Sinclair ZX Spectrum Troubleshooting Guide
This guide provides detailed, component-level troubleshooting for the Sinclair ZX Spectrum home computer series (16K, 48K, 48K+, 128K, +2, +3). It covers common failure symptoms, diagnostic procedures, and fixes for:
- Power supply faults
- “No display” (blank screen) scenarios
- RAM (4116/4164/41464) faults
- ULA (Uncommitted Logic Array) failures
- ROM and CPU (Z80A) faults
- Keyboard and membrane issues
- Video and audio output faults
- Edge connector and peripheral problems
Differences between major board revisions (Issue 1–6, 128K, +2, +3) are noted where relevant.
Diagnostic Tools & Techniques
Visual Inspection
- Remove the case; inspect for burnt, cracked, or corroded components, especially around the power input, edge connector, and RAM chips.
- Check for cold solder joints—especially on the voltage regulator, RAM, and ULA.
- Look for leaking or bulging capacitors.
Thermal Checks
- After 1–2 minutes of power-on, gently touch (or use an IR thermometer) on the ULA, RAM, and voltage regulator.
- Too-hot-to-touch RAM or ULA often indicates internal failure or short.
- Use freeze spray or compressed air: if behaviour changes when cooling a chip, it is likely faulty.
Power & Signal Probing
- +5 V DC at RAM, ULA, CPU, and ROM Vcc pins.
- -5 V DC and +12 V DC (16K/48K only) at lower RAM (4116) chips.
- RESET line: low at power-on, then high (5 V).
- System clock: 3.5 MHz at Z80 pin 6.
- Composite video at modulator input (before RF conversion).
- ROM chip-enable and RAM multiplexing signals.
Chip Substitution
- Swap socketed chips (ULA, ROM, CPU) one at a time with known-good parts.
- Observe orientation and always power off before removal/insertion.
- For 128K/+2/+3, test with known-good upper/lower RAM chips.
Piggy-back Testing
- Press a good DRAM chip on top of each suspect RAM (pins aligned).
- If symptoms change or machine boots, the underlying IC is bad.
- Warning: Ineffective if the bad chip is shorted; never piggy-back ULA or custom ICs.
Minimal-Configuration Boot
- The Spectrum will not boot without ULA, ROM, or CPU.
- On 16K/48K, you can boot with only lower RAM (16K) fitted; upper RAM (48K) can be removed for testing.
- Disconnect keyboard membrane to rule out shorts.
Power Supply & Voltage Checks
Always verify the PSU before suspecting mainboard faults.
| Test Point | Expected Voltage | Purpose / Notes |
| Regulator input (7812/7805 tab) | +12 V DC | Main supply rail (16K/48K) |
| Regulator output (7805) | +5 V DC (±5%) | Logic rail for CPU, ULA, ROM |
| Lower RAM pin 1 | -5 V DC | Only on 4116 RAM (16K/48K) |
| Lower RAM pin 8 | +12 V DC | Only on 4116 RAM (16K/48K) |
| CPU Vcc (pin 11) | +5 V DC | Z80A supply |
| ULA Vcc (pin 40) | +5 V DC | ULA supply |
| RESET (edge connector pin 16) | Low → High | Must release to 5 V after power-up |
Common PSU Faults
- 5 V missing/high → no boot or chip damage.
- 12 V missing → no video, no sound, or RAM errors.
- -5 V missing → lower RAM (4116) failure, often black screen or stripes.
- Intermittent drop-outs due to cracked power jack solder or faulty regulator.
- Buzzing/hum bars = dried-out capacitors or PSU ripple.
Never run a Spectrum on an unstable PSU; modern regulated adapters are recommended.
“No Display” (Blank Screen) Flowchart
- Check PSU rails (+5 V, +12 V, -5 V), RESET, and clock first.
- Swap/feel ULA (most common failure).
- Replace/logic-probe ROM and CPU (Z80A).
- Test/replace lower RAM (4116) – black screen or stripes often indicate RAM.
- Inspect upper RAM (48K models) – garbage screen or crashes.
- Remove keyboard membrane; check for shorts.
- Inspect modulator and composite video output.
RAM Failures
Lower RAM (16K/48K: 4116)
- Each chip = 1 bit; all 8 must work for 16K operation.
- Needs +5 V, +12 V, and -5 V.
- Failure symptoms: black screen, coloured stripes, random resets, or garbage display.
- One chip hotter than others often indicates failure.
Upper RAM (48K: 4532/4164)
- Adds 32K for 48K total.
- Failure symptoms: boots as 16K, random crashes, corrupted graphics, or “R” errors on startup.
- Can be removed for 16K-only operation.
128K/+2/+3 RAM (41464/4464)
- 8 × 41464 (128K) or 8 × 4464 (256K).
- Failure: random crashes, corrupted display, “RAMTOP” errors, or beeper noise.
Diagnosis / Fix
- Swap suspected chip, or socket & replace.
- If still faulty after RAM swap, check multiplexers (74LS157/74LS32).
- Test for correct voltages at each RAM chip.
ULA (Uncommitted Logic Array) Faults
- The ULA (IC1, Ferranti 5C102E/6C001E/7K010E) is the most failure-prone chip in 16K/48K models.
- Controls video, keyboard, tape I/O, and RAM multiplexing.
Failure Signs
- No display (blank/black screen)
- Vertical or horizontal stripes
- No sync or distorted video
- No sound or tape I/O
- Keyboard unresponsive
Diagnosis / Fix
- Swap with known-good ULA (matching type)
- Check for excessive heat
- Inspect for dry joints on ULA socket
Z80A CPU Faults
- Rare, but possible after over-voltage or static discharge.
Symptoms
- No clock at pin 6, or address/data lines stuck
- No response to RESET
- Dead after ULA and RAM ruled out
Diagnosis / Fix
- Swap with known-good Z80A
- Check for correct clock and RESET signals
ROM Faults
- 16K/48K: 8K ROM (IC5, Sinclair 2364 or 27C64 EPROM)
- 128K/+2/+3: 32K or 64K ROM
Symptoms
- Blank screen or border only
- Corrupt startup screen or “1982 Sinclair Research” missing
- Machine boots with test cartridge but not to BASIC
Diagnosis / Fix
- Swap with known-good ROM or EPROM
- Check chip-enable and address lines
Keyboard and Membrane Issues
- The keyboard membrane is a common failure point (cracks, broken traces).
- Symptoms: unresponsive keys, stuck keys, or no keyboard at all.
- Test with continuity meter; replace membrane if needed.
- On 48K+, check for broken key plungers or springs.
- On 128K/+2/+3, check for loose ribbon cables and corroded connectors.
Video Output Faults
No Video (but power LED on)
- Check composite video at modulator input (bypass RF for testing).
- Suspect ULA, modulator, or video amplifier transistor (TR1/TR2).
Rolling or distorted image
- Wrong ULA type for board revision (PAL/NTSC mismatch)
- Bad clock crystal (14 MHz)
- Faulty modulator or dry joints
Colour missing
- Faulty ULA or modulator
- Check chroma circuit (128K/+2/+3)
Jailbars or checkerboard
- RAM or ULA fault; check for hot chips
Audio Output Faults
- No sound: ULA failure, speaker disconnected, or dry joints.
- Distorted sound: faulty ULA or speaker.
- 128K/+2/+3: check AY-3-8912 sound chip and associated circuitry.
