Module:Submit an edit request/config
Revision as of 22:08, 6 September 2025 by Josh (talk | contribs) (1 revision imported)
Documentation for this module may be created at Module:Submit an edit request/config/doc
-- This module contains configuration data for [[Module:Submit an edit request]].
return {
-- Messages
-- The default display value for edit requests.
['default-display-value'] = 'Submit an edit request',
-- The template that stores the edit request preload text
['preload-template'] = 'Template:Submit an edit request/preload',
-- The section heading that is generated when a user clicks on an edit request
-- link. $1 is the protection level text, e.g. "Semi-protected" or
-- "Template-protected". $2 is the current date, in the format specified by the
-- "preload-title-date-format" message.
['preload-title-text'] = '$1 edit request on $2',
-- The date format for the automatically-generated section heading. The format
-- must be valid input for the #time parser function.
['preload-title-date-format'] = 'j F Y',
-- What do do with the generated section header if another header with the same section already exists
-- $1 is the original section header. $2 is an automatically generated number, starting at 2 and increasing
-- by one until a unique header is found.
['preload-title-dedup-suffix'] = '$1 ($2)',
-- The names of pages (and their subpages) that make up the content of the main page for this wiki
['main-page-content'] = {
	['Wikipedia:Today\'s featured article'] = true,
	['Template:In the news'] = true,
	['Template:Did you know'] = true,
	['Wikipedia:Selected anniversaries'] = true,
	['Template:POTD protected'] = true,
	['Wikipedia:Today\'s featured list'] = true
-- The page used to request changes to things on the Main Page.
['main-page-request-page'] = 'Wikipedia:Main Page/Errors',
-- The page used to request edits to protected talk pages.
['protected-talk-page-request-page'] = 'Wikipedia:Requests for page protection/Edit',
-- The names of the templates to be used as wrappers for the "link" and "button"
-- functions. These are passed as arguments to the "wrappers" option of
-- [[Module:Arguments]].
['link-wrapper-template'] = 'Template:Submit an edit request/link',
['button-wrapper-template'] = 'Template:Submit an edit request',
-- Protection level config
protectionLevels = {
-- These settings are for the different protection levels which the module can
-- output edit request links for.
-- editintro:
-- The template to use as the edit intro users see when they click on an edit
-- request link.
-- request-template:
-- The name of the edit request template for that protection level. Do not
-- include the "Template:" text.
-- protectionlevel:
-- The name of the protection level, used for formatting the automatically-
-- generated section headings.
-- Semi-protection
semi = {
	editintro = 'Template:Edit semi-protected/editintro',
	requestTemplate = 'edit semi-protected',
	levelText = 'Semi-protected',
-- Extended-confirmed-protection
extended = {
	editintro = 'Template:Edit extended-protected/editintro',
	requestTemplate = 'edit extended-protected',
	levelText = 'Extended-confirmed-protected',
-- Template-protection
template = {
	editintro = 'Template:Edit template-protected/editintro',
	requestTemplate = 'edit template-protected',
	levelText = 'Template-protected',
-- Full protection
full = {
	editintro = 'Template:Edit protected/editintro',
	requestTemplate = 'edit fully-protected',
	levelText = 'Protected',
-- Interface-protection
interface = {
	editintro = 'Template:Edit interface-protected/editintro',
	requestTemplate = 'edit interface-protected',
	levelText = 'Interface-protected',
