Macintosh Classic II Memory Upgrade Guide
Replacing or upgrading RAM in your Macintosh Classic II allows System 7 to breathe and makes multitasking with applications such as Claris Works or Netscape 1.x far smoother. This guide details the correct SIMM types, installation procedure, and common pitfalls.
Memory Specifications
The Classic II ships with 2 MB of RAM soldered to the logic board and provides two onâboard 30âpin SIMM sockets for expansion.
| ⢠Standard configuration: 2 MB onboard |
| ⢠SIMM sockets: 2 â 30âpin, 80 ns or faster |
| ⢠Supported SIMM sizes: 1 MB or 4 MB only (SIMMs must match) |
| ⢠Memory bus: 16âbit (SIMMs installed in pairs) |
| ⢠Maximum RAM: 10 MB (2 MB onboard + 2 â 4 MB) |
Supported Memory Configurations
| Total RAM | SIMM 1 | SIMM 2 | Notes |
| 2 MB | â | â | Factory base (no SIMMs) |
| 4 MB | 1 MB | 1 MB | Pair of identical 1 MB SIMMs |
| 10 MB | 4 MB | 4 MB | Maximum supported |
Important Notes
- Install SIMMs in identical pairs; the 16âbit data bus will not boot with mismatched sizes.
- Use 8âchip, nonâparity modules. Twoâ or fourâchip âhighâdensityâ SIMMs will not be detected.
- Fasterâthanâ80 ns SIMMs (e.g., 70 ns) work fine but give no speed benefit.
Required Tools
- Long Tâ15 Torx screwdriver (⼠15 cm shaft)
- Plastic spudger / case cracker
- Antiâstatic wrist strap
- Compatible 30âpin SIMM pair (1 MB or 4 MB each)
MemoryâUpgrade Procedure
- Shut down & discharge â Power off, unplug, wait 5 min. Clip the wrist strap to chassis ground.
- Open the case â Remove four Torx screws (two bottom, two recessed). Gently separate the shell with a spudger, watching CRT anode lead.
- Access the logic board â Pull the board straight out by the plastic handle/finger cutâouts.
- Install SIMMs â
- a. Note the notch orientation (toward rear of board).
- b. Insert the first SIMM at a ~45° angle, then press down until it clicks.
- c. Repeat for the second socket with the identical SIMM.
- Inspect â Ensure both modules are fully seated and level.
- Reassemble â Slide the logic board back, reconnect speaker & power leads, close the case, install screws.
- Verify â Boot while holding âââĽâPâR to clear PRAM, then choose  > About This Macintosh. The reported âTotal Memoryâ should match the table above.
Common Issues and Troubleshooting
| Issue | Likely Cause | Fix |
| Continuous beep / no video | Single SIMM installed or sizes donât match | Install matched pair; reseat both modules. |
| Reports 6 MB or 8 MB | Highâdensity (2âchip) SIMMs | Replace with 8âchip modules. |
| Random freezes | Dirty edge contacts or 100âns SIMMs | Clean contacts with IPA; use 80âns or faster SIMMs. |
| Sad Mac | Parity/ECC SIMMs present | Use nonâparity modules. |
