Troubleshooting the Macintosh LC 630 and related models (Quadra 630 , Performa 630 series , LC 630 DOS Compatible ) requires understanding their shared architecture. All variants use the same logic board (820-0524) with minor configuration differences. This guide covers common issues and diagnostic procedures.
Before diagnosing component failures, verify:
Power cable securely connected
Power outlet functional (test with another device)
Power switch on rear of unit in ON position
Monitor connected and powered on separately
Keyboard and mouse connected to ADB port
Power Supply Voltages
+5V rail: 4.85V – 5.15V
+12V rail: 11.9V – 12.7V
-12V rail: Within 10% of nominal
No Power (Unit Dead)
Macintosh LC 630. Source: Wikimedia Commons.
No Power Diagnostics
Symptom
Possible Cause
Recommended Action
No LED, no sound, completely dead
Blown fuse in power supply
Open PSU, check and replace fuse if blown
No LED, no sound
Failed power supply
Test PSU outputs, replace if necessary
No LED, no sound
Power switch failure
Bypass switch to test; replace if faulty
Faint click when power button pressed
Shorted component on logic board
Disconnect drives and cards; test bare board
Power LED flashes briefly then dies
Capacitor failure
Inspect for leaking capacitors; recap board
Intermittent power
Loose power connector
Reseat internal power cable connections
Power Supply Testing
Disconnect power and open case
Slide out motherboard drawer for access
Reconnect power with drawer extended (careful!)
Measure voltages at logic board connector
If voltages absent or incorrect, PSU requires service
Check PSU capacitors for bulging or leakage
Chime but No Video
Startup Chime Without Video
Symptom
Possible Cause
Recommended Action
Normal chime, no video
Monitor connection issue
Check DA-15 video cable; try different monitor
Video DRAM failure
Logic board repair required (DRAM soldered)
Normal chime, black screen
Resolution mismatch
Zap PRAM (Cmd-Opt-P-R at startup)
Normal chime, garbled display
Video DRAM failure
Test with external video card if available
Chime, monitor shows "No Signal"
Video output failure
Check video port for bent pins; test board
Chime, dim or flickering image
DRAM timing issues
Recap logic board; check capacitors near video
Video System Notes
The LC 630 uses 1 MB DRAM shared with system operations:
Video memory cannot be upgraded
DRAM failure requires board-level repair
Some video issues caused by capacitor failure
Sad Mac Errors
Sad Mac errors display a code indicating the failure type. See Sad Mac Error Codes for complete reference.
Common LC 630 Sad Mac Codes
Code
Meaning
Resolution
0000000F 00000001
ROM test failure
Clean ROM if socketed; logic board failure likely
0000000F 00000002
Memory (RAM) test exception
Reseat or replace SIMMs; check soldered RAM
0000000F 00000003
Memory (RAM) test failure
Test with known-good SIMM; check SIMM socket
0000000F 00000005
Bus error
Check for bent pins; reseat all socketed ICs
0000000F 0000000E
NuBus error
Remove expansion cards; test bare board
0000000F 0000000F
Data bus test failure
Logic board failure; recap may help
Intermittent Operation Issues
Symptom
Possible Cause
Recommended Action
Random freezes after warmup
Thermal issues (passive cooling)
Clean vents; check for dust accumulation
Crashes after 10-30 minutes
Failing capacitors
Inspect and recap logic board
Freezes during disk access
IDE cable issue
Check IDE cable connections; try different cable
Intermittent startup
Oxidized CPU socket
Reseat 68040; clean socket with DeoxIT
Freezes with extensions enabled
Software conflict
Boot with extensions off (hold Shift)
System hangs at startup
Corrupted system software
Reinstall System 7.5.3 or later
Random resets
PRAM battery failure
Check and replace 4.5V alkaline battery
RAM and Memory Issues
Memory Problems
Symptom
Possible Cause
Recommended Action
Less RAM reported than installed
Incompatible SIMM
Use 72-pin, 80ns, non-parity SIMMs
System won't boot with new SIMM
Wrong SIMM type
Check SIMM compatibility; use single-sided if slot 2
4 MB reported with SIMM installed
SIMM not seated
Reseat SIMM firmly in socket
Sad Mac RAM error
Defective SIMM
System unstable with 64+ MB SIMM
Unsupported size
64 MB requires single-banked SIMM specifically
SIMM Slot Notes
Single-slot models: Accept SIMMs up to 32 MB (64 MB unofficial)
Dual-slot models (DOS Compatible): Slot 2 requires single-sided SIMMs only
Slot 2 maximum: 16 MB (1, 4, or 16 MB single-sided)
IDE Hard Drive Problems
IDE Storage Issues
Symptom
Possible Cause
Recommended Action
Drive not recognized
Old system software
Update to System 7.5.2+; use Drive Setup 1.0.3+
Drive clicks but won't mount
Drive failure
Try different IDE drive
"This disk is unreadable"
Needs initialization
Use Apple Drive Setup to format
Drive recognized but won't boot
No System Folder
Reinstall Mac OS; verify blessed System Folder
Only partial capacity recognized
8 GB limit
IDE controller limitation; use drive ≤8 GB or partition
Single device only
Normal
LC 630 does not support master/slave configuration
IDE Compatibility Notes
First desktop Mac with IDE—driver support varies
System 7.1.2 requires third-party utilities for some drives
PIO Mode 3 maximum (11.1 MB/s theoretical)
Use Apple Drive Setup 1.0.3 or later for best compatibility
Floppy Drive Issues
Floppy Drive Diagnostics
Symptom
Possible Cause
Recommended Action
Disk won't eject
Mechanical failure
Manual eject with straightened paperclip
Disks not recognized
Dirty heads
Clean with head cleaning disk
Read errors on all disks
Worn heads
Replace floppy drive mechanism
Drive accepts disk but won't read
Misaligned heads
Professional realignment or drive replacement
Disk icon with X at startup
No bootable disk
Insert system disk or check HD
CD-ROM Drive Issues
CD-ROM Diagnostics
Symptom
Possible Cause
Recommended Action
Drive tray won't open
Mechanical failure
Use emergency eject hole with paperclip
CDs not recognized
Dirty lens
Clean with CD lens cleaner
Audio CDs work, data CDs fail
Software issue
Verify CD-ROM drivers installed
SCSI ID conflict
Incorrect configuration
Check CD-ROM SCSI ID (typically 3)
Intermittent recognition
SCSI termination
Verify proper SCSI chain termination
CD-ROM Notes
The internal CD-ROM uses SCSI, not IDE:
Apple CD 300i Plus (2X speed)
SCSI ID typically set to 3
External SCSI devices need proper termination
DOS Compatibility Card Issues
For LC 630 DOS Compatible and Performa 640 DOS Compatible models:
DOS Card Troubleshooting
Symptom
Possible Cause
Recommended Action
DOS mode won't start
Card not seated
Reseat card in CPU socket and PDS slot
Blue screen in DOS mode
RAM issue
Check DOS card SIMM if installed
No sound in DOS mode
Driver issue
Reinstall SoundBlaster drivers
Joystick not working
Port issue
Check joystick port connection on card
Windows 95 unstable
CPU upgrade issue
Some 486 upgrades incompatible with Win95
"No PC card found" in PC Setup
Connection failure
Remove and reseat entire DOS card assembly
Mac freezes when switching to PC
Software conflict
Update PC Setup to latest version
PC mode shows wrong resolution
Configuration issue
Adjust in PC Setup control panel
DOS Card Seating Procedure
Disconnect DOS card from PDS slot first
Carefully lift lower board from CPU socket
Inspect contacts for corrosion
Clean with DeoxIT if necessary
Reinstall lower board in CPU socket
Reconnect upper board to PDS slot
Verify joystick port alignment
CPU Upgrade Compatibility
If you've upgraded the 486 processor:
Upgrade
Compatibility
Cyrix 5x86-100GP
Recommended; stable
Intel 486DX4-100
Windows 95 may be unstable
AMD 5x86-133
Requires voltage interposer; may be unstable
Capacitor Failure Symptoms
Capacitor-Related Failures
Symptom
Typical Cause
Resolution
Won't power on at all
Failed power filtering caps
Full recap of logic board
Powers on, no chime
Audio circuit caps failed
Recap; check AWACS chip
Intermittent crashes
General capacitor degradation
Full recap recommended
Brown residue on logic board
Electrolyte leakage
Clean thoroughly; recap immediately
Corrosion around caps
Advanced leakage
Clean with vinegar then IPA; repair traces if damaged
The LC 630 logic board contains 9 SMD electrolytic capacitors:
3× 100µF 6.3V
6× 47µF 16V
Refer to Macintosh LC 630 Capacitor Replacement Guide for specifications and procedures.
PRAM/NVRAM Issues
PRAM-Related Problems
Symptom
Possible Cause
Recommended Action
Wrong date/time on each boot
Dead PRAM battery
Replace 4.5V alkaline battery
Wrong startup disk selected
Corrupted PRAM
Zap PRAM: Cmd-Opt-P-R at startup
Monitor settings not saved
Dead battery or corrupt PRAM
Replace battery; zap PRAM
System asks for time zone always
Battery failure
Replace 4.5V battery
Zapping PRAM
Restart the Mac
Immediately hold Command-Option-P-R
Wait for second startup chime
Release keys
Software Compatibility
Supported System Software
Version
Compatibility
Notes
System 7.1.2
Minimum
Requires Enabler 405
System 7.5.x
Recommended
Best 68K compatibility
Mac OS 7.6.1
Compatible
Stable on 68040
Mac OS 8.0
Compatible
Works but slower
Mac OS 8.1
Maximum
Last supported version
Mac OS 8.5+
Not compatible
Requires PowerPC
Software Notes
68LC040 has no FPU—software requiring FPU will fail
Full 68040 upgrade adds hardware FPU support
Some games and CAD software require FPU
SoftwareFPU can emulate FPU in some cases
Quick Diagnostic Checklist
Check power cable and outlet
Verify monitor connection and power
Listen for startup chime
Check for Sad Mac error code
Zap PRAM (Cmd-Opt-P-R)
Reseat RAM SIMMs
Reseat expansion cards
Inspect for capacitor leakage
Test with known-good peripherals
Related Pages
