SD2IEC & IEC-2-SD Adapters
The SD2IEC family—and its ARM-based off-shoots usually sold as IEC-2-SD—are open-hardware adapters that let Commodore 8-bit machines read and write FAT/FAT32-formatted SD-cards through the standard IEC serial bus. Acting as a *smart* disk-drive clone they implement the most-used 1541/1571/1581 DOS commands (LOAD, SAVE, directory, block API, ↑, ←, etc.) plus a small command channel interpreter that maps files and sub-directories to disk images on the card.
Quick facts
- “Loader-ready in < 1 s” – no mechanical spin-up / head-seek delays.
- Capacity: 32 GB+ per card, thousands of ‘‘D64/D71/D81’’ images or plain PRGs.
- Speed: ≈ 45× stock 1541 with JiffyDOS fast-loader (≈ 12 kB s-1).
- Firmware upgradable from the C64 itself (`LOAD "FW.BIN",8,1` & `RUN`).
- 100 % open-source: hardware KiCad / Eagle files & AVR/ARM firmware on GitHub.
📜 History
- 2006-07 – MMC2IEC — Lars Pontoppidan prototypes an ATmega32 board that translates IEC ↔ SPI-MMC.[1]
- 2008 – sd2iec — Ingo Korb forks the code, adds FAT32, long filenames, D71/D81 and renames the firmware sd2iec.[2]
- 2010-12 – Commercial kits — Jim Brain's uIEC/SD and NKC Electronics sell through-hole DIY modules.
- 2014-15 – TFW8b v4/v5 — TheFutureWas8bit releases compact SMD units with button board & OLED.
- 2018 – IEC-2-SD (STM32) — Petter Lundsten ports the protocol to the STM32 “Blue Pill”, bringing USB mass-storage gadget mode.[3]
🛠️ Hardware architecture
| Variant | MCU | Clock | RAM | Notes |
| Classic SD2IEC | ATmega1284P | 20 MHz crystal | 16 KB | SPI→SD, UART→debug, optional OLED/I²C |
| uIEC/SD | ATmega644P | 16 MHz | 4 KB | 2× micro-SD sockets, daughter-card form factor |
| IEC-2-SD | STM32F103C8T6 | 72 MHz | 20 KB SRAM | USB-C, full-speed USB gadget (card seen as drive on PC) |
| SaRuMan-SD | ATmega1284P | 24 MHz (X-tal) | 16 KB | Sidekick64 plug-on module, exposed JTAG |
Most boards power entirely from the +5 V IEC bus (≈ 100 mA). A 3 V LDO or DC/DC step-down supplies the SD slot. Level-shifting is done by resistor networks or BSS138 FETs depending on revision.
⚙️ Firmware features
- DOS Commands: `LOAD, SAVE, OPEN, B-A (block execute), VALIDATE`, etc.
- Disk image hot-swap using buttons (NEXT / PREV) or via `OPEN 15,"CD:somedir"`.
- Long-file-name to C64 PETSCII mapping (configurable).
- GEOS support (`U0>M0`) and native fast-loader patches for JiffyDOS, Final Cartridge III, Epyx FastLoad, SJLoad, etc.
- Config file `sd2iec.cfg` – set default device #, Jiffy mode, drive # mapping, LED polarity.
- IEC passthrough so real 1541s can daisy-chain behind the adapter.
Known limitations
- No true 6502-cycle-exact 1541 CPU emulation ⇒ copy-protected titles that rely on drive-side code or nibble-level flux patterns fail.
- Relative files not supported.
- Burst-mode fast-loaders designed for the 1571/1581 may require a parallel-IEC mod or fail altogether.
- Command channel buffers are 254 bytes – very long `@` commands can overflow.
🚀 Fast-loader compatibility matrix
| Loader | Stock C64 | JiffyDOS | SD2IEC (AVR) | IEC-2-SD (STM32) |
| JiffyDOS (KERNAL) | ✗ | ✔ | ✔ 45× | ✔ 45× |
| Epyx FastLoad (cart) | ✔ 5× | ✔ 5× | ✔ 30× | ✔ 35× |
| Final Cartridge III | ✔ 6× | ✗ | ✔ 32× | ✔ 34× |
| Dolphin DOS | ✗ | ✗ | — | — |
| Fast Load V5 PAL | ✔ | ✔ | ⚠ (needs ``OPEN15,"UX"` patch) | ✔ |
🔌 Using SD2IEC
<plainlist>
- Device number – shipped as *8*; change with `OPEN15,8,15,"U0>"+CHR$(10+new#):CLOSE15`.
- Browse directories – `LOAD"$",8` or use FB64 file-browser PRG on the card root.
- Mount D64 image – `OPEN1,8,15,"CD:DEMOS/DISK1.D64":CLOSE1`.
- Swap image – front buttons (NEXT/PREV) or `OPEN15,"XS:next":CLOSE15`.
- Firmware update – copy `firmware.bin` to card root → reset while holding “NEXT”.
</plainlist>
🆚 Pi1541 / 1541 Ultimate
| Feature | SD2IEC / IEC-2-SD | Pi1541 | 1541 Ultimate-II+ |
| MCU / SoC | 8-bit AVR / STM32 | Raspberry Pi (ARM) | FPGA (Cyclone III) |
| Cycle-exact 6502 emulation | ✗ | ✔ | ✔ |
| Copy-protected G64 / TAP | ✗ | ✔ | ✔ |
| Price (2024) | US$25-60 | US$60-90 | US$200+ |
| Plug-and-play (no Pi setup) | ✔ | ⚠ SD card image & config needed | ✔ |
| Real-time clock, Ethernet, RAM-expansion | ✗ | ✗ | ✔ |
🛒 Popular ready-made units
| Brand / Model | Notes | Approx. price (2024) |
| TheFutureWas8bit SD2IEC v5B | OLED, 3 buttons, IEC thru, 3-D printed shell | £34 GB |
| Retro-Port uIEC/SD | Daughter-card w. 6-pin header, fits internal C64 installs | US$44 |
| Pi1541 Zero (not SD2IEC) | Cycle-exact but needs Pi Zero – see separate page | €49 |
| IEC-2-SD “BluePill edition” | STM32, USB-C, optional OLED, DIY kit | €29 kit / €45 built |
🔧 DIY resources
- PCB & schematic: <https://github.com/IngmarK/sd2iec-hardware>
- Firmware source: <https://github.com/sd2iec/sd2iec>
- IEC-2-SD repo: <https://github.com/plundstr/IEC-2-SD>
- Forum support: Lemon64 “sd2iec user thread”, retro-computing Stack Exchange tag ‘‘sd2iec’’.
📚 See also
📝 References
🌐 External links
- Official sd2iec wiki – documentation, binaries, parts list.
- The Future Was 8-bit – commercial SD2IEC hardware.
- Retroleum blog – tutorial “Compiling sd2iec on macOS”.
