Atari 400 Troubleshooting Guide
This guide provides detailed, step-by-step troubleshooting for the Atari 400 home computer. It covers common startup failures, video and audio faults, keyboard issues, and memory/logic problems. Component-level checks and proven repair strategies are outlined for both NTSC and PAL models.
๐ Preliminary & Power-up Checks
Begin by confirming the power supply and system voltages before suspecting mainboard faults.
Power Checks
- Verify the external PSU outputs +5 V DC (4.85โ5.15 V) under load.
- Inspect the power jack and internal fuse for corrosion or breakage.
- Confirm the power switch moves freely and makes firm contact.
| Test Point | Expected Voltage | Notes |
| Mainboard edge connector (pin 1 = +5 V, pin 2 = GND) | +5 V DC | Primary logic rail |
| Cartridge slot pin 12 (+5 V) | +5 V DC | Cartridge power |
| CPU (6502) pin 8 (Vcc) | +5 V DC | Core supply |
| RESET line (CPU pin 40) | Low โ High | Should pulse low at power-on, then rise to 5 V |
Visual Inspection
- Remove the top cover; check for burnt components, loose wires, or corrosionโespecially near the power input and voltage regulator.
- Inspect for bulging/leaking capacitors and reflow any suspect solder joints.
๐ฅ๏ธ Display & Chime Diagnostics
The Atari 400 should display a solid blue screen (NTSC) or light blue (PAL) with the built-in Memo Pad prompt if no cartridge is inserted.
| No video, no sound | No power, blown fuse, or dead voltage regulator | Check PSU, replace fuse, test/replace 7805 regulator |
| Black screen, no border | CPU, ANTIC, or RAM failure | See memory/logic section; swap ICs if socketed |
| Solid colour screen, no prompt | OS ROM or address decoding fault | Reseat/replace OS ROM; check logic chips |
| Rolling, distorted, or B&W video | Bad modulator, wrong TV channel, or faulty GTIA/CTIA | Test on composite output; swap GTIA/CTIA if possible |
| Intermittent video loss | Loose RF cable, cracked solder at modulator | Resolder or replace modulator |
Audio (Power-on Chime)
- The Atari 400 does not produce a startup chime.
- If you hear static or noise from the TV speaker, the audio circuit is at least partially alive.
๐พ Memory & ROM Faults
The Atari 400 uses up to 16 KB RAM (typically 8 ร 4116 DRAMs) and a socketed OS ROM.
RAM Faults
| Black screen, no cursor | Lower RAM failure (first 8 KB) | Touch DRAMs for overheating; piggy-back or replace suspect chip |
| Garbage characters, random freezes | Upper RAM failure | Test with known-good RAM board; swap chips if socketed |
| Coloured blocks or stripes | Address bus fault or DRAM stuck bit | Check address lines; replace failed DRAM or 74LS158/74LS257 multiplexers |
ROM Faults
| Solid colour screen, no prompt | OS ROM failure | Reseat or replace OS ROM (C012296/C014377) |
| Boots with cartridge, not without | OS ROM bad, cartridge ROM OK | Replace OS ROM |
โ ๏ธ Connector & Socket Issues
- Cartridge slot: Dirty or oxidised contacts can cause boot failures or crashes. Clean with isopropyl alcohol and a soft brush.
- Keyboard connector: Ribbon cable may loosen or corrode; reseat and clean contacts.
- IC sockets: Early Atari 400s use single-wipe sockets prone to poor contact. Gently rock and reseat chips, or replace sockets if intermittent faults persist.
- Monitor/TV out: Check for bent pins or cracked solder at the modulator and mainboard.
๐ฉ Component-level Tests
Clock & Reset
- The 6502 CPU requires a stable 1.79 MHz (NTSC) or 1.77 MHz (PAL) clock from the system oscillator.
- RESET should pulse low at power-on, then return high (5 V).
- Use a logic probe or oscilloscope to confirm activity at CPU pins 37 (ฯ2) and 40 (RESET).
Chip Substitution & Piggy-back
- Power off and remove one suspect IC at a time (if socketed).
- Replace with a known-good part, observing orientation.
- For DRAM, piggy-back a good 4116 atop each suspect chip; if behaviour changes, the underlying chip is faulty.
- Never piggy-back custom Atari chips (ANTIC, GTIA/CTIA, POKEY, etc.).
Minimal Boot Configuration
- The Atari 400 will not boot without working RAM, OS ROM, ANTIC, and GTIA/CTIA.
- Remove the cartridge and all unnecessary peripherals for basic diagnostics.
๐ Audio & I/O Failures
Audio Issues
- No sound in games or Memo Pad:
* Suspect POKEY chip (C012294); swap with known-good if socketed. * Check speaker wiring and TV volume. * Inspect for cold solder joints at the modulator and audio output.
Keyboard & Joystick Problems
- No key response:
* Reseat keyboard ribbon; clean contacts. * Test with another keyboard if available. * Inspect for broken traces on the keyboard PCB.
- Joystick not detected:
* Clean joystick port; check for broken solder joints. * Faulty POKEY or 4050 buffer IC may cause input failures.
๐ฅ Cartridge & Peripheral Issues
- System boots with Memo Pad but not with cartridge:
* Clean cartridge contacts; test with another cartridge. * Inspect cartridge slot for bent pins. * If all cartridges fail, suspect address decoding logic (74LS138/74LS42) or cartridge power rail.
๐ Error & Code Tables
The Atari 400 does not display error codes or beep patterns. For advanced diagnostics, use a test cartridge (e.g., Atari Diagnostic or SALT) if available.
