edit']    = 'Wikipedia template-protected templates',
	['all|template|all|templateeditor|move']    = 'Wikipedia template-protected templates', -- move-protected templates
	['all|all|blp|sysop|edit']                  = 'Wikipedia indefinitely protected biographies of living people',
	['temp|all|blp|sysop|edit']                 = 'Wikipedia temporarily protected biographies of living people',
	['all|all|dispute|sysop|edit']              = 'Wikipedia pages protected due to dispute',
	['all|all|sock|sysop|edit']                 = 'Wikipedia pages protected from banned users',
	['all|all|vandalism|sysop|edit']            = 'Wikipedia pages protected against vandalism',
	['all|category|all|sysop|edit']             = 'Wikipedia fully protected categories',
	['all|file|all|sysop|edit']                 = 'Wikipedia fully protected files',
	['all|project|all|sysop|edit']              = 'Wikipedia fully protected project pages',
	['all|talk|all|sysop|edit']                 = 'Wikipedia fully protected talk pages',
	['all|template|all|extendedconfirmed|edit'] = 'Wikipedia extended-confirmed-protected templates',
	['all|template|all|sysop|edit']             = 'Wikipedia fully protected templates',
	['all|user|all|sysop|edit']                 = 'Wikipedia fully protected user and user talk pages',
	['all|module|all|all|edit']                 = 'Wikipedia fully protected modules',
	['all|module|all|templateeditor|edit']      = 'Wikipedia template-protected modules',
	['all|module|all|extendedconfirmed|edit']   = 'Wikipedia extended-confirmed-protected modules',
	['all|module|all|autoconfirmed|edit']       = 'Wikipedia semi-protected modules',
	['all|all|all|sysop|move']                  = 'Wikipedia move-protected pages',
	['indef|all|all|sysop|move']                = 'Wikipedia indefinitely move-protected pages',
	['all|all|dispute|sysop|move']              = 'Wikipedia pages move-protected due to dispute',
	['all|all|vandalism|sysop|move']            = 'Wikipedia pages move-protected due to vandalism',
	['all|portal|all|sysop|move']               = 'Wikipedia move-protected portals',
	['all|project|all|sysop|move']              = 'Wikipedia move-protected project pages',
	['all|talk|all|sysop|move']                 = 'Wikipedia move-protected talk pages',
	['all|template|all|sysop|move']             = 'Wikipedia move-protected templates',
	['all|user|all|sysop|move']                 = 'Wikipedia move-protected user and user talk pages',
	['all|all|all|autoconfirmed|autoreview']    = 'Wikipedia pending changes protected pages',
	['all|file|all|all|upload']                 = 'Wikipedia upload-protected files',
-- Expiry category config
-- This table configures the expiry category behaviour for each protection
-- action.
-- * If set to true, setting that action will always categorise the page if
--   an expiry parameter is not set.
-- * If set to false, setting that action will never categorise the page.
-- * If set to nil, the module will categorise the page if:
--   1) an expiry parameter is not set, and
--   2) a reason is provided, and
--   3) the specified reason is not blacklisted in the reasonsWithoutExpiryCheck
--      table.
expiryCheckActions = {
	edit = nil,
	move = false,
	autoreview = true,
	upload = false
reasonsWithoutExpiryCheck = {
	blp = true,
	template = true,
-- Pagetypes
-- This table produces the page types available with the ${PAGETYPE} parameter.
-- Keys are namespace numbers, or the string "default" for the default value.
pagetypes = {
	[0] = 'article',
	[6] = 'file',
	[10] = 'template',
	[14] = 'category',
	[828] = 'module',
	default = 'page'
-- Strings marking indefinite protection
-- This table contains values passed to the expiry parameter that mean the page
-- is protected indefinitely.
indefStrings = {
	['indef'] = true,
	['indefinite'] = true,
	['indefinitely'] = true,
	['infinite'] = true,
-- Group hierarchy
-- This table maps each group to all groups that have a superset of the original
-- group's page editing permissions.
hierarchy = {
	sysop = {},
	reviewer = {'sysop'},
	filemover = {'sysop'},
	templateeditor = {'sysop'},
	extendedconfirmed = {'sysop'},
	autoconfirmed = {'reviewer', 'filemover', 'templateeditor', 'extendedconfirmed'},
	user = {'autoconfirmed'},
	['*'] = {'user'}
-- Wrapper templates and their default arguments
-- This table contains wrapper templates used with the module, and their
-- default arguments. Templates specified in this table should contain the
-- following invocation, and no other template content:
-- {{#invoke:Protection banner|main}}
-- If other content is desired, it can be added between
-- <noinclude>...</noinclude> tags.
-- When a user calls one of these wrapper templates, they will use the
-- default arguments automatically. However, users can override any of the
-- arguments.
wrappers = {
	['Template:Pp']                         = {},
	['Template:Protection padlock']         = {},
	['Template:Pp-extended']                = {'ecp'},
	['Template:Pp-blp']                     = {'blp'},
	-- we don't need Template:Pp-create
	['Template:Pp-dispute']                 = {'dispute'},
	['Template:Pp-main-page']               = {'mainpage'},
	['Template:Pp-move']                    = {action = 'move', catonly = 'yes'},
	['Template:Pp-move-dispute']            = {'dispute', action = 'move', catonly = 'yes'},
	-- we don't need Template:Pp-move-indef
	['Template:Pp-move-vandalism']          = {'vandalism', action = 'move', catonly = 'yes'},
	['Template:Pp-office']                  = {'office'},
	['Template:Pp-office-dmca']             = {'dmca'},
	['Template:Pp-pc']                      = {action = 'autoreview', small = true},
	['Template:Pp-pc1']                     = {action = 'autoreview', small = true},
	['Template:Pp-reset']                   = {'reset'},
	['Template:Pp-semi-indef']              = {small = true},
	['Template:Pp-sock']                    = {'sock'},
	['Template:Pp-template']                = {'template', small = true},
	['Template:Pp-upload']                  = {action = 'upload'},
	['Template:Pp-usertalk']                = {'usertalk'},
	['Template:Pp-vandalism']               = {'vandalism'},
--                                 MESSAGES
msg = {
-- Intro blurb and intro fragment
-- These messages specify what is produced by the ${INTROBLURB} and
-- ${INTROFRAGMENT} parameters. If the protection is temporary they use the
-- intro-blurb-expiry or intro-fragment-expiry, and if not they use
-- intro-blurb-noexpiry or intro-fragment-noexpiry.
-- It is possible to use banner parameters in these messages.
['intro-blurb-expiry'] = '${PROTECTIONBLURB} until ${EXPIRY}.',
['intro-blurb-noexpiry'] = '${PROTECTIONBLURB}.',
['intro-fragment-expiry'] = '${PROTECTIONBLURB} until ${EXPIRY},',
['intro-fragment-noexpiry'] = '${PROTECTIONBLURB}',
-- Tooltip blurb
-- These messages specify what is produced by the ${TOOLTIPBLURB} parameter.
-- If the protection is temporary the tooltip-blurb-expiry message is used, and
-- if not the tooltip-blurb-noexpiry message is used.
['tooltip-blurb-expiry'] = 'This ${PAGETYPE} is ${PROTECTIONLEVEL} until ${EXPIRY}.',
['tooltip-blurb-noexpiry'] = 'This ${PAGETYPE} is ${PROTECTIONLEVEL}.',
['tooltip-fragment-expiry'] = 'This ${PAGETYPE} is ${PROTECTIONLEVEL} until ${EXPIRY},',
['tooltip-fragment-noexpiry'] = 'This ${PAGETYPE} is ${PROTECTIONLEVEL}',
-- Special explanation blurb
-- An explanation blurb for pages that cannot be unprotected, e.g. for pages
-- in the MediaWiki namespace.
-- It is possible to use banner parameters in this message.
['explanation-blurb-nounprotect'] = 'See the [[Wikipedia:Protection policy|'
	.. '|consensus]].',
-- Protection log display values
-- These messages determine the display values for the protection log link
-- or the pending changes log link produced by the ${PROTECTIONLOG} parameter.
['protection-log-display'] = 'protection log',
['pc-log-display'] = 'pending changes log',
-- Current version display values
-- These messages determine the display values for the page history link
-- or the move log link produced by the ${CURRENTVERSION} parameter.
['current-version-move-display'] = 'current title',
['current-version-edit-display'] = 'current version',
-- Talk page
-- This message determines the display value of the talk page link produced
-- with the ${TALKPAGE} parameter.
['talk-page-link-display'] = 'talk page',
-- Edit requests
-- This message determines the display value of the edit request link produced
-- with the ${EDITREQUEST} parameter.
['edit-request-display'] = 'submit an edit request',
-- Expiry date format
-- This is the format for the blurb expiry date. It should be valid input for
-- the first parameter of the #time parser function.
['expiry-date-format'] = 'F j, Y "at" H:i e',
-- Tracking categories
-- These messages determine which tracking categories the module outputs.
['tracking-category-incorrect'] = 'Wikipedia pages with incorrect protection templates',
['tracking-category-template'] = 'Wikipedia template-protected pages other than templates and modules',
-- Images
-- These are images that are not defined by their protection action and protection level.
['image-filename-indef'] = 'Full-protection-shackle.svg',
['image-filename-default'] = 'Transparent.gif',
-- End messages
-- End configuration
