Macintosh LC
Revision as of 18:08, 9 February 2026 by Josh (talk | contribs) (Added infobox image)
Macintosh LC
Macintosh LC
TypePersonal Computer
ReleasedOctober 15, 1990
DiscontinuedMarch 23, 1992
Intro priceUS$2,499
CPUMotorola 68020 @ 16 MHz
Memory2 MB RAM (expandable to 10 MB)
Storage40 MB or 80 MB SCSI HDD, 1.44 MB SuperDrive
Display512×384 (8-bit) or 640×480 (4-bit)
Sound8-bit stereo input/output
Dimensions2.9" H × 12.2" W × 15.3" D
Weight8.8 lbs (4.0 kg)
OS / FirmwareSystem 6.0.7 – System 7.5.5
SuccessorMacintosh LC II
CodenameElsie
Model no.M0350
The Macintosh LC is a low-cost Macintosh personal computer released by Apple on October 15, 1990.[1] The name "LC" stands for "low-cost color," and the machine was designed to bring color Macintosh computing to education and home markets at a more affordable price point than the Macintosh II series.[2] The internal codename "Elsie" was a phonetic play on "LC."
The Macintosh LC uses a Motorola 68020 processor running at 16 MHz. However, the system has a significant bottleneck: the 68020's 32-bit data bus is connected through a 16-bit memory controller, effectively limiting memory bandwidth.[3] This design decision reduced costs but limited performance compared to full 32-bit implementations.
The Gestalt ID for the Macintosh LC is 19.
Memory and Storage
RAM Configuration
The LC shipped with 2 MB of RAM standard, expandable to 10 MB. Memory expansion uses two 30-pin SIMM slots, which must be populated in pairs using matching SIMMs. The machine uses 100ns or faster SIMMs.
RAM Configurations
Configuration Slot 1 Slot 2
2 MB 1 MB 1 MB
4 MB 2 MB 2 MB
10 MB 4 MB + 2 MB onboard 4 MB
Video RAM
The LC includes 256 KB of VRAM standard, expandable to 512 KB with an optional VRAM SIMM. Video memory determines available color depth:
  • 256 KB VRAM: 512×384 at 8-bit (256 colors) or 640×480 at 4-bit (16 colors)
  • 512 KB VRAM: 512×384 at 8-bit or 640×480 at 8-bit
Storage Systems
Standard storage options included:
  • 40 MB or 80 MB internal SCSI hard drive
  • 1.44 MB SuperDrive (reads/writes 400K, 800K, and 1.44 MB disks)
Input/Output and Expansion
Port Configuration
  • 1× Apple Desktop Bus (ADB) port
  • 1× External SCSI (DB-25)
  • 1× Audio input (3.5mm stereo minijack)
  • 1× Audio output (3.5mm stereo minijack)
  • 2× Serial ports (Mini DIN-8)
  • 1× Video output (DA-15)
Expansion
The LC features a single LC Processor Direct Slot (LC PDS), a 96-pin expansion slot. This slot accepts LC-specific expansion cards including:
  • Ethernet adapters
  • Video capture cards
  • Apple IIe Card (for Apple II compatibility)
Design and Form Factor
The LC introduced Apple's "pizza box" form factor—a compact, horizontally-oriented case designed to fit under a monitor. The case measures 2.9 inches high, 12.2 inches wide, and 15.3 inches deep. This form factor was used throughout the LC line and influenced subsequent compact Macintosh designs.
For detailed maintenance practices including cleaning, PRAM battery management, and connector care, refer to the dedicated Macintosh LC General Maintenance page.
A comprehensive troubleshooting guide addressing common issues with the Macintosh LC is available on the Macintosh LC Troubleshooting page.
Capacitor Replacement
The Macintosh LC logic board contains 17 surface-mount electrolytic capacitors that commonly fail due to age. Detailed replacement guidelines can be found on the Macintosh LC Capacitor Replacement Guide page.
System Specifications
Macintosh LC Technical Specifications
Component Specification
CPU Motorola 68020 @ 16 MHz
FPU None (not supported)
Data Bus 32-bit (16-bit memory controller)
Address Bus 32-bit
System Bus 16 MHz
ROM 512 KB
RAM 2 MB (max 10 MB)
VRAM 256 KB (max 512 KB)
  1. Macintosh LC, Apple History—link(accessed 2026-02-09)
  2. Macintosh LC, Low End Mac—link(accessed 2026-02-09)
  3. Apple Macintosh LC Specs, EveryMac.com—link(accessed 2026-02-09)
