Module:Shortcut/config
Revision as of 22:33, 15 May 2025 by Josh (talk | contribs) (1 revision imported: Citation Import)
Documentation for this module may be created at Module:Shortcut/config/doc
-- This module holds configuration data for [[Module:Shortcut]].
return {
-- The heading at the top of the shortcut box. It accepts the following parameter:
-- $1 - the total number of shortcuts. (required)
['shortcut-heading'] = '[[Wikipedia:Shortcut|{{PLURAL:$1|Shortcut|Shortcuts}}]]',
-- The heading when |redirect=yes is given. It accepts the following parameter:
['redirect-heading'] = '[[Wikipedia:Redirect|{{PLURAL:$1|Redirect|Redirects}}]]',
-- The error message to display when a shortcut is invalid (is not a string, or
-- is the blank string). It accepts the following parameter:
-- $1 - the number of the shortcut in the argument list. (required)
['invalid-shortcut-error'] = 'shortcut #$1 was invalid (shortcuts must be ' ..
	'strings of at least one character in length)',
-- The error message to display when no shortcuts or other displayable content
-- were specified. (required)
['no-content-error'] = 'Error: no shortcuts were specified and the ' ..
	mw.text.nowiki('|msg=') ..
	' parameter was not set.',
-- A category to add when the no-content-error message is displayed. (optional)
['no-content-error-category'] = 'Shortcut templates with missing parameters',
