Macintosh IIvx Troubleshooting
Revision as of 12:32, 9 February 2026 by Josh (talk | contribs) (Created IIvx troubleshooting guide)
This guide covers common faults with the Macintosh IIvx, including startup failures, video problems, CD-ROM issues, and storage errors.
Preliminary Checks
  • Verify the power cable is secure
  • Test with a known-good outlet
  • Disconnect all external SCSI devices
  • Remove any NuBus or PDS cards
  • Check for visible capacitor leakage or battery corrosion
No Power
Power Issues
Symptom Possible Cause Action
Completely dead Blown fuse, failed PSU, bad cord Check outlet; test power cord; check PSU fuse
Clicking or ticking Failed PSU capacitors Recap power supply
Powers on briefly then dies Overload protection, shorted component Disconnect cards and drives; test with minimal config
Fan spins but no startup Dead PRAM battery, failed logic board Replace PRAM battery; check for capacitor damage
Startup Failures
Startup Problems
No chime, no video Dead logic board, failed capacitors Recap logic board; check PRAM battery
Chime but no video VRAM issue, video connector Reseat VRAM SIMMs; check video cable
Sad Mac error Hardware failure Decode error code; test RAM
Flashing question mark No boot device Check SCSI drive; verify termination
Chimes of death RAM failure Reseat or replace RAM SIMMs
Sad Mac Error Codes
Common Sad Mac Codes
Code Range Meaning Action
01XXXX ROM test failure Check for corrosion; may need logic board repair
02XXXX – 05XXXX RAM test failure Try different SIMMs; clean SIMM slots
0DXXXX NuBus card failure Remove all NuBus cards
0EXXXX SCSI controller failure Check for capacitor damage
0FXXXX Data bus failure Logic board damage
See Sad Mac Error Codes for complete reference.
Video Problems
Display Issues
No video after chime VRAM failure, cable issue Reseat VRAM; check video cable and monitor
Distorted or garbled VRAM configuration, bad VRAM Ensure matching VRAM SIMMs; try removing VRAM upgrade
Wrong colors VRAM issue, video DAC Reseat VRAM; check for capacitor damage
Flickering Loose cable, monitor issue Check video cable; test with different monitor
Audio Problems
Sound Issues
No startup chime Audio circuit failure, capacitor damage Recap logic board
Distorted audio Failed capacitors Recap logic board
No audio through jack Jack issue, cable Test with different cable/speakers
CD-ROM Issues
CD-ROM Problems (if installed)
Drive not recognized SCSI ID conflict, loose cable Check SCSI ID (usually 3); reseat ribbon cable
Disc not reading Dirty lens, worn laser Clean lens with CD lens cleaner
Tray won't open Mechanical failure, stuck tray Use emergency eject hole (paperclip); lubricate mechanism
Audio CDs work but data CDs don't Driver issue, laser calibration Reinstall CD-ROM driver; laser may be failing
Slow performance Dirty lens, failing drive Clean lens; 2X drives are slow by design
Serial Port Issues
The IIvx serial ports are limited to 57.6 kbit/s:
Serial Port Problems
Modem connection fails Speed limitation Configure modem for 57.6 kbit/s or lower
MIDI timing problems Port speed insufficient Use external MIDI interface card
Printing slow or fails Speed setting Check printer driver settings
SCSI and Storage
Drive Problems
Flashing question mark No bootable System Check SCSI drive; verify cable; test with boot floppy
Drive not recognized Wrong SCSI ID, termination Verify unique SCSI IDs; check termination
System freezes during boot SCSI bus conflict Disconnect all SCSI; add one at a time
Floppy not reading Dirty heads, failed drive Clean heads; test with different disks
SCSI Termination
  • Internal hard drive: terminated (usually SCSI ID 0)
  • Internal CD-ROM (if installed): usually SCSI ID 3, not terminated
  • External devices: terminate only the last device in chain
  • Verify each device has a unique SCSI ID (0–6)
Capacitor Failure Symptoms
Symptom Likely Cause Solution
Random crashes Failed logic board caps Full logic board recap
Audio distortion Caps near audio circuit Recap logic board
No startup Power or reset circuit caps Recap; check traces
Intermittent operation Multiple failing caps Full recap
See Macintosh IIvx Capacitor Replacement Guide for procedures.
