Atari 65XE Capacitor Replacement Guide
Replacing the original electrolytic capacitors (“recapping”) in your Atari 65XE is essential for long-term reliability and performance. Ageing capacitors can cause power instability, video artefacts, audio noise, or even prevent the machine from starting. Proactively replacing these components helps ensure stable operation, protects delicate custom chips, and cures many “mystery” faults common in vintage Atari 8-bit systems.
Before starting, carefully examine all electrolytic capacitors on the mainboard for:
- Bulging or domed tops – Indicates internal gas pressure and imminent failure.
- Leaking electrolyte – Brown, green, or white crust around the base or legs.
- Corroded or stained PCB areas – Suggests past leakage, especially near the power input.
- Random resets, video glitches, or audio hum – Often traceable to dried-out or high-ESR capacitors.
If any capacitor shows signs of failure, it is strongly recommended to replace all electrolytic capacitors on the board.
Atari 65XE Capacitor List
The 65XE mainboard uses a mix of through-hole and, in later revisions, some SMD electrolytic capacitors. Always cross-check your board’s silkscreen and reference numbers, as minor layout changes exist between European and US models.
Mainboard Electrolytic Capacitors
| Ref. Designator | Capacitance | Voltage | Function / Location |
| C1 | 2200 µF | 16 V | Main +5 V input filter (power smoothing) |
| C13 | 470 µF | 16 V | +5 V local decoupling (CPU/ASIC area) |
| C41 | 100 µF | 16 V | Video circuit decoupling |
| C42 | 10 µF | 16 V | Audio output coupling |
| C43 | 10 µF | 16 V | Audio input coupling (monitor port) |
| C44 | 1 µF | 50 V | Video chroma coupling (monitor port) |
| C45 | 10 µF | 16 V | Reset circuit timing |
| C46 | 10 µF | 16 V | SIO circuit decoupling |
| C47 | 10 µF | 16 V | SIO circuit decoupling |
| C48 | 10 µF | 16 V | SIO circuit decoupling |
| C49 | 10 µF | 16 V | SIO circuit decoupling |
| C50 | 10 µF | 16 V | SIO circuit decoupling |
| C51 | 10 µF | 16 V | SIO circuit decoupling |
| C52 | 10 µF | 16 V | SIO circuit decoupling |
| C53 | 10 µF | 16 V | SIO circuit decoupling |
| C54 | 10 µF | 16 V | SIO circuit decoupling |
| C55 | 10 µF | 16 V | SIO circuit decoupling |
| C56 | 10 µF | 16 V | SIO circuit decoupling |
| C57 | 10 µF | 16 V | SIO circuit decoupling |
| C58 | 10 µF | 16 V | SIO circuit decoupling |
| C59 | 10 µF | 16 V | SIO circuit decoupling |
| C60 | 10 µF | 16 V | SIO circuit decoupling |
| C61 | 10 µF | 16 V | SIO circuit decoupling |
| C62 | 10 µF | 16 V | SIO circuit decoupling |
| C63 | 10 µF | 16 V | SIO circuit decoupling |
| C64 | 10 µF | 16 V | SIO circuit decoupling |
| C65 | 10 µF | 16 V | SIO circuit decoupling |
Note: Some later 65XE boards (especially “Cost Reduced” versions) may use SMD electrolytic capacitors for some of the 10 µF positions. Replace with equivalent SMD or use carefully-fitted radial types.
Power Supply (External)
The 65XE uses an external 5 V DC power supply (“brick”). If you experience unstable voltages or excessive ripple, inspect and recap the PSU as well. Typical values:
| Capacitance | Voltage | Notes |
| 2200 µF | 16 V or 25 V | Main filter (inside PSU brick) |
Always open and service the PSU only if you are experienced with mains voltages.
- Disassemble: Remove the case screws (usually five underneath), then gently lift the top case. Disconnect the keyboard flex cable.
- Remove the mainboard: Unscrew and lift out the PCB, noting the orientation of all connectors.
- Desolder old capacitors: Use solder wick and/or a pump. Take care not to lift pads, especially on single-sided boards.
- Clean pads: Remove old flux and any leaked electrolyte using isopropyl alcohol.
- Install new capacitors: Observe polarity (long lead = positive; silkscreen usually marks negative). Use low-ESR, 105 °C rated parts.
- Trim leads and solder: Ensure solid, shiny joints. Avoid excess solder.
- Inspect: Check for solder bridges and correct orientation.
- Reassemble and reconnect: Fit the board, connect the keyboard, and close the case.
Recommended Tools & Parts
- Temperature-controlled soldering iron (15–40 W, fine tip)
- Desoldering pump and/or braid
- Isopropyl alcohol (IPA) and small brush
- Lead-free or leaded 0.5–0.7 mm solder
- ESR meter (optional, for testing old capacitors)
- Quality 105 °C, low-ESR capacitors (e.g., Nichicon, Panasonic, Rubycon)
- Tweezers (for SMD parts, if present)
- Antistatic wrist strap
Post-Recap Voltage & Ripple Checks
After recapping, verify the main voltage rails with a multimeter or oscilloscope:
| Test Point | Nominal Value | Acceptable Range | Max Ripple (p-p) |
| +5 V (mainboard input) | 5.00 V | 4.85–5.15 V | < 50 mV |
| +5 V (CPU, RAM, ANTIC) | 5.00 V | 4.85–5.15 V | < 50 mV |
| Audio out (monitor port) | – | – | No hum/buzz |
If you observe excessive ripple (>100 mV) or unstable voltages, recheck your soldering and consider recapping the external PSU.
Additional Tips
- Check the power brick first! A faulty PSU can damage new capacitors and chips.
- Keep capacitor height below 18 mm to ensure the metal shield fits.
- Double-check polarity before soldering – reversed caps may explode.
- Clean any leaked electrolyte thoroughly, as it corrodes PCB traces.
- Retain original lead spacing (usually 5 mm for 10–100 µF, 7.5–10 mm for 2200 µF).
- If SMD caps are present, use quality SMD replacements or carefully adapt radial types.
- Power up with a current-limited supply or fuse for first test after recapping.
