Apple Joystick IIe/IIc
Revision as of 13:03, 9 February 2026 by Josh (talk | contribs) (Fix category to Apple Vintage Accessories)
The Apple Joystick (models A2M2002 and A2M2012) was Apple's analog joystick for the Apple IIe, Apple IIc, and Apple IIGS computers. Used primarily for games, the self-centering joystick provided proportional control through two potentiometers.
Apple Joystick (Model A2M2012)
Type Joystick (analog)
Discontinued 1993
Price US$49
Interface DE-9 (game port)
Compatible Apple IIe, Apple IIc, Apple IIc Plus, Apple IIGS
Dimensions ~115 mm × 115 mm × 70 mm (4.5" × 4.5")
Weight ~200 g
Predecessor Apple II Joystick (A2M2002)
Successor None
Model A2M2002, A2M2012
Models
Apple produced two joystick models with identical external appearance but different model numbers:
Model Description Period
A2M2002 Original Apple II Joystick 1983-1985
A2M2012 Apple IIe/IIc Joystick (revised) 1984-1993
The case dimensions appear identical between models. Internal components may vary.
Design
Physical Construction
The joystick features a compact beige plastic housing:
  • Square base approximately 4.5" × 4.5" (115 mm × 115 mm)
  • Central stick with rounded knob
  • Two fire buttons on the base
  • Adjustable centering controls on bottom
  • Fixed DE-9 cable
Self-Centering Mechanism
The joystick uses spring-loaded centering:
  • Springs return the stick to center when released
  • Center position represents "no input"
  • Trim controls on bottom allow fine adjustment
  • Prevents drift in software that relies on neutral position
Analog Operation
Unlike digital joysticks with simple on/off contacts, the Apple Joystick provides proportional control:
  • Two potentiometers (approximately 100-150 kΩ)
  • Variable resistance indicates stick position
  • Allows gradual movement vs. binary direction
  • Similar principle to modern analog thumbsticks
Measured potentiometer values vary between units (114k, 118k, 136k observed), requiring calibration for optimal performance.
Connection
The joystick connects via a DE-9 connector:
  • Direct connection to Apple IIc and IIc Plus game port
  • Requires interface card or adapter for Apple II and II Plus
  • Compatible with Apple IIGS
Apple II Compatibility
The packaging stated Apple II compatibility, but this required an adapter. Southern California Research Group sold adapters for:
  • Apple II and II Plus connection
  • Dual joystick support on Apple IIGS
The green wire present in the cable is unused.
Parameter Value
Model numbers A2M2002, A2M2012
Weight ~200 g
Potentiometers ~100-150 kΩ (varies)
Buttons 2 fire buttons
Interface DE-9 connector
Cable length ~1.5 m
Case color Beige (Apple II matching)
Case material ABS plastic
Internal Components
Potentiometers
Two potentiometers control X and Y axes:
  • Rotary type with gear linkage to stick
  • Values observed: 114k, 118k, 136k ohms
  • Variation between units may require calibration
  • Some Apple IIe units need capacitor adjustment for full range
Buttons
Two momentary switches provide button inputs:
  • Standard NO (normally open) contacts
  • Connect to Button 0 and Button 1 inputs
  • Located on base flanking the stick
Springs
Centering springs provide return force:
  • Loaded around the stick pivot
  • Force increases with deflection
  • Springs can weaken over decades of use
Maintenance
Calibration
Centering adjustments are accessible on the bottom:
  1. Locate two trim controls
  2. Adjust while monitoring center position in software
  3. Small screwdriver required
  4. Test in multiple applications
Potentiometer Cleaning
Erratic movement often indicates dirty pots:
  1. Open case (screws on bottom)
  2. Apply contact cleaner to potentiometer openings
  3. Work stick through full range multiple times
  4. Allow to dry before reassembly
Spring Replacement
Weak centering indicates worn springs:
  1. Disassemble joystick
  2. Identify spring type and dimensions
  3. Source replacement springs (uncommon)
  4. Reassemble with correct tension
Problem Cause Solution
No response Cable damage, card issue Test cable continuity, verify card
Drift from center Calibration needed Adjust trim controls
Erratic movement Dirty potentiometers Clean with contact cleaner
Limited range Pot mismatch with system May require capacitor adjustment
Weak centering Worn springs Replace springs (difficult)
Button stuck Debris, worn switch Clean or replace switch
Collecting
Condition Assessment
  • Mint: Original box, fully functional, clean
  • Excellent: Functional, minimal wear
  • Good: Functional, cosmetic wear
  • Fair: Functional but needs calibration
  • Poor: Non-functional or damaged
Original Box
Boxed examples are more valuable. The packaging includes:
  • Joystick unit
  • Brief documentation
  • Apple II compatibility note
3D Printed Reproductions
Due to rising prices, some collectors create 3D printed cases:
  • Dimensions available from community measurements
  • Original internal components still required
  • Considered replicas, not original units
  • Applefritter community discussions
  • The Liberator — joystick disassembly documentation
  • Computer History Museum collection records
