Atari 400 Capacitor Replacement Guide
Revision as of 21:21, 9 August 2025 by Josh (talk | contribs)
Recapping your Atari 400 is a crucial preventative step to ensure reliable operation, stable power delivery, and crisp video output. The original aluminium electrolytic capacitors in the Atari 400 are now over four decades old—well past their intended service life. Ageing capacitors can cause power instability, random crashes, distorted audio, and display artefacts. Proactive replacement restores system health and helps prevent catastrophic failures.
Before beginning, examine each capacitor for classic signs of failure:
  • Bulging or domed tops – Indicates internal gas pressure and imminent failure.
  • Leaking electrolyte – Brown, black, or green residue at the base or leads.
  • Corrosion or PCB staining – Green/white deposits or darkened board areas.
  • Intermittent resets, video glitches, or audio hum – Often traceable to dried-out or high-ESR capacitors.
If any single capacitor shows symptoms, it is best practice to replace all electrolytic capacitors on the mainboard.
Atari 400 Capacitor List
The Atari 400 uses a modest number of electrolytic capacitors, all of which are through-hole types on the mainboard and power supply board. SMD electrolytics are not present in this model.
Mainboard Electrolytic Capacitors
Atari 400 Mainboard Electrolytic Capacitors
Ref. Designator Capacitance Voltage Function / Notes
C44 2200 µF 16 V Main +5 V rail smoothing (bulk filter)
C43 470 µF 16 V +12 V rail smoothing (video/audio circuits)
C42 47 µF 16 V +5 V local decoupling (logic)
C41 10 µF 16 V +5 V local decoupling (logic)
C40 10 µF 16 V +5 V local decoupling (logic)
C39 1 µF 50 V Video output coupling
C38 1 µF 50 V Audio output coupling
Note: Some board revisions may use slightly different reference numbers—always cross-check with your silkscreen before ordering.
Internal Power Supply Board
If your Atari 400 has the original internal linear power supply (NTSC models), it contains additional electrolytic capacitors:
Atari 400 Power Supply Board Electrolytic Capacitors
C1 4700 µF 16 V Main input filter (rectified DC)
C2 1000 µF 16 V +12 V rail filter
PAL models (with external power bricks) may not have these internal capacitors. Always inspect your specific unit.
Recapping Procedure
  1. Power off and unplug the Atari 400. Wait several minutes for capacitors to discharge.
  2. Disassemble the case: remove screws from the underside, gently separate the top shell, and disconnect the keyboard membrane.
  3. Remove the mainboard and, if present, the internal power supply board.
  4. Label all connectors for easy reassembly.
  5. Desolder each capacitor using a soldering iron (350–375 °C) and wick or pump. Take care not to lift PCB pads.
  6. Clean the pads with isopropyl alcohol and inspect for damage.
  7. Install new capacitors, matching polarity (long lead = positive) and ensuring correct lead spacing.
  8. Trim excess leads, solder cleanly, and inspect for bridges or cold joints.
  9. Reassemble the unit, reconnecting all cables and the keyboard membrane.
  • Temperature-controlled soldering iron (2 mm chisel tip recommended)
  • Desoldering braid and/or spring pump
  • Leaded 63/37 or quality lead-free solder (0.5–0.7 mm)
  • Isopropyl alcohol (99%) and antistatic brush
  • Side-cutters for trimming leads
  • Multimeter (for continuity and voltage checks)
  • 105 °C, low-ESR radial electrolytic capacitors (brands: Nichicon, Panasonic, Rubycon)
  • Kapton tape (optional, for insulating capacitors near shielding)
Voltage & Ripple Check
After recapping and reassembly, verify the power rails at the mainboard edge connector or test points:
Atari 400 Power Rails (No Cartridge, BASIC READY)
+5 V (logic) 4.90 – 5.10 V < 50 mV
+12 V (video/audio) 11.5 – 12.5 V < 100 mV
  • Use an oscilloscope (20 MHz bandwidth) to check ripple if available.
  • Excessive ripple or unstable voltages may indicate a faulty power supply or incorrect capacitor installation.
Additional Tips
  • Double-check polarity before soldering—reverse installation can damage the board.
  • Use capacitors with equal or higher voltage ratings; never substitute lower-voltage parts.
  • Clean any electrolyte residue thoroughly to prevent corrosion.
  • If the video output remains noisy after recapping, check the RF modulator and its internal capacitors (if fitted).
  • Store the Atari 400 in a dry environment and power it up periodically to keep capacitors healthy.
  • Dispose of old capacitors at an approved electronics recycling centre.
