A first-generation Master System has only seven large custom ICs; with a meter, logic probe and a flash cartridge you can diagnose > 90 % of โdeadโ units at the component level. This page gives a structured workflow, pin-by-pin test tables and known failure modes.
- Isolated bench 9 V DC, 1 A supply with current-limit.
- DMM (200 mV, diode, continuity).
- Logic probe or 20 MHz oscilloscope.
- ESR-meter (for bulk 220 ยตF & 470 ยตF caps).
- Solder station, hot air, flux & braid.
- Diagnostic flash cart (EverDrive SMS, SD-Card GG PRO, or homemade 27C256 โTest ROMโ).
- Service manual PDF & board-schematic (link on Sega Master System Service Manual (1986)).
๐บ๏ธ Quick Board Orientation
| Custom IC |
Function |
Packages |
Common failures
| 315-5216 |
Gate-array: I/O, memory decode, banking |
100-pin QFP |
Stuck RESET, no controller read
| 315-5124 / -5246 |
VDP (Video Display Processor) + PSG audio |
40-pin DIP |
No video, single-colour screen, missing audio
| Z80A |
Main CPU @ โ3.58 MHz (NTSC) / 3.55 MHz (PAL) |
40-pin DIP |
Rare โ ESD or over-voltage
| 64 kbit ร2 DRAM |
8 KB VRAM (TMS4164, KM4164C) |
18-pin DIP ร 2 |
Garbled tiles / vertical bars
| BIOS ROM |
256โ512 KB mask ROM |
28-pin |
Blank screen until cart inserted
๐ โ Check Power & Voltages
Master System VA-x expected rails
| Test-point |
Nominal |
Notes
| DC IN header |
9โ10 V DC |
Center-pin positive
| Regulator tab (IC6 7805) |
5.00 ยฑ 0.15 V |
< 100 mV p-p ripple
| Z80 pin 11 (+5 V) |
same |
First CPU pin to probe
| VDP pin 13 (+5 V) |
same |
Loss = open LK3 or bad filter cap
- No 5 V โ blown fuse F1 (1 A), oxidised power switch, shorted electrolytic (C69 220 ยตF or C23 470 ยตF).
- 5 V low (< 4.6 V) under load โ 7805 overheating; replace with NJM7805FA or switch-mode โTRACO TSR 1-2450โ.
- 5 V high (> 5.3 V) = 7805 short to Vin โ power off immediately to save the VDP and RAM.
- Current draw > 700 mA at boot usually means shorted 315-5124 or reverse-polarity plug.
โฏ โ Reset & Clock
- Reset โ Z80 pin 26
- Should sit low for ~30 ms on power-up, then high (5 V). Permanently low โ bad 315-5216, C38 (10 ยตF) or R44 (10 kฮฉ).
- CPU clock โ pin 6
- NTSC board โ 3.579545 MHz (10.738635 MHz crystal รท 3). PAL โ 3.546894 MHz. Absent clock = open XTAL, cracked Y1 solder or dead VDP.
| Signal (CPU) |
Pin |
Probe result |
Meaning
| /MREQ |
19 |
0 โ 5 V activity |
CPU fetching ROM/RAM
| /IORQ |
20 |
Pulses every ~64 ยตs |
VBlank interrupt routine running
| /HALT |
18 |
HIGH |
OK โ low means CPU halted (bad RAM/ROM)
If clock and reset are good yet all address/data lines are static โ CPU dead or no memory decode (/MREQ stuck) โ swap 315-5216.
๐ฅ๏ธ โ Video Path Diagnosis
Symptom 1: Solid black (or blue) screen, no audio
- Confirm composite at JP3 pad โ if composite has sync but TV shows โno-signalโ your encoder (Sony CXA1145 / MC1377) may be dead.
- No sync at all โ VDP not running (check pins 35 HSync, 36 VSync โ 5 kHz / 60 Hz).
- If HSync toggles but picture is garbage โ VRAM or address-bus failure (see below).
Symptom 2: Garbled tiles / vertical coloured bars
| Pattern |
Probable part |
Action
| Thin 8-pixel vertical stripes repeating |
One 4164 DRAM data bit |
Piggy-back good 4164; replace socket
| Checkerboard, stable colour |
VDP VRAM address latch inside 315-5124 |
Swap VDP
| Random characters, flicker when warm |
Oxidised cartridge slot A18โA20 |
Clean with DeoxIT D5
Dead test ROMs (SMS Power โHardware Testโ) run from flash-cart and exercise VRAM; failures are printed on-screen.
Symptom 3: Jailbars / โjailhouseโ video noise
- Common on VA3โVA6 due to 5 V ripple on VDP analog pins.
- Replace C23 470 ยตF and C9 100 ยตF; add 10 ยตF tant on VDP pin 1 (analog 5 V).
- Re-flow RF-box ground posts โ cracked solder injects hum into composite.
๐ โ Audio Faults
PSG (SN76489-compatible inside VDP)
| Issue |
Check |
Likely cause
| No sound, video OK |
Pin 7 (YM PSG out) silence |
LM358 amp bad (IC11) or broken C68 1 ยตF
| Constant buzz, volume w/ screen brightness |
Ground loop inside RF modulator |
Bypass RF box, install direct-AV board
| Only one channel, clipping |
C27/C28 10 ยตF coupling caps open |
Replace caps, 105 ยฐC type
Note: FM expansion board (Japan only) mixes at JP1; if jumpers removed audio will mute.
๐ฎ โ Controller / Pause / Reset Failures
- Both pads dead โ 5 V missing on pin 5 of both ports (fuse F2 500 mA open).
- One direction stuck โ shorted 74HC157 (IC4, some VA boards) or cracked trace under port socket.
- PAUSE button dead but Reset works โ defective tactile switch or broken via between SW1 and 315-5216 pin 71 (/NMI).
๐ โ Cartridge & Card Slots
- โInsert cartridgeโ BIOS loop
- /CS pin (edge B1) must pulse low when address โฅ $0000. Check for 0 ฮฉ resistors R31โR34 (buffer to 315-5216).
- Clean cart edge with IPA; if still no read, RAM /CE may be stuck pulling bus โ lift pin 20 on each 4164 to isolate.
- My Card slot issues โ Slot wiring is โstraight-throughโ to cart bus; most failures are oxidised leaf contacts. Same troubleshooting as cartridge.
โ Full Memory-Map Check
SMS physical address map (with BIOS enabled)
| Range |
Size |
Device |
Notes / entry points
| $0000โ$03FF |
1 KB |
BIOS vector table |
RESET $0000, NMI $0066
| $0400โ$1FFF |
7 KB |
BIOS code & logo |
Calls CART start at $0150
| $2000โ$3FFF |
8 KB |
BIOS (bank 2) |
Game Gear mode stub
| $4000โ$BFFF |
32 KB |
Cartridge bank 0 |
Mapped when BIOS disabled
| $C000โ$DFFF |
8 KB |
Work-RAM (1 ร 8 KB) |
IC3 GM76C28
| $E000โ$FFFF |
8 KB mirror |
Mirror of $C000 |
Stack defaults here
If writes to $C000 do not read back โ RAM bad. If writes to $4000 echo on bus โ 315-5216 decode fail.
๐ง Diagnostic ROM & Loopback
Download โSMS Hardware Testโ from SMS Power; flash to EPROM/flash-cart.
- Tests Z80 RAM, VRAM, VDP registers, PSG tones, controller ports (loopback jig uses DB-9 diodes).
๐ฅ Thermal & Aging Issues
- 7805 runs at โ80 ยฐC in stock RF cage โ install bolt-on heatsink or drop-in DC-DC module to reduce heat.
- Early VA0 boards use NEC uPC7805 with high dropout; replace proactively.
- Replace all 85 ยฐC caps near heat sources: C23, C69, C27/28.
๐๏ธ Revision-Specific Errata
| PCB rev |
Distinguishing marks |
Known quirks / bugs |
Fix
| VA-0 |
Green mask, discrete 74LS logic |
RGB level too high (1.2 Vp-p) |
Add 75 ฮฉ series R per colour
| VA-2 (NTSC) |
315-5124 DP VDP |
Jailbars common |
Recap + ground braid under VDP
| VA-3/VA-4 |
315-5246 VDP |
Poor RF audio balance |
Re-tune T4 pot or bypass RF
| VA-6 PAL-I |
315-5363 encoder |
Composite overly dark |
Change R46 from 75 ฮฉ โ 47 ฮฉ
๐น๏ธ Common Fix-at-a-Glance
| Symptom |
Most likely fix
| Dead, no LED |
Replace fuse F1 & 7805
| LED on, black screen |
Verify clock; swap VDP; check /RESET
| Vertical stripes |
Replace bad 4164 DRAM (U8/U9)
| Game boots but resets randomly |
Replace C38 10 ยตF reset cap; clean cart slot
| No sound |
Replace C68 1 ยตF & LM358; check VDP pin 7
| Controllers not detected |
Re-flow JP1, replace 74HC157
๐ Conclusion
The original Master System is one of the most repair-friendly 8-bit consoles: every IC but the VDP is still obtainable, and almost every fault traces to power, RAM or slot corrosion. Follow the signal path โ 5 V โ Reset โ Clock โ /CS โ and you will pinpoint the failure.
