This page is "edit" protected. The "autoconfirmed" right is required to "edit" this page.<ul class='mw-logevent-loglines'>
<li data-mw-logid="6038" data-mw-logaction="protect/modify" class="mw-logline-protect"> <a href="/index.php?title=Special:Log&logid=6038" title="Special:Log">04:38, 5 September 2025</a> <a href="/User:Josh" class="mw-userlink" title="User:Josh"><bdi>Josh</bdi></a> <span class="mw-usertoollinks mw-changeslist-links"><span><a href="/User_talk:Josh" class="mw-usertoollinks-talk" title="User talk:Josh">talk</a></span> <span><a href="/Special:Contributions/Josh" class="mw-usertoollinks-contribs" title="Special:Contributions/Josh">contribs</a></span></span> changed protection settings for <a href="/Template:AfC_draft_editintro" title="Template:AfC draft editintro">Template:AfC draft editintro</a> [Edit=Allow only autoconfirmed users] (indefinite) [Move=Allow only autoconfirmed users] (indefinite) <span class="mw-logevent-actionlink">(<a href="/index.php?title=Template:AfC_draft_editintro&action=history&offset=20250905033806" title="Template:AfC draft editintro">hist</a>)</span> <span class="mw-logevent-tool"></span></li>
</ul>
<ul class="mw-logevent-footer"><li><a href="/index.php?title=Special:Log&page=Template%3AAfC_draft_editintro&type=protect" title="Special:Log">View full log</a></li></ul>
This page is "move" protected. The "autoconfirmed" right is required to "move" this page.<ul class='mw-logevent-loglines'>
</ul>
Instructions
Creating a draft article takes three steps. Please read carefully.
- Enter the content of your article in the blank area as illustrated.
- Remember to use your own words. Do not copy content from another website.
- If you need help with your submission, you can visit forum.retrotechcollection.com or the RTC Discord.
- When you are finished writing, click the "Publish page" button. You are all done! We appreciate your submission.
Important
- Please note: Once you click the "publish" button, your draft is saved in a public drafting area. You may continue to work on your draft as long as you like; there is no deadline, but bear in mind that if the draft isn't edited in six months, it may be deleted.
- If the draft is declined, you will still be able to edit it. It is simply marked as declined.
- When you feel your draft is ready to become an article, you can request a review (or a re-review). To do so, edit your draft, by clicking on its "Edit" button, and add
{{subst:submit}} at the beginning of your draft.
