Osborne Vixen
Revision as of 19:12, 12 May 2025 by Josh (talk | contribs)
Osborne Vixen
Osborne Vixen portable computer
ManufacturerOsborne Computer Corporation
TypePortable Computer
ReleasedNovember 1984
Discontinued1985
Intro priceUS$1,298 (1984)
CPUZilog Z80A @ 4 MHz
Memory64 KB RAM
StorageDual 5.25" double-sided, double-density floppy drives (400 KB each)
Display7-inch monochrome CRT, 80×24 text
SoundInternal beeper
Dimensions12.5" × 16.25" × 6.75"
Weight18 lbs (8.2 kg)
OS / FirmwareCP/M 2.2
PredecessorOsborne Executive
CodenameEncore
Model no.OCC-4
The Osborne Vixen is a Z80-based portable computer introduced by Osborne Computer Corporation in late 1984 as the successor to the Osborne Executive. Designed as a compact, luggable CP/M system, the Vixen featured a larger screen, increased storage, and improved portability for business users.
At its core, the Osborne Vixen utilised the Zilog Z80A microprocessor running at 4 MHz. The Z80A was a popular 8-bit CPU for CP/M systems, offering robust performance for business and productivity applications of the era.
The system architecture included:
  • Z80A CPU @ 4 MHz
  • 64 KB DRAM (maximum addressable by CP/M)
  • Standard CP/M 2.2 BIOS and BDOS
  • ROM for boot and system diagnostics
Memory and Storage
The Vixen shipped with:
  • 64 KB RAM – the maximum supported by CP/M 2.2, used for operating system, applications, and RAM disk.
  • Dual 5.25" floppy drives – double-sided, double-density, each offering 400 KB of storage (total 800 KB).
  • Optional external 10 MB hard disk (Osborne "Hard Disk Subsystem"), connected via IEEE-488 interface.
The floppy drives supported standard CP/M disk formats, and the system could emulate a RAM disk for faster temporary storage.
Display and Graphics
The Osborne Vixen featured a:
  • 7-inch monochrome CRT display
  • 80 columns × 24 rows text mode
  • Green phosphor screen, non-graphics (text-only)
The larger screen was a significant improvement over the Osborne 1's 5-inch display, allowing full-width CP/M text editing and spreadsheet work.
Sound Capabilities
Sound on the Vixen was limited to a simple internal beeper, used for system alerts and keypress feedback. No advanced audio hardware or synthesis was provided.
Input/Output and Expansion
The Osborne Vixen included a variety of I/O ports and expansion options:
  • Parallel port (Centronics-compatible) for printers
  • Serial port (RS-232C) for modems and terminals
  • IEEE-488 port for external hard disk subsystem
  • Composite video output for external monitor connection
  • Keyboard – detachable, full-stroke, 69-key layout with numeric keypad
Expansion was limited compared to desktop CP/M systems, but the Vixen's ports allowed connection to most business peripherals of the era.
Main Logic Board & IO Schematics
Osborne Vixen Main Logic Board
Osborne Vixen IO Board
File:Vixen Schematic.pdf
The official Osborne Vixen Service Manual and full schematics are available on the Osborne Documentation category page
