Macintosh LC III Troubleshooting
Revision as of 23:48, 15 July 2026 by Josh (talk | contribs) (Expand troubleshooting: exploding PRAM battery, SMD-cap leakage (chime-but-no-video), PSU recap; cited (68kMLA/Quagmire/Service Source))
This guide covers common issues and diagnostic procedures for the Macintosh LC III.
Preliminary Checks
  • Power cable is securely connected.
  • Monitor cable is properly attached.
  • Keyboard and mouse are connected to ADB port.
  • No external SCSI devices are causing conflicts.
No Power
No Power Diagnostics
Symptom Possible Cause Action
Completely dead, no fan Power supply failure Check power supply capacitors; test with known-good PSU
Clicks or ticks repeatedly Short circuit or capacitor failure Inspect logic board for leaked capacitors; check for shorts
Fan spins briefly, then stops Thermal protection or PSU fault Check PSU output voltages; inspect for overheating
LED on but no startup Logic board issue Reset PRAM (Cmd+Opt+P+R); inspect for capacitor damage
Power Supply Voltages
  • +5V rail: 4.85V – 5.15V
  • +12V rail: 11.9V – 12.7V
Chimes but No Video
Chime But No Video
Normal chime, black screen VRAM failure or video circuit issue Reseat VRAM SIMM; test with different monitor
Chime with garbage display VRAM or logic board damage Check VRAM; inspect for capacitor leakage near video circuit
Distorted or shifted image Video timing issue Check video output connector; try different monitor cable
Startup Chime Errors
Error Chime Codes
Chime Pattern Meaning Action
No chime CPU or ROM failure Inspect logic board; check ROM
Single tone (not normal chime) RAM failure Reseat 72-pin SIMM; test with different SIMM
Four tones (ascending) RAM failure Replace RAM SIMM
Sad Mac Errors
A Sad Mac icon with error codes indicates hardware failure:
Sad Mac Error Codes
Code Meaning Action
0000000F / 00000001 ROM test failure ROM or logic board problem
0000000F / 00000002 Memory test failure Check RAM SIMM
0000000F / 00000003 Memory addressing error Reseat or replace RAM
Intermittent Operation
Intermittent Issues
Random freezes Capacitor failure or bad RAM Recap logic board; test RAM
Works when cold, fails when warm Thermal-related component failure Inspect capacitors; check solder joints
Spontaneous restarts Power supply instability Check PSU capacitors and output voltages
Corrupted graphics after warmup VRAM or video circuit failure Reseat VRAM; check for capacitor damage
SCSI Problems
SCSI Troubleshooting
Hard drive not recognized SCSI ID conflict or cable issue Check SCSI ID (drive should be ID 0); reseat cables
Flashing question mark No bootable system found Boot from floppy; check hard drive
External devices not detected Termination or ID issue Verify termination; check all SCSI IDs are unique
Floppy Drive Issues
Floppy Drive Problems
Disk not ejecting Mechanical jam or failed eject motor Manually eject with paperclip; check mechanism
Cannot read disks Dirty heads or misalignment Clean heads with IPA; try different disks
Disks not recognized Drive failure or controller issue Test with known-good drive; check ribbon cable
FPU Issues
If you have installed an optional 68882 FPU:
FPU Problems
FPU not detected by software Poor socket contact Reseat FPU; check for bent pins
System unstable after FPU install Wrong FPU speed Use 25 MHz or faster 68882
Crashes in FPU-intensive apps Defective FPU Test with different 68882
Audio Issues
Audio Problems
No sound output Capacitor failure in audio circuit Recap logic board
Distorted audio Failing capacitors Replace capacitors
Crackling or popping Bad solder joints or capacitors Reflow solder joints; replace capacitors
The Macintosh LC III uses a 3.6 V 1/2AA lithium PRAM battery (often a red Maxell). These are notorious for leaking and even exploding, spraying corrosive electrolyte across the logic board — a battery can burst while the machine sits in storage and destroy the board. Remove the PRAM battery from any un-serviced unit immediately. If one has leaked, neutralise and clean the residue and check the traces and vias around the battery and the nearby chips for corrosion, repairing any that are damaged.[1]
⚠️ Surface-mount capacitor leakage
The Macintosh LC III logic board uses surface-mount electrolytic capacitors that leak electrolyte from the bottom with age. The leakage corrodes traces and vias and is a leading cause of faults, so recap and clean the board as a first step. A common pattern is a board that chimes but shows no video after servicing — usually corrosion damage (broken traces or vias) around the leaked capacitors (for example near C136/C137), which must be traced and repaired.[2]
The compact LC "pizza-box" power supply also uses electrolytics that leak with age. A dead LC PSU can usually be revived by replacing all its electrolytic capacitors and cleaning the leakage; any working LC PSU should be recapped pre-emptively, as it will otherwise fail. Confirm the +5 V and +12 V rails after servicing.[2]
  1. 1.0 1.1 "Warning! Exploding Maxell PRAM Batteries", 68kMLA; and "Mac Battery Leaks", MacDat. Source for the exploding/leaking Maxell PRAM battery and the resulting board damage, and the LC not booting without a battery.
  2. 2.0 2.1 "Quadra 605 / LC 475", Quagmire Repair; the Apple Macintosh LC/LC II/LC III/LC 475/Quadra 605 Service Source; and "Macintosh LC Recap", PAPPP's Rambling. Source for the SMD-capacitor leakage, the PSU recap, and the trace/via damage causing chime-but-no-video.
