Atari 65XE Troubleshooting Guide
This guide covers detailed troubleshooting of the Atari 65XE 8-bit home computer. It addresses typical failure symptoms, diagnostic steps and component-level remedies for common faults affecting PAL and NTSC models. Use these procedures to restore a non-booting, unstable or otherwise faulty 65XE to reliable operation.
Preliminary & Power-up Checks
Begin with basic power and visual checks before suspecting major component failure.
- Disconnect all peripherals (cartridges, SIO, joystick, cassette).
- Remove the top cover; inspect for burnt, cracked or corroded components—especially around the power jack, voltage regulator, and mainboard edge connectors.
- Confirm the power supply outputs +5V DC (measure at the power input or across any major IC’s Vcc and GND pins).
- Inspect for leaking or bulging electrolytic capacitors, especially C56 (input filter) and C57 (regulator output).
- Check for loose or oxidised IC sockets (RAM, ROM, custom chips).
- Ensure the power switch is not intermittent or oxidised.
Power Supply & Voltage Table
| Test Point | Expected Voltage | Notes |
| Power input jack (centre) → GND | +5 V DC (±5%) | Main logic supply |
| 7805 regulator input (pin 1) | 8–12 V DC | From external PSU |
| 7805 regulator output (pin 3) | +5 V DC | Should be stable under load |
| Any IC Vcc pin | +5 V DC | Check at RAM, CPU, GTIA, ANTIC |
Common PSU faults:
- No power-on LED, no video – check PSU fuse, cable, and 7805 regulator.
- Repeated resets, random crashes – suspect dried-out capacitors or failing 7805.
- Overvoltage (>5.5 V) – can destroy RAM or custom ICs rapidly.
Display & Chime Diagnostics
The 65XE should display a blue READY prompt and beep on successful boot. If not, use the following table to narrow down the fault:
| No video, no sound, power LED off | Dead PSU, blown fuse, bad switch | Test/replace PSU, check fuse, clean switch |
| Black screen, power LED on | RAM, CPU, ROM, or custom chip failure | See “Black Screen” flowchart below |
| Solid colour screen (no text) | ROM or RAM fault | Reseat/replace ROM, test RAM |
| Garbage characters, unstable display | RAM fault, bad socket, bus contention | Swap/test RAM, clean sockets |
| Rolling/no sync video | Bad GTIA, ANTIC, or crystal | Swap GTIA/ANTIC, check clock |
| No beep at power-on | Bad POKEY, speaker, or CPU | Test/replace POKEY, check speaker wiring |
“Black Screen” (No Boot) Flowchart
- Confirm +5 V at mainboard and ICs.
- Check for a brief beep or click at power-on (if present, CPU/ROM likely running).
- Swap/feel GTIA, ANTIC, CPU (6502C), and POKEY in turn (if socketed).
- Reseat or substitute OS ROM and BASIC ROM.
- Test RAM chips (see below).
- Inspect for shorted decoupling capacitors or burnt resistors near the power input.
Memory & ROM Faults
The 65XE uses eight 4164 DRAMs (U12–U19) and two ROMs: OS (U3) and BASIC (U4). RAM and ROM failures are among the most common causes of boot problems.
RAM Faults
| Symptom | Probable Cause | Action |
| Black screen, no beep | Lower RAM failure (U12–U15) | Replace suspected DRAM(s) |
| Garbage screen, freezes | Upper RAM failure (U16–U19) | Replace DRAM(s), check address lines |
| Random characters, “Error” on boot | Partial RAM failure | Swap/test RAM, check for hot chips |
Diagnosis:
- Touch each DRAM after 1–2 minutes – a failed chip may run hot.
- Piggy-back a known-good 4164 on each suspect chip; if boot improves, replace the underlying chip.
- Use a RAM test cartridge (e.g. Atari Diagnostics, SALT) for precise identification.
ROM Faults
| Blue screen, no READY prompt | BASIC ROM failure (U4) | Replace BASIC ROM |
| No display, no beep | OS ROM failure (U3) | Replace OS ROM |
| Boots cartridge but not to BASIC | BASIC ROM bad | Replace BASIC ROM |
Note: Cartridges override internal ROMs; if a cartridge boots but normal BASIC does not, the fault is in the OS or BASIC ROM.
Connector & Socket Issues
Many 65XE faults are due to poor connections, especially after years of use.
- Reseat all socketed ICs (RAM, ROM, custom chips).
- Clean edge connectors (cartridge, SIO, joystick) with isopropyl alcohol.
- Inspect for cracked solder joints at the power jack, SIO, and joystick ports.
- Check for broken traces near the keyboard connector and cartridge slot.
- Test continuity from each port pin to its corresponding PCB pad.
Component-level Tests
Clock & Reset Signals
- Confirm system clock (1.79 MHz NTSC / 1.77 MHz PAL) at pin 39 of the 6502C CPU.
- RESET line (CPU pin 40) should pulse low at power-on, then remain high (+5 V).
- If no clock, suspect the crystal (Y1), GTIA, or ANTIC.
- If RESET stuck low, check C50, R114, and associated reset circuitry.
Voltage Test Points
| Location | Expected Voltage | Notes |
| 6502C Vcc (pin 8) | +5 V DC | Main CPU supply |
| GTIA Vcc (pin 24) | +5 V DC | Video logic |
| DRAM Vcc (pin 8) | +5 V DC | All RAM chips |
Audio & I/O Failures
The POKEY chip (U7) generates sound and handles keyboard, serial, and paddle input.
| No sound, but boots | Bad POKEY, speaker, or amp | Replace POKEY, test speaker |
| Keyboard unresponsive | Bad POKEY, keyboard membrane, or connector | Test/replace keyboard, check POKEY |
| Joystick port not working | Bad solder joint, trace break, or POKEY | Reflow joints, continuity test, replace POKEY |
| SIO (disk/tape) not detected | SIO connector, POKEY, or 74LS logic | Clean connector, check U5/U6 (logic) |
- Test the speaker by applying 1.5 V briefly; if it clicks, the speaker is good.
- For keyboard faults, test continuity from the keyboard connector to the POKEY IC.
Cartridge & Peripheral Failures
- If the system boots with a cartridge but not without, suspect the BASIC or OS ROM.
- If no cartridge boots, check the cartridge slot for bent pins or cracked solder joints.
- SIO (serial) failures often trace to U5/U6 (74LS logic), POKEY, or the SIO connector itself.
- Cassette motor control issues may be due to Q1 (transistor) or associated driver circuitry.
Error & Code Tables
The 65XE does not display detailed error codes, but certain patterns are diagnostic:
| Symptom/Pattern | Interpretation |
| Black screen, no beep | Major RAM, ROM, or CPU failure |
| Blue screen, no READY | BASIC ROM or RAM fault |
| Boots with cartridge only | Internal ROM failure |
| Beep but no display | Video (GTIA/ANTIC) failure |
Final Notes
- Always start with power and visual checks.
- Use a known-good power supply and test cartridges for diagnosis.
- Statistically, most common failures: RAM → ROM → POKEY → GTIA/ANTIC → CPU.
- Fit sockets when replacing chips for future serviceability.
- Avoid prolonged operation with a faulty PSU—overvoltage quickly destroys custom ICs.
Diagnostic order and the Star Raiders test
On the Atari 8-bit machines the components fail, statistically, in this order: RAM → OS ROM → POKEY → GTIA/ANTIC → CPU. Work through them in that order. The Star Raiders cartridge is a quick diagnostic: it exercises ANTIC, the CPU and GTIA/CTIA, so if it runs those three are good and the fault is narrowed to the PIA, the OS ROM, the MMU or the RAM. Before swapping chips, leave the machine powered for about ten minutes and feel for an overheating RAM chip, and make sure the RAM, OS ROM, ANTIC, MMU, PIA and CPU are all fully seated (reseating cures many garbage-screen / no-boot faults).[1]
Power and clock
- Power: the external "ingot" supply, an oxidised power switch and a cracked DC power connector all cause dead or intermittent operation. Check the switch and connector, and test/replace the 470 uF 16 V radial electrolytic in the left-rear corner of the board.[1]
- CPU clock and reset: check for a clean 1.79 MHz clock at the 6502/SALLY (pin 37), and that RESET pulses low then high at power-up. A RESET stuck low points to the reset circuit.[1]
Keyboard and POKEY
POKEY scans the keyboard and generates the sound and the SIO serial signals. A dead keyboard while sound still works is a classic POKEY (or keyboard-membrane) fault; SIO/peripheral problems also point to POKEY.[1]
Internal BASIC (XL/XE)
The XL/XE machines have BASIC built in. A bad internal BASIC ROM can stop the machine booting; hold OPTION at power-on to disable internal BASIC as a test (and to run software that needs BASIC off). If the machine boots with OPTION held but not without, suspect the BASIC ROM.[1]
- ↑ 1.0 1.1 1.2 1.3 1.4 Atari 8-bit pictorial fault guide, 8bithardware; Black Screen [XL/XE Fix Checklist], Atari Owners Club; and AtariAge repair threads. Source for the RAM→ROM→POKEY→GTIA/ANTIC→CPU failure order, the Star Raiders diagnostic cartridge, the seated-socket checks, the PSU 470 uF capacitor and switch/connector faults, and the SALLY 1.79 MHz clock/reset checks.
