Sega CD (Model 2)
| U.S. NTSC Sega CD (Model 2) side-mounted beneath a Genesis 2 | |
| Manufacturer | Sega Enterprises Ltd. |
| Type | CD-ROM add-on console |
| Released | April 23, 1993 (JP Mega-CD 2) November 1, 1993 (US Sega CD 2) |
| Discontinued | 1996 (replaced by licensed JVC WonderMega 2 & CD X) |
| Intro price | JP ยฅ29 800 โข US US$229 โข EU ยฃ230 |
| CPU | Motorola MC68EC000 @ 12.500 MHz (main) Sony CXD1802Q custom gate-array (CD-DSP) โ |
| Memory | 512 KB Program RAM 768 KB dual-ported Word-RAM 128 KB PCM Sample RAM 64 KB Battery-backed Save RAM |
| Storage | 1ร 1 ร-speed top-loading CD-ROM (150 kB sโปยน) cartridge passthrough up to 4 MB |
| Display | 256 / 320 ร 224 px (NTSC) โข 52-colour line-scroll โข 80 sprites |
| Sound | Genesis YM3438 FM & PSG plus Ricoh RF5C164 8-ch PCM @ 32 kHz 10-bit DAC |
| Dimensions | 252 mm W ร 215 mm D ร 63 mm H |
| Weight | โ 1.3 kg |
| OS / Firmware | Mega-CD System BIOS v2.x (128 KB mask ROM) |
| Predecessor | Sega CD (Model 1) |
| Successor | Sega CDX / JVC Wondermega |
| Codename | โข MARS-CD-B (JP R&D) โข โTop-loaderโ |
| Model no. | HAA-2950 (JP) โข MK-4102 (US) โข MK-4102-50 (EU) |
The Sega CD Model 2 โ known in Japan and PAL regions as the Mega-CD 2 โ is the second-generation optical add-on for the Sega Genesis/Mega Drive. Launched April 1993 in Japan and late-1993 overseas, it re-engineers the bulky front-loading Model 1 into a smaller, top-loading deck that bolts to the right-hand side of a Model-2 Genesis (or underneath a Model-1 via spacer plate). The redesign slashes build cost by integrating disc-logic, FM synth mix, and RF modulator into two new ASICs and by replacing the complex motorised tray with a spring-latched lid.
๐ Historical Context & Sales
- Segaโs first CD drive โ the Model 1 โfront-loaderโ (HAA-2910) โ cost US$299 and carried a high RMA rate (optical alignment, belt stretch).
- Cost-reduction taskforce (โMCD-R2โ) produced a simplified mechanism using Sonyโs ubiquitous KSS-210A pickup and a plastic clam-shell housing.
- Debuted 23 April 1993 bundled with Sonic CD in Japan; U.S. release November 1993 bundled with Sewer Shark.
- Combined Model-1/2 worldwide sales โ 2.24 million units โ ~70 % are Model 2 according to 1995 Sega annual report.
๐ง Hardware Architecture
| Part | Function(s) |
| MC68EC000 (64-pin) | Primary 16-bit CPU @ 12.5 MHz |
| 315-5880 โMCD ASIC 2โ | Sub-CPU bus arbiter โข Word-RAM controller โข rotation / scaling / 3ร3 matrix |
| 315-5788 | OKI MSM6295-compatible DMA + CD-SUB code ROM |
| Ricoh RF5C164 | 8-channel PCM generator, 10-bit DAC |
| CXD2510Q | CD-DSP / decoder โ replaces discrete CN-303 & CXP controllers in Model 1 |
| 315-5684-B | RGB DAC + stereo mixer (shares with Genesis 2) |
Internally, software sees identical registers to Model 1; all games and dev tools remain compatible.
Clock Scheme (NTSC)
- Master XTAL = 12.500 MHz ร 4 = 50.000 MHz โ รท4 = 12.5 MHz (68k)
- Z80 (in Genesis) still sourced from 53.693 MHz รท15 โ 3.58 MHz
- Word-RAM dual-ported clock = 25 MHz.
Memory Map (MC68EC000)
| Range | Size | Device |
| $0000 00โ$0FFF FF | 1 MB | Program RAM |
| $0200 00โ$03FF FF | 2 MB | Word-RAM (dual-bank 0/1) |
| $0400 00โ$05FF FF | 2 MB | PRG-RAM mirror / save RAM (battery) |
| $0600 00โ$07FF FF | 2 MB | PCM sample RAM mirror |
| $0800 00โ$0BFF FF | 4 MB | BIOS ROM (128 KB mirrored) |
| $0C00 00โ$0DFF FF | 2 MB | CD-DSP & sub-CPU registers |
| $0E00 00โ$0E00 FF | 256 B | Gate array I/O (gate, LEDs, reset) |
๐ Differences vs. Model 1
| Area | Model 1 (1991) | Model 2 (1993) | Result |
| Drive mech | Sony KSS-240A sled + worm gear front-tray | Sony KSS-210A fixed sled, top-lid | 40 % cheaper, quieter |
| Optical control | CXP921P + CXD1095Q (DSP) | CXD2510Q SoC | Fewer PCB layers |
| Audio mixing | External op-amps, RCA output | Mixed inside 315-5684-B, no RCA | Shares Genesis 2 mini-DIN |
| Power rails | 9 V in โ 5 V, โ5 V, +12 V regulators | โ5 V rail deleted (unused) | One less 7905 IC |
| Word-RAM width | 2 ร 16-bit SRAM (dual bus) | Same, but SRAMs integrated in ASIC later VA1 | Slightly lower latency |
๐ External Connectors
- Expansion edge โ identical 64-pin BUS as Model 1; ships with 10 cm ribbon โmixingโ cable to the Genesis 2 A/V port (carries left/right audio).
- AC Adaptor โ same barrel 2.1 mm as Genesis 2 (centre positive).
- EXT Link โ 9-pin mini-DIN to daisy-chain two Mega-CDs for dev use (never utilised by retail titles).
๐ Motherboard Revisions
| Rev | Key ICs | Notes |
| VA0 | 315-5880, CXD2510Q, discrete SDRAM | Japan launch โ green soldermask |
| VA1 | 315-5933 โASIC 3โ (RAM+gate array in one) | Most common US/EU; no Word-RAM wait glitches |
| VA2 (Majesco) | GOAC single-chip + Mitsubishi drive board | Pack-in with late Genesis 3; cost-reduced |
All revisions are cross-compatible; BIOS ROM changes (v2.00โv2.11) fix Lunar Eternal Blue save bug and 32X pass-through timing.
๐ Audio Path
1. RF5C164 PCM โ 315-5880 bus โ 2. ASIC mixer combines FM+PSG from Genesis via ribbon audio BUS โ 3. 315-5684-B internal op-amp โ mini-DIN 9 (pins 2/4) / RCA L+R (PAL only). Because mixing is line-level only, Model 2 inherits Genesis 2โs famous โquietโ output (~300 mVpp). Mods: VMU Audio Amp or โSega CD Audio Boostโ board (TL072).
๐ ๏ธ Maintenance
- Pickup lens โ KSS-210A rarely fails; clean with 91 % IPA swab.
- Spindle hub โ plastic hub cracks; 3-D-print โclamp hub saverโ or cannibalise PC CD-ROM.
- Lid switch โ dual leaf SW1; adjust if unit reports โPlease Close Coverโ error.
- Belt โ Model 2 has *no belt*, only a direct-drive spindle.
- Capacitors โ far fewer SMD cans: primarily C224 220 ยตF (5 V rail) and audio coupling 47 ยตF (C138, C139). See Sega CD (Model 2) Capacitor Replacement Guide.
๐ Common Faults & Fixes
| Symptom | Diagnosis | Remedy |
| โChecking discโ endless | Spindle hub height / dirty lens | Clean lens; shim hub 0.2 mm |
| No PCM channels | RF5C164 pin-rot on VA0 | Re-flow QFP; recap C139/C140 |
| BIOS boots, drive dead | 5 V present, 9 V missing at CN3 | Replace poly-fuse PF1 or AC adaptor |
| 32X hangs on Sega CD | ASIC revision < v2.11 | Burn patch cart with โ32X-SCD fixโ |
๐ง Popular Mods
- RGB Bypass via Triple-Bypass board (VDP โ THS7374 โ DIN 9).
- Region Free BIOS โ swap 27C1001 EPROM with patched Mega CD Multi-BIOS v2.8.
- Non-destructive Switchless โ PIC16F630 toggles JP1/JP2 for 50/60 Hz & J/U/E.
- S-Video + Stereo Jack โ tap Y/C from CXD2510Q and RF5C164 out.
๐ Technical Documentation
- *Mega-CD 2 Service Manual* (Sega doc 400-6408-01) โ full schematics & test points.
- Yasushi Yamaguchi, โSega CD ASIC Architectureโ โ Nikkei 1994 conference slides.
- US Patent 5 471 206 โ โHome-use CDROM system with rotation & scale processingโ.
๐๏ธ Trivia & Pop-Culture
- Segaโs marketing touted Model 2 as โ2 ยฝ times fasterโ to load due to firmware tweaks, though the drive itself is identical 1 ร speed.
- Film prop in Hackers (1995) โ Acid Burnโs bedroom shows a Mega-CD 2 + Genesis 2 stack.
- The JP manual warns: โDo not place cup noodles on top lid while operating.โ
๐ See Also
- Sega CD Model 1 โ original front-loader
- Sega Genesis (Model 2) โ matching base console
- Sega 32X โ 32-bit attachment (Model 2 compatible)
