Macintosh Classic II Memory Upgrade Guide
Replacing or upgrading RAM in your Macintosh Classic II allows System 7 to breathe and makes multitasking with applications such as Claris Works or Netscape 1.x far smoother. This guide details the correct SIMM types, installation procedure, and common pitfalls.
💾 Memory Specifications
The Classic II ships with 2 MB of RAM soldered to the logic board and provides two on‑board 30‑pin SIMM sockets for expansion.
🧮 Supported Memory Configurations
Macintosh Classic II RAM Configurations
Total RAM SIMM 1 SIMM 2 Notes
2 MB Factory base (no SIMMs)
4 MB 1 MB 1 MB Pair of identical 1 MB SIMMs
10 MB 4 MB 4 MB Maximum supported
Important Notes
  • Install SIMMs in identical pairs; the 16‑bit data bus will not boot with mismatched sizes.
  • Use 8‑chip, non‑parity modules. Two‑ or four‑chip “high‑density” SIMMs will not be detected.
  • Faster‑than‑80 ns SIMMs (e.g., 70 ns) work fine but give no speed benefit.
Macintosh Classic II logic‑board RAM locations (SIMM slots highlighted)
🛠 Required Tools
  • Long T‑15 Torx screwdriver (≥ 15 cm shaft)
  • Plastic spudger / case cracker
  • Anti‑static wrist strap
  • Compatible 30‑pin SIMM pair (1 MB or 4 MB each)
🔧 Memory‑Upgrade Procedure
  1. Shut down & discharge – Power off, unplug, wait 5 min. Clip the wrist strap to chassis ground.
  2. Open the case – Remove four Torx screws (two bottom, two recessed). Gently separate the shell with a spudger, watching CRT anode lead.
  3. Access the logic board – Pull the board straight out by the plastic handle/finger cut‑outs.
  4. Install SIMMs
    a. Note the notch orientation (toward rear of board).
    b. Insert the first SIMM at a ~45° angle, then press down until it clicks.
    c. Repeat for the second socket with the identical SIMM.
  5. Inspect – Ensure both modules are fully seated and level.
  6. Reassemble – Slide the logic board back, reconnect speaker & power leads, close the case, install screws.
  7. Verify – Boot while holding ⌘‑⌥‑P‑R to clear PRAM, then choose  > About This Macintosh. The reported “Total Memory” should match the table above.
❗ Common Issues and Troubleshooting
Issue Likely Cause Fix
Continuous beep / no video Single SIMM installed or sizes don’t match Install matched pair; reseat both modules.
Reports 6 MB or 8 MB High‑density (2‑chip) SIMMs Replace with 8‑chip modules.
Random freezes Dirty edge contacts or 100‑ns SIMMs Clean contacts with IPA; use 80‑ns or faster SIMMs.
Sad Mac Parity/ECC SIMMs present Use non‑parity modules.
📜 Additional Resources
