Template:R protected
| This template is used on approximately 1 pages and changes may be widely noticed. Test changes in the template's /sandbox or /testcases subpages, or in your own user subpage. Consider discussing changes on the talk page before implementing them. |
This template will automatically categorize redirects into their appropriate rcat protection category.
Usage
#REDIRECT [[(redirect target)]]
{{R protected}}This template is also called automatically by {{redirect category shell}}; if that template is used on the page, this template does not need to be included in the redirect cat templates as it will be called directly. A protected page also using {{r from move}} would look like this:
{{Redirect category shell|1=
{{R from move}}
}}{{redirect category shell}} adds both templates automatically. For another example of this use case, see Wikipedia:Example of a broken redirect.
Examples
- Fully protected: This is a redirect from a title that is fully protected from editing for any of several possible reasons. It may have been protected by an administrator, or it may be on the Cascade-protected list, or both.
- Please do not replace these redirected links with links directly to the target page unless expressly advised to do so below or elsewhere on this page, or if the change is supported by a policy or guideline.
- Template-protected: This is a redirect from a page that is template-protected from editing for any of several possible reasons. Only administrators and template editors may edit this page.
- Extended-confirmed protected: This is a redirect from a title that is extended confirmed protected from editing for any of several possible reasons.
- Semi-protected: This is a redirect from a title that is semi-protected from editing for any of several possible reasons.
