Macintosh Quadra 700 Troubleshooting
Revision as of 00:08, 16 July 2026 by Josh (talk | contribs) (Expand troubleshooting: PRAM battery bomb, tantalum board (no recap), PSU recap; cited)
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh Quadra 700'\\. This guide covers the most common problems and their solutions.
Preliminary Checks
  • Verify power outlet is working with another device
  • Check that the power cable is fully seated
  • Ensure the voltage selector (if present) matches your local voltage
  • Disconnect all external peripherals except keyboard and mouse
  • Remove any NuBus or PDS cards temporarily
Power Supply Specifications
Parameter Specification
Input Voltage 100V โ€“ 240V AC
Frequency 50 โ€“ 60 Hz
Maximum Power 50W
+5V Rail 4.85V โ€“ 5.15V
+12V Rail 11.9V โ€“ 12.7V
No Power (Unit Dead)
No response when power key pressed Dead PRAM battery Replace 3.6V lithium battery
No response when power key pressed Failed power supply Test PSU output voltages; replace if out of spec
No response when power key pressed Bad power cable Test with known-good cable
Power light on, no startup Failed soft power circuit Check keyboard power key circuit on logic board
Intermittent power Loose power connector Reseat power supply connector; check solder joints
Clicking/ticking sound Power supply overload or short Disconnect drives; test with minimal configuration
Power-On Circuit
The Quadra 700 uses soft power, controlled by the power key on the ADB keyboard. If the keyboard power key does not work:
  • Test with a different ADB keyboard
  • Check the ADB port and cable
  • The programmer's switch on the side can force power-on (interrupt button held during plug-in)
Startup Chime but No Video
Video Issues
Chime, no video on internal VRAM failure Reseat VRAM SIMMs; test with 512 KB onboard only
Chime, no video on internal Video circuit failure Test with NuBus video card
Chime, no video on internal Monitor or cable issue Test monitor with another source
Garbled or distorted video Bad VRAM SIMM Remove expansion VRAMs; test individually
Incorrect colors VRAM configuration issue Verify all 6 VRAM slots populated identically
Video Output Configuration
The Quadra 700 outputs video through a DB-15 connector. Ensure you are using the correct adapter for your monitor type. The system can detect monitor type through sense pins in the connector.
Stability Issues
Random freezes Bad RAM Test RAM modules individually; replace faulty SIMMs
Freezes during disk access SCSI termination issue Verify proper termination at end of SCSI chain
Freezes during disk access Failing hard drive Run disk diagnostics; backup and replace drive
Freeze after warmup Thermal issue Check fan operation; clean dust from heatsink
Intermittent startup Dirty contacts Clean SIMM and expansion card contacts with DeoxIT
Sad Mac Error Codes
See the Sad Mac Error Codes page for a full list. Common codes for the Quadra 700:
Error Code Meaning
0000000F 00000001 ROM test failed
0000000F 00000002 Memory (RAM) test failed
0000000F 00000003 Memory addressing test failed
0000000F 00000004 Memory cell test failed
0000000F 00000005 Memory odd/even logic test failed
0000000E xxxxxxxx SCSI chip failure or conflict
For RAM-related Sad Mac errors, try:
  • Removing expansion SIMMs and testing with onboard RAM only
  • Reseating SIMM modules
  • Testing each SIMM bank individually
  • Cleaning SIMM contacts
Floppy Drive Issues
Floppy Drive Troubleshooting
Disk not ejecting Failed eject motor Replace eject motor or entire drive
Disk not ejecting Mechanical obstruction Check for debris; clean mechanism
Read/write errors Dirty heads Clean heads with isopropyl alcohol
Drive not recognized Cable issue Reseat or replace internal ribbon cable
Constant disk grinding Drive failure Replace SuperDrive mechanism
SCSI Issues
The Quadra 700 uses the NCR 53C96 SCSI controller.
External drives not seen Improper termination Terminate last device in chain only
SCSI ID conflicts Duplicate IDs Ensure each device has unique ID (0-6)
Slow performance Poor cable quality Use quality shielded SCSI cables
Intermittent access Loose connections Check all SCSI connectors
The internal hard drive should be set to SCSI ID 0. External devices should use IDs 1-6 (ID 7 is reserved for the host).
Networking Issues
No Ethernet connectivity Missing transceiver AAUI port requires external transceiver
Intermittent connection Bad transceiver Test with known-good AAUI transceiver
No LocalTalk Cable/termination issue Check LocalTalk connectors and termination
NuBus/PDS Card Issues
Card not recognized Poor contact Reseat card firmly; clean edge connector
System crash with card Card conflict Test card alone; check for resource conflicts
PDS card blocks NuBus Physical interference PDS slot blocks one NuBus slot by design
โš ๏ธ PRAM battery โ€” remove it now
The Quadra 700 carries a 3.6 V 1/2AA lithium PRAM battery. These leak and can burst, spraying corrosive electrolyte across the logic board and destroying nearby components — often while the machine simply sits in storage. Remove the PRAM battery from any un-serviced unit. If one has leaked, neutralise and clean the residue and repair corroded traces and vias before troubleshooting.[1]
Unlike the LC and Mac II surface-mount-electrolytic boards, the 68040-family Quadra 700 logic board uses tantalum capacitors, which do not leak with age — the logic board does not normally need recapping. If the board misbehaves, look to leaked-PRAM-battery corrosion, socket/connector contacts and the power supply rather than to board capacitors.[2]
  1. โ†‘ "Warning! Exploding Maxell PRAM Batteries", 68kMLA; and MacDat — Macintosh II family. Source for the leaking/exploding lithium PRAM battery that destroys nearby components.
  2. โ†‘ "Apple Macintosh Quadra 650", Retro Viator; and the Apple Macintosh Quadra/Centris 650 Service Source. Source for the 68040-family logic boards using tantalum capacitors (no logic-board recap needed) while the power supply uses electrolytics that do need replacing.
  3. โ†‘ "Compact/Desktop Power Supply Capacitor Lists (by make and model)", 68kMLA; and "Capacitor Replacement in a Vintage Power Supply", Big Mess o' Wires. Source for the shared desktop PSU form factor (IIci/IIcx/IIvi/IIvx/Performa 600/Quadra 650/Quadra 700), the electrolytic failure symptoms and the PSU capacitor lists.
