Atari 1040STE
Revision as of 19:15, 12 August 2025 by Josh (talk | contribs) (Updated by RetroTechWikiBot - Generated page content)
The Atari 1040STE (ST Enhanced) is the late‑generation 68000‑based ST model with upgraded graphics, audio, memory subsystem, and I/O versus the earlier STf/STfm machines. It kept the integrated keyboard/CPU form factor and 8 MHz MC68000 while adding a 4,096‑color palette, 2‑channel DMA stereo audio with on‑board filtering and mixing, SIMM‑based RAM to 4 MB, and two side‑mounted 15‑pin enhanced joystick/analogue ports. It shipped broadly in Europe in late 1989 and reached U.S. retail on June 2, 1990. [12] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com)) [atarimuseum.info](https://www.atarimuseum.info/1040ste.htm?utm_source=chatgpt.com))
Atari 1040STE
ManufacturerAtari Corporation
TypeHome computer
ReleasedSeptember 1, 1989 (Europe); June 2, 1990 (U.S.)[1] ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm?utm_source=chatgpt.com))
Discontinued1994[2] ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm?utm_source=chatgpt.com))
Intro priceLaunch examples: DM 1,598 (West Germany, Sept. 1989); US$699 with color monitor (June 1990); typical U.S. street price fell to US$599 by Feb. 1991.[3] ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm?utm_source=chatgpt.com))
CPUMotorola MC68000 (PLCC) @ 8 MHz[4] ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?utm_source=chatgpt.com))
Memory1 MB standard; 30‑pin SIMMs, expandable to 4 MB (256 KB or 1 MB modules only; early units used SIPP).[5] ([info-coach.fr](https://info-coach.fr/atari/hardware/memory.php?utm_source=chatgpt.com))
StorageInternal 3.5" DS/DD 720 KB floppy; external floppy port; ACSI (DMA) external hard‑disk interface.[6] ([atarimagazines.com](https://www.atarimagazines.com/startv5n4/enhanced.html?utm_source=chatgpt.com)) [en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
Display320×200 (16 colors), 640×200 (4 colors), 640×400 mono; 4,096‑color palette; hardware fine scroll and split screen.[7] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
SoundYamaha YM2149 PSG (3 ch + noise) + 2‑channel 8‑bit stereo DMA PCM at 6.25/12.5/25/50 kHz; LMC1992 audio control via Microwire; stereo RCA line out.[8] ([bus-error.nokturnal.pl](https://bus-error.nokturnal.pl/atari_compendium/html/chap5.htm?utm_source=chatgpt.com)) [alive.atari.org](https://alive.atari.org/alive11/mcrowire.php?utm_source=chatgpt.com))
Dimensions475 mm × 290 mm × 70 mm (W×D×H), case same footprint as late 1040STF/M.[9] ([forums.atariage.com](https://forums.atariage.com/topic/134542-atari-520-ste-dimensions/?utm_source=chatgpt.com))
Weight≈4.0–4.7 kg (varies by PSU/drive revision).[10] ([computermuseum.wordpress.com](https://computermuseum.wordpress.com/2006/04/25/1040-stf/?utm_source=chatgpt.com)) [amibay.com](https://www.amibay.com/threads/atari-1040ste-4mb-ram-tos-1-62-german.2442186/?utm_source=chatgpt.com))
OS / FirmwareTOS 1.06 (“STE TOS”) or TOS 1.62 in 256 KB (2×128 KB) ROMs; GEM desktop.[11] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_TOS?utm_source=chatgpt.com))
PredecessorAtari 1040STFM
SuccessorAtari Mega STE
The 1040STE uses a socketed Motorola MC68000 (PLCC) clocked at 8 MHz on a 16‑bit external bus (32‑bit internal ALU/regs). Support logic is consolidated into Atari‑designed ASICs: the GST MCU (combines GLUE, MMU, joystick/paddle logic, DMA‑audio addressing, clocking) and the GST Shifter (enhanced video and audio shifting). Early STE boards feature a discrete BLiTTER; later revisions integrate the blitter into the GST MCU. [13] ([info-coach.fr](https://info-coach.fr/atari/hardware/STE-HW.php?utm_source=chatgpt.com)) [forums.atariage.com](https://forums.atariage.com/topic/263950-missing-blitter-from-ste/?utm_source=chatgpt.com))
Key chips commonly encountered on 1040STE boards: - Motorola MC68000FN8 CPU (PLCC, 8 MHz).[14] ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?utm_source=chatgpt.com)) - Atari GST MCU: C300589 (earlier, separate BLiTTER) or C302183 (integrated BLiTTER) 144‑pin QFP.[15] ([forums.atariage.com](https://forums.atariage.com/topic/263950-missing-blitter-from-ste/?utm_source=chatgpt.com)) [ebay.com](https://www.ebay.com/itm/163699098588?utm_source=chatgpt.com)) - Atari GST Shifter: C301712‑001 (later SMD) or C300588‑001 (earlier 84‑pin), provides 4096‑color palette and video shift; also interfaces Microwire for LMC1992 audio.[16] ([ataristsales.co.uk](https://www.ataristsales.co.uk/product/gst-shifter-chip-c301712-001-for-the-atari-ste-and-mega-ste/?utm_source=chatgpt.com)) [atari-forum.com](https://www.atari-forum.com/viewtopic.php?t=29116&utm_source=chatgpt.com)) - Motorola 68901 MFP (interrupt/timer/serial glue), WD1772 floppy controller, DMA controller (several revisions), Yamaha YM2149 PSG, National LMC1992 audio controller (Microwire).[17] ([info-coach.fr](https://info-coach.fr/atari/hardware/STE-HW.php?utm_source=chatgpt.com)) [atariarchives.org](https://www.atariarchives.org/cfn/12/05/03/0003.php?utm_source=chatgpt.com))
Input/Output and Expansion
Rear and side panel connectivity (varies slightly by region/revision): - RS‑232C serial (DB‑25M), Centronics parallel (DB‑25F).[18] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com)) - ACSI DMA port (DB‑19) for hard disks/laser printer; external floppy (14‑pin DIN).[19] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com)) - Monitor out (13‑pin DIN) for RGB mono/color; some units retain TV/RF output in certain regions. [20] ([atarimagazines.com](https://www.atarimagazines.com/startv5n4/enhanced.html?utm_source=chatgpt.com)) - MIDI In/Out (5‑pin DIN).[21] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com)) - Two enhanced joystick/analogue ports (DB‑15F) on the left side; accept Jaguar‑style pads/analogue controllers; adapters allow two standard DE‑9 sticks per port. [22] ([info-coach.fr](https://info-coach.fr/atari/hardware/interfaces.php?utm_source=chatgpt.com)) - Two DE‑9 mouse/joystick ports retained under the keyboard recess. [23] ([pcworld.com](https://www.pcworld.com/article/511497/inside_atari_1040st.html?utm_source=chatgpt.com)) - Stereo RCA (L/R) line‑level audio outputs. [24] ([atarimagazines.com](https://www.atarimagazines.com/startv5n4/enhanced.html?utm_source=chatgpt.com))
The internal PSU is a compact switching supply providing +5 V and +12 V; nominal +5 V adjustment is 5.1 V. [25] ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?utm_source=chatgpt.com))
Display and Graphics
- Resolutions: 320×200 (16 colors), 640×200 (4 colors), 640×400 mono (SM124‑class monitor required).[26] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com)) - Palette: 12‑bit (4,096 colors), with per‑scanline palette tricks enabling richer on‑screen color in demos/games.[27] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com)) - Hardware features: BLiTTER (standard on STE; max ~4 MB/s moves), fine hardware scroll, split screen (via Shifter timing).[28] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com)) - Shifter devices: early C300588‑001 (84‑pin) and later C301712‑001 (SMD) found across board revisions. [29] ([atari-forum.com](https://www.atari-forum.com/viewtopic.php?t=29116&utm_source=chatgpt.com))
Motherboard families and documentation useful to technicians:
- Common 1040STE board FABs/ASSYs
 - CA4003290 (early–mid runs; some with SIPP RAM, later SIMM), CA401177 (late, many SMD parts), and C300779‑001 Rev. 5.1 are observed in the field. [30] ([temlib.org](https://temlib.org/AtariForumWiki/index.php/Atari_ST_motherboard_revisions?utm_source=chatgpt.com)) [milan.kovac.cc](https://milan.kovac.cc/atari/chipmunk/?id=1499348247&utm_source=chatgpt.com))
- Schematic set: “Atari STe Schematic Rev. A C300780‑001” (dated Oct‑3‑1989) corresponds closely to shipping 520/1040STE boards. [31] ([yumpu.com](https://www.yumpu.com/it/document/view/34489511/atari-ste-schematic-rev-a-c300780-001-oct-3-1989?utm_source=chatgpt.com)) [elektrotanya.com](https://elektrotanya.com/atari_1040ste_c300780-001_rev.a_sch_1986.pdf/download.html?utm_source=chatgpt.com)) - Field Service Manual: “Atari 520STE/1040STE Field Service Manual” covers both models; PSU trim, theory of operation, diagnostics, flowcharts. [32] ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?utm_source=chatgpt.com))
Board/FAB (marking) Typical features Matching schematic docs
CA4003290 Early “beta” and revised runs; some SIPP sockets; discrete BLiTTER; later sub‑runs add integrated‑BLiTTER MCU C300780‑001 Rev.A STe schematic set
C300779‑001 Rev. 5.1 Late ’89/’90 production; SIMM RAM; frequent DMA chip updates C300780‑001 Rev.A; field addenda
CA401177 Late SMD‑heavy run; BLiTTER in MCU; surface‑mount 68000, Shifter C300780‑001 Rev.A + rev notes
Memory and Storage
- DRAM: Four 30‑pin SIMM sockets (some early units shipped SIPP). Accept 256 KB or 1 MB 8‑bit modules (with/without parity). Supported capacities: 1, 2, or 4 MB; 2.5 MB is possible but has compatibility caveats. Recommended speeds: 150 ns (256 KB) and 120 ns (1 MB). [33] ([info-coach.fr](https://info-coach.fr/atari/hardware/memory.php?utm_source=chatgpt.com)) - ROM: Two socketed 128 KB ROMs (27C010 class) carrying TOS 1.06 or 1.62; upgrades and multi‑TOS switchers are common. [34] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_TOS?utm_source=chatgpt.com)) [ultradevtools.de](https://www.ultradevtools.de/ultraTos.html?utm_source=chatgpt.com)) - Floppy: Internal 3.5" DS/DD 720 KB; external 14‑pin DIN port allows second drive; HD (1.44 MB) available only via later mods/kits. [35] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com)) - Mass storage: ACSI (DB‑19) hard disks; modern SD‑based ACSI devices (e.g., UltraSatan) rely on healthy DMA silicon (see DMA notes below). [36] ([forums.atariage.com](https://forums.atariage.com/topic/211660-buggy-dma-chip/?utm_source=chatgpt.com))
- Atari 1040STE General Maintenance - Atari 1040STE Troubleshooting Guide - Atari 1040STE Capacitor Replacement Guide - Atari ST and STE RAM Upgrade Guide - Atari STE DMA Port & Hard‑Disk Guide
Sound Capabilities
In addition to the YM2149 PSG (3 tones + noise), the STE adds 2‑channel 8‑bit PCM playback via DMA, at selectable nominal rates of 6,258/12,517/25,033/50,066 Hz (mono or stereo). Audio is mixed and equalized by an LMC1992 controlled over the Microwire serial interface exposed by the Shifter; bass/treble and master/left/right levels are software‑settable. The STE also routes mixed audio to both the built‑in monitor mono output and to rear‑panel stereo RCA jacks. [37] ([bus-error.nokturnal.pl](https://bus-error.nokturnal.pl/atari_compendium/html/chap5.htm?utm_source=chatgpt.com)) [alive.atari.org](https://alive.atari.org/alive11/mcrowire.php?utm_source=chatgpt.com)) [mikrosk.github.io](https://mikrosk.github.io/doitarchive/doit_st/0309.htm?utm_source=chatgpt.com))
Tech note: Many units ship with PSG/DMA level imbalance (PSG “hotter”). Hardware and software adjustments are documented by the scene and repair community for achieving near‑1:1 mix when required. [38] ([atari.8bitchip.info](https://atari.8bitchip.info/STEamFix.html?utm_source=chatgpt.com)) [alive.atari.org](https://alive.atari.org/alive11/mcrowire.php?utm_source=chatgpt.com))
- PSU: Recap original switchers (DVE/Mitsumi etc.) and set +5 V at ≈5.10 V under load; replace the 2 A fuse only after root‑cause analysis. [39] ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?utm_source=chatgpt.com)) - Mainboard electrolytics: Replace aging caps on CA4003290/CA401177 boards; vetted lists exist for STE cap kits. [40] ([wiki.console5.com](https://wiki.console5.com/wiki/Atari_ST?utm_source=chatgpt.com)) [console5.com](https://console5.com/store/atari-520ste-1040ste-computer-cap-kit-main-ste-pcb.html?utm_source=chatgpt.com)) - Floppy: Clean/lubricate rails; verify write‑protect and track‑0 sensors; re‑align only with proper disks/tools. - RAM: Use matched SIMM pairs; avoid 2 MB/4 MB 30‑pin modules which are not supported by the stock MMU design. [41] ([info-coach.fr](https://info-coach.fr/atari/hardware/memory.php?utm_source=chatgpt.com))
For full procedures see Atari 1040STE General Maintenance.
Subsystem Device(s) / notes
CPU Motorola MC68000 (PLCC) @ 8 MHz; socketed on most boards. [42] ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?utm_source=chatgpt.com))
System ASICs GST MCU (C300589 early, C302183 later with integrated BLiTTER); GST Shifter (C301712‑001/C300588‑001). [43] ([forums.atariage.com](https://forums.atariage.com/topic/263950-missing-blitter-from-ste/?utm_source=chatgpt.com)) [atari-forum.com](https://www.atari-forum.com/viewtopic.php?t=29116&utm_source=chatgpt.com))
Blitter Discrete BLiTTER on early boards; ~4 MB/s block moves; later integrated into MCU. [44] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
Memory 4× 30‑pin SIMM sockets (or SIPP on earliest); 1–4 MB official configurations. [45] ([info-coach.fr](https://info-coach.fr/atari/hardware/memory.php?utm_source=chatgpt.com))
Audio YM2149 PSG + 2‑ch DMA PCM (8‑bit) via Shifter; LMC1992 mixer/EQ (Microwire). [46] ([bus-error.nokturnal.pl](https://bus-error.nokturnal.pl/atari_compendium/html/chap5.htm?utm_source=chatgpt.com)) [alive.atari.org](https://alive.atari.org/alive11/mcrowire.php?utm_source=chatgpt.com))
I/O RS‑232 (DB‑25M), Centronics (DB‑25F), ACSI DMA (DB‑19), external floppy (14‑pin DIN), monitor (13‑pin DIN), 2× MIDI, 2× DB‑15 enhanced joystick, 2× DE‑9 mouse/joystick. [47] ([atarimagazines.com](https://www.atarimagazines.com/startv5n4/enhanced.html?utm_source=chatgpt.com)) [info-coach.fr](https://info-coach.fr/atari/hardware/interfaces.php?utm_source=chatgpt.com))
FDD WD1772 controller; 3.5" DS/DD 720 KB internal. [48] ([info-coach.fr](https://info-coach.fr/atari/hardware/STE-HW.php?utm_source=chatgpt.com))
- MC68000 8 MHz core; 24‑bit address space (16 MB). - GST MCU handles DRAM multiplexing, decode, DMA hand‑off, joystick/paddle and timing. - GST Shifter fetches bitplanes and clocks RGB; exposes Microwire to the LMC1992 and manages DMA‑audio shift. - BLiTTER accelerates block copies/fills. - MFP 68901 provides timers/interrupt aggregation; ACIA 6850s handle MIDI and keyboard links. - DMA port (ACSI) arbitrates CPU/disk transfers. [49] ([info-coach.fr](https://info-coach.fr/atari/hardware/STE-HW.php?utm_source=chatgpt.com))
Apple Service Manual
This section header is retained for template consistency; Atari 1040STE documentation is covered instead by the official 520/1040STE Field Service Manual and STe schematics listed below. [50] ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?utm_source=chatgpt.com))
The 1040STE is a single main logic board plus a separate PSU (no discrete “analog board” as on Apple compacts). Use: - Atari STe Schematic Rev. A (C300780‑001, 1989‑10‑03). [51] ([yumpu.com](https://www.yumpu.com/it/document/view/34489511/atari-ste-schematic-rev-a-c300780-001-oct-3-1989?utm_source=chatgpt.com)) - 520/1040STE Field Service Manual (diagnostics, PSU trim, theory). [52] ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?utm_source=chatgpt.com))
Common STE failure modes and pointers: - No boot/white or checker screen: reseat PLCC CPU and Shifter; verify +5 V = 5.10 V; try known‑good SIMMs in bank order (1/3); run a diagnostic cartridge if available. [53] ([forums.atariage.com](https://forums.atariage.com/topic/283468-1040ste-wont-boot-help-needed/?utm_source=chatgpt.com)) - Floppy errors: clean heads, verify WD1772 clock, check drive select and write‑protect sensors. - ACSI hard‑disk issues: certain early DMA chips (e.g., C025913‑38) are marginal; Atari and community fixes improve bus hand‑off (pull‑up changes, small timing caps); later C398739‑001A silicon is preferred. [54] ([exxosforum.co.uk](https://exxosforum.co.uk/atari/last/DMASG/index.htm?utm_source=chatgpt.com)) [forums.atariage.com](https://forums.atariage.com/topic/211660-buggy-dma-chip/?utm_source=chatgpt.com)) - Audio imbalance/distortion: adjust LMC1992 in software (reduce master volume a few dB) or apply documented Microwire/PSG level fix for proper DMA/PSG mix. [55] ([alive.atari.org](https://alive.atari.org/alive11/mcrowire.php?utm_source=chatgpt.com)) [atari.8bitchip.info](https://atari.8bitchip.info/STEamFix.html?utm_source=chatgpt.com))
🧠 Architecture and Processor
Deep‑dive register highlights for repair and testing: - DMA sound control block at $FF8900–$FF8920: set mode (mono/stereo), rate (6.25–50 kHz), base/end addresses, and looping. [56] ([bus-error.nokturnal.pl](https://bus-error.nokturnal.pl/atari_compendium/html/chap5.htm?utm_source=chatgpt.com)) - LMC1992 Microwire writes via $FF8922/$FF8924; 11‑bit transactions (addr+data). [57] ([mikrosk.github.io](https://mikrosk.github.io/doitarchive/doit_st/0309.htm?utm_source=chatgpt.com)) - BLiTTER present flag and speed: use desktop “Blitter” option or query $FFFF8A00 series (model‑dependent). [58] ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
Technical Documentation
- Atari 520STE/1040STE Field Service Manual (theory, diagnostics, PSU adjustment). [59] ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?utm_source=chatgpt.com)) - Atari 1040STE Schematics (C300780‑001 Rev.A) (Oct‑3‑1989). [60] ([yumpu.com](https://www.yumpu.com/it/document/view/34489511/atari-ste-schematic-rev-a-c300780-001-oct-3-1989?utm_source=chatgpt.com)) [archive.org](https://archive.org/details/Atari_1040STe_Schematic_1986_Atari?utm_source=chatgpt.com)) - Atari Compendium – Hardware Reference (DMA sound registers, system programming). [61] ([bus-error.nokturnal.pl](https://bus-error.nokturnal.pl/atari_compendium/html/chap5.htm?utm_source=chatgpt.com)) - STE Hardware Description (Info‑Coach) (chip roles, LMC1992 and GST ASIC details). [62] ([info-coach.fr](https://info-coach.fr/atari/hardware/STE-HW.php?utm_source=chatgpt.com)) - Atari ST Interfaces and Connectors (Info‑Coach) (pinouts for STE DB‑15 joystick and audio). [63] ([info-coach.fr](https://info-coach.fr/atari/hardware/interfaces.php?utm_source=chatgpt.com))
Notes on dimensions and mass
Case dimensions for the 1040‑style chassis are approximately 475×290×70 mm, consistent with user measurements and museum entries for 1040STF/M/STE shells; bare unit weights vary across revisions and drive/PSU vendors (≈4.0–4.7 kg). [64] ([forums.atariage.com](https://forums.atariage.com/topic/134542-atari-520-ste-dimensions/?utm_source=chatgpt.com)) [computermuseum.wordpress.com](https://computermuseum.wordpress.com/2006/04/25/1040-stf/?utm_source=chatgpt.com)) [amibay.com](https://www.amibay.com/threads/atari-1040ste-4mb-ram-tos-1-62-german.2442186/?utm_source=chatgpt.com))
Motherboard revisions (service reference)
Common field sightings include CA4003290 (early/mid), C300779‑001 Rev.5.1, and CA401177 (late SMD) with combinations of discrete/integrated BLiTTER and SIPP/SIMM RAM hardware. [65] ([temlib.org](https://temlib.org/AtariForumWiki/index.php/Atari_ST_motherboard_revisions?utm_source=chatgpt.com)) [milan.kovac.cc](https://milan.kovac.cc/atari/chipmunk/?id=1499348247&utm_source=chatgpt.com))
PCB Schematics & Service Guide
- Assembly/FAB identifiers: CA4003290 (early/mid), C300779‑001 Rev.5.1 (1989‑1990), CA401177 (late). [66] ([wiki.console5.com](https://wiki.console5.com/wiki/Atari_ST?utm_source=chatgpt.com)) - Schematic mapping table is provided above; use C300780‑001 Rev.A set as baseline, plus field addenda as encountered. [67] ([yumpu.com](https://www.yumpu.com/it/document/view/34489511/atari-ste-schematic-rev-a-c300780-001-oct-3-1989?utm_source=chatgpt.com))
Service manual and schematics (quick links)
- Atari 520/1040STE Field Service Manual (PSU 5.1 V calibration, fault trees). [68] ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?utm_source=chatgpt.com)) [best-electronics-ca.com](https://www.best-electronics-ca.com/service_.htm?utm_source=chatgpt.com)) - 1040STE Schematic (C300780‑001 Rev. A, 1989) (Internet Archive/Yumpu mirrors). [69] ([archive.org](https://archive.org/details/Atari_1040STe_Schematic_1986_Atari?utm_source=chatgpt.com)) [yumpu.com](https://www.yumpu.com/it/document/view/34489511/atari-ste-schematic-rev-a-c300780-001-oct-3-1989?utm_source=chatgpt.com))
  1. Shipping windows compiled from period coverage and museum research.
  2. End-of-production window reported by the German Atari Museum project.
  3. Contemporaneous pricing collated from dealer brochures and museum price tables.
  4. Listed in the 520STE/1040STE Field Service Manual.
  5. STE memory subsystem notes and SIMM/SIPP specifics.
  6. Port/drive summary from contemporary reviews and hardware guides.
  7. STE graphics overview and palette expansion versus STF/M.
  8. DMA sample rates and LMC1992 mixer details.
  9. User‑measured case dimensions consistent across ST and STE shells.
  10. Typical bare‑unit masses reported by collections and sales logistics.
  11. TOS versions and ROM formats for STE.
  12. Overview of STE enhancements and U.S. release timing.
  13. STE motherboard component map and GST MCU/SHIFTER roles.
  14. CPU type and packaging from the Field Service Manual.
  15. Part numbers for STE MCUs, with/without blitter.
  16. GST Shifter device references.
  17. Part roles summarized from hardware articles and service texts.
  18. Standard ST family I/O retained on STE.
  19. ACSI/DMA and external floppy connector formats.
  20. Monitor/TV outputs on STE models reviewed at launch.
  21. ST‑series hallmark MIDI ports.
  22. STE joystick port pinout and usage.
  23. Legacy ports placement description.
  24. STE rear‑panel stereo jacks.
  25. Power section adjustment and fuse rating in Field Service Manual.
  26. Resolution modes across the ST family.
  27. Palette expansion vs. earlier STs.
  28. BLiTTER throughput and fine‑scroll support.
  29. Device identities and interchangeability notes.
  30. Community‑maintained revision list and serial registry entries.
  31. Primary STe schematic drawings.
  32. Manual availability and scope.
  33. STE SIMM/SIPP guidance and timing requirements.
  34. TOS formats and upgrade practice.
  35. Stock floppy capabilities and external port.
  36. ACSI usage and DMA chip caveats on some STEs.
  37. DMA registers/rates and LMC1992 control model.
  38. Documented Microwire mix corrections and best‑practice settings.
  39. PSU calibration guidance.
  40. Consolidated capacitor lists for STE PCB variants.
  41. Supported SIMM sizes and speeds.
  42. CPU packaging and speed.
  43. Part numbers and integration notes.
  44. BLiTTER presence and throughput.
  45. Memory sockets and limits.
  46. DMA and Microwire chain.
  47. Panel I/O inventory.
  48. WD1772 use on STE.
  49. Consolidated STE block‑level description.
  50. Atari, not Apple, publishes the applicable service literature.
  51. Primary schematic set for 520/1040STE.
  52. Field servicing content and procedures.
  53. Community triage tactics; RAM isolation and reseat advice.
  54. Known “DMA bug” history and mitigation.
  55. Microwire programming and hardware correction notes.
  56. Register map and recommended programming sequence for playback.
  57. Microwire timing, masks, and command format.
  58. Presence and configuration checks.
  59. Manual sources and scanned copies.
  60. Schematics hosted by preservation sites.
  61. Compendium hardware chapters.
  62. STE hardware overview and translations of ST Magazine technical articles.
  63. Connector pinouts and port usage.
  64. Dimension and weight observations from museum sources and shipping reports.
  65. Community rev lists and serial database entries corroborating board IDs.
  66. See also cap lists keyed to board markings for recapping jobs.
  67. Multiple hosts mirror the same Rev.A package; verify sheet dates.
  68. Manualslib mirror; Best Electronics print copies.
  69. Schematic sets and dates.
Categories:
Editorial note on the “infobox” request and section names: The values supplied in the user’s template (e.g., Apple‑specific data) do not match the Atari 1040STE and would be factually incorrect if reproduced. This page therefore provides a complete, accurate “infobox computer” for the 1040STE. Likewise, Apple‑specific section titles are retained for structural compatibility, but the content points to the correct Atari service literature.
