This guide covers common issues and diagnostic procedures for the Macintosh LC 475.
Preliminary Checks
- Power cable is securely connected.
- Monitor cable is properly attached.
- Keyboard and mouse are connected to ADB port.
- No external SCSI devices are causing conflicts.
No Power
No Power Diagnostics
| Symptom |
Possible Cause |
Action
| Completely dead, no fan |
Power supply failure |
Check power supply capacitors; test with known-good PSU
| Clicks or ticks repeatedly |
Short circuit or capacitor failure |
Inspect logic board for shorts
| Fan spins briefly, then stops |
Thermal protection or PSU fault |
Check PSU output voltages
| LED on but no startup |
Logic board issue |
Reset PRAM (Cmd+Opt+P+R); inspect board
Power Supply Voltages
- +5V rail: 4.85V – 5.15V
- +12V rail: 11.9V – 12.7V
Chimes but No Video
Chime But No Video
| Symptom |
Possible Cause |
Action
| Normal chime, black screen |
VRAM failure or video circuit issue |
Reseat VRAM SIMMs; test with different monitor
| Chime with garbage display |
VRAM or logic board damage |
Check VRAM SIMMs
| Distorted or shifted image |
Video timing issue |
Check video output connector
Startup Chime Errors
Error Chime Codes
| Chime Pattern |
Meaning |
Action
| No chime |
CPU or ROM failure |
Reseat CPU; inspect logic board
| Single tone (not normal chime) |
RAM failure |
Reseat 72-pin SIMM; test with different SIMM
| Four tones (ascending) |
RAM failure |
Replace RAM SIMM
Sad Mac Errors
Sad Mac Error Codes
| Code |
Meaning |
Action
| 0000000F / 00000001 |
ROM test failure |
ROM or logic board problem
| 0000000F / 00000002 |
Memory test failure |
Check RAM SIMM
| 0000000F / 00000003 |
Memory addressing error |
Reseat or replace RAM
Intermittent Operation
Intermittent Issues
| Symptom |
Possible Cause |
Action
| Random freezes |
Capacitor failure, bad RAM, or CPU issue |
Recap board; test RAM; reseat CPU
| Works when cold, fails when warm |
Thermal-related component failure |
Inspect for dry solder joints; check CPU seating
| Spontaneous restarts |
Power supply instability |
Check PSU capacitors and output voltages
SCSI Problems
SCSI Troubleshooting
| Symptom |
Possible Cause |
Action
| Hard drive not recognized |
SCSI ID conflict or cable issue |
Check SCSI ID (drive should be ID 0); reseat cables
| Flashing question mark |
No bootable system found |
Boot from floppy; check hard drive
| External devices not detected |
Termination or ID issue |
Verify termination; check all SCSI IDs are unique
Floppy Drive Issues
Floppy Drive Problems
| Symptom |
Possible Cause |
Action
| Disk not ejecting |
Mechanical jam |
Manually eject; check mechanism
| Cannot read disks |
Dirty heads |
Clean heads with IPA
| Disks not recognized |
Drive failure |
Test with known-good drive
CPU Issues
The 68LC040 is socketed and can develop contact issues:
CPU Problems
| Symptom |
Possible Cause |
Action
| No boot, no chime |
CPU not seated properly |
Remove and reseat CPU carefully
| Random crashes |
Poor CPU contact |
Reseat CPU; clean socket contacts
| FPU-dependent software crashes |
Using 68LC040 (no FPU) |
Upgrade to full 68040, or use software FPU emulator
Audio Issues
Audio Problems
| Symptom |
Possible Cause |
Action
| No sound output |
Capacitor failure in audio circuit |
Recap logic board
| Mono output only |
Damaged stereo circuit |
Check audio capacitors and output jack
| Distorted audio |
Failing capacitors |
Replace capacitors
Related Pages
