BBC Micro Model A/B Troubleshooting Guide
Revision as of 21:28, 9 August 2025 by Josh (talk | contribs)
This guide details systematic troubleshooting for the BBC Micro Model A and Model B home computers. These classic 8-bit systems are robust but now decades old, so methodical diagnosis is essential for reliable restoration and repair.
Preliminary & Power-up Checks
Begin by confirming the BBC Micro receives correct voltages and basic startup conditions. Many faults stem from power or socket issues rather than failed chips.
Visual & Basic Checks
  • Remove the top cover; inspect for burnt components, corrosion, or bulging capacitors.
  • Check all socketed ICs are firmly seated.
  • Inspect the power supply for leaking capacitors or burnt smell.
  • Confirm the keyboard ribbon cable is securely connected.
Power Supply Voltages
5V rail (IC pin 14/40, e.g. 6502 CPU) +5 V DC (±5%) Main logic supply
12V rail (disk interface, if fitted) +12 V DC Only present on Model B or upgraded A
-5V rail (RAM, if fitted) -5 V DC Required for some DRAMs (early Issue 3/4 boards)
RESET line (IC pin 40, 6502) Low → High Should pulse low at power-on, then remain high
  • If any rail is missing or out of tolerance, recap or repair the PSU before further diagnosis.*
Power-up Sequence
  1. Switch on the unit.
  2. Confirm the red power LED lights.
  3. Listen for a single "beep" from the speaker.
  4. Observe the display for a white or black screen with a cursor and "BBC Computer" banner.
If any of these are missing, proceed to the next section.
Display & Chime Diagnostics
The BBC Micro provides clear visual and audio cues at startup. Use these to narrow down faults.
Symptom Probable Cause(s) Diagnostic Action
No display, no beep No power, PSU failure, blown fuse, shorted IC Check PSU voltages, inspect fuses, feel for hot chips
No display, but beep present Video circuit failure, ULA (IC6), bad socket Check video output, swap ULA if possible
Display present, no beep Speaker, sound IC (IC18), CPU not running code Check speaker, test with external speaker, probe CPU activity
"Scrolling" or unstable display Wrong video mode, bad crystal, ULA fault Try MODE 7, check 16 MHz/8 MHz clock, swap ULA
Garbage or random characters RAM fault, CPU fault, ROM not read See memory/ROM section, check CPU clock/reset
"Language?" prompt or "No ROM at ..." OS ROM or language ROM missing/faulty Reseat ROMs, replace as needed
Video Output Types
  • Composite video (BNC or phono) – test with a known-good monitor.
  • RGB output (6-pin DIN) – check cable and monitor compatibility.
  • UHF output (RF modulator) – test with analogue TV, channel 36 (UK).
Memory & ROM Faults
RAM and ROM failures are common in ageing BBC Micros, especially with original DRAM chips.
RAM Faults
Symptom Likely Cause Diagnostic Steps
No boot, continuous beep Lower 16K RAM failure Touch DRAMs for excess heat, piggy-back known-good 4116/4164, check -5V rail
"Bad RAM" message, random crashes Upper 16K RAM fault (Model B) Swap upper bank DRAMs, check for dry joints
Corrupt screen, random characters Address/data bus fault, RAM chip Logic probe address/data lines, swap suspected DRAM
  • Early Model A: only lower 16K fitted. Model B: both banks (32K total).*
ROM Faults
Symptom ROM Involved Action
"Language?" prompt BASIC ROM missing/faulty Reseat or replace BASIC ROM (IC52)
"No ROM at ..." Any sideways ROM Reseat or replace named ROM
No boot, black screen OS ROM (IC51) Swap with known-good OS ROM
  • ROMs are typically 27128 or 27128-compatible EPROMs; always observe correct orientation.*
Connector & Socket Issues
Loose or oxidised sockets are a frequent cause of intermittent faults.
  • Reseat all socketed ICs, especially the ULA (IC6), CPU (IC1), and ROMs (IC51/IC52).
  • Clean edge connectors (user port, 1 MHz bus, Tube, etc.) with isopropyl alcohol.
  • Inspect keyboard ribbon and connectors for cracks or poor contact.
  • Check for broken solder joints on the power socket and video connectors.
Component-level Tests
Clock & Reset
  • 6502 CPU (IC1) pin 37: should show a stable 2 MHz clock.
  • ULA (IC6): generates system clocks; check for activity on pins 35 (16 MHz), 39 (8 MHz).
  • RESET (CPU pin 40): should pulse low at power-on, then remain high.
Piggy-back & Substitution
  • Carefully piggy-back a known-good DRAM on top of each suspect chip.
  • Swap socketed chips (ULA, CPU, ROMs) one at a time with known-good parts.
Logic Probing
  • Probe address/data lines for stuck-high or stuck-low signals.
  • Check for activity on the NMI and IRQ lines (CPU pins 6 and 4).
Audio & I/O Failures
Symptom Probable Cause Action
No beep or sound Faulty speaker, sound IC (IC18), ULA Test speaker, swap sound IC, check ULA
Keyboard dead Faulty keyboard, ribbon, 6522 VIA (IC3) Test keyboard on another BBC, check ribbon, swap VIA
Cassette not working Faulty relay, op-amp (IC7), socket Listen for relay click, check op-amp, clean sockets
Joystick/user port not working 6522 VIA (IC3), bad port Swap VIA, inspect port soldering
Storage & Expansion Issues
Floppy Disk Problems (Model B or upgraded A)
  • No drive activity: check 1770/8271 disk controller, drive power, ribbon cable.
  • "Drive not ready" or "No drive": check drive select jumpers, cable orientation.
  • Disk errors: clean drive heads, try known-good drive.
Cassette Interface
  • "Loading" message but no progress: check cassette relay, op-amp (IC7), cable.
  • No relay click: check relay driver transistor (Q2), 5V rail.
Cartridge/ROM Expansion
  • "No ROM at ..." or language not found: check sideways ROM sockets, orientation, and supply voltage.
Error & Beep Code Table
The BBC Micro uses beep codes for basic error reporting at power-on.
Beep Pattern Meaning Likely Cause
Continuous tone RAM failure (lower 16K) One or more DRAMs faulty
Single beep Normal startup System healthy
No beep CPU, ULA, or ROM fault Check CPU, ULA, OS ROM
Final Notes
  • Always start with power and visual checks before replacing chips.
  • Fit sockets when replacing DRAMs or major ICs for future serviceability.
  • Many faults are due to poor connections or aged sockets—reseating often cures intermittent issues.
  • Never operate the BBC Micro with missing or incorrect voltage rails, especially -5V on early DRAM boards.
