Module:CallAssert
Revision as of 22:09, 6 September 2025 by Josh (talk | contribs) (1 revision imported)
Documentation for this module may be created at Module:CallAssert/doc
local function pack(...)
	return {...}, select('#', ...)
end
local function mapArray(func, array, count)
	local result = {}
	for i = 1, count or #array do
		result[i] = func(array[i])
	end
	return result
end
local function quote(value)
	if type(value) == 'string' then
		return (string.gsub(string.format('%q', value), '\\\n', '\\n'))  -- Outer parentheses remove second value returned by gsub
	end
	local str = tostring(value)
	if type(value) == 'table' and str ~= 'table' then
		return '{' .. str .. '}'
	end
	return str
end
local function callAssert(func, funcName, ...)
	local result, resultCount = pack(func(...))
	if not result[1] then
		local args, argsCount = pack(...)
		args = mapArray(quote, args, argsCount)
		local message = mw.ustring.format(
			'%s(%s) failed',
			funcName,
			table.concat(args, ', ')
		error(message, 2)
	end
	return unpack(result, 1, resultCount)
end
return callAssert
