Template:ProdwarningBLP
Revision as of 23:18, 6 September 2025 by Josh (talk | contribs) (1 revision imported)
Proposed deletion of [[{{{1}}}]]
Notice
The article [[{{{1}}}]] has been proposed for deletion because it appears to have no references. Under Wikipedia policy, this biography of a living person will be deleted after seven days unless it has at least one reference to a reliable source that directly supports material in the article.
If you created the article, please don't be offended. Instead, consider improving the article. For help on inserting references, see Referencing for beginners, or ask at the help desk. Once you have provided at least one reliable source, you may remove the {{prod blp/dated}} tag. Please do not remove the tag unless the article is sourced. If you cannot provide such a source within seven days, the article may be deleted, but you can request that it be undeleted when you are ready to add one.
