Macintosh SE Capacitor Replacement Guide
Revision as of 23:06, 4 April 2025 by Josh (talk | contribs)
Replacing electrolytic capacitors (recapping) in your Macintosh SE is essential for maintaining long-term reliability, consistent power delivery, and clean video output. Aging capacitors can cause instability, poor display quality, or outright system failure. Proactively replacing these components greatly improves the health and performance of your SE.
๐Ÿ” Capacitor Inspection
Before beginning a recap, check each capacitor for visual signs of failure:
  • Bulging Tops โ€“ A domed capacitor top indicates internal gas pressure and failure.
  • Leaking Electrolyte โ€“ Brown or white crust near the leads signals electrolyte leakage.
  • Corrosion or PCB Staining โ€“ Green residue or darkened board areas mean urgent replacement is needed.
Use a multimeter with ESR testing capabilities if available to confirm health.
๐Ÿ“‹ Macintosh SE Capacitor List
๐Ÿงฏ Analog Board Capacitors
The Macintosh SE analog board uses the same layout and component values as the Macintosh Plus, and should be recapped entirely for reliability.
Macintosh SE Analog Board Capacitor Specifications
C1 3.9ยตF 35V 1x
C2 4700ยตF 16V 1x
C3 220ยตF 16V 2x
C5 47ยตF 10V 1x
C6 22ยตF 50V 2x
C10 33ยตF 16V 2x
C11 10ยตF 160V 1x
C12 22ยตF 50V 2x
C18 33ยตF 16V 2x
C24 2200ยตF 16V 4x
C27 2200ยตF 16V 1x
C28 1000ยตF 16V 1x
C30 2200ยตF 16V 1x
C31 220ยตF 16V 1x
C32 2200ยตF 16V 1x
C33 4700pF 250V 2x
C34 100ยตF 200V 4x
C35 100ยตF 200V 1x
C36 4700pF 250V 1x
C37 0.47ยตF 250V 1x
C38 100ยตF 200V 1x
C39 100ยตF 200V 1x
C42 470ยตF 10V 2x
C45 470ยตF 10V 1x
๐Ÿ’พ Logic Board Capacitors
Macintosh SE Logic Board Capacitor Locations
The Macintosh SE logic board contains only a few electrolytic capacitors but they are vital to system operation.
Macintosh SE Logic Board Capacitor Specifications
C6 1ยตF 50V 1x
C1, C3, C4, C5, C7, C8, C9, C10, C12, C13 33ยตF 10V 10x
> Note: Labeling may differ slightly across board revisions. Double-check values before replacing.
๐Ÿ› ๏ธ Capacitor Replacement Procedure
  1. Discharge CRT โ€“ Always discharge the CRT before any internal work to prevent injury.
  2. Disassemble โ€“ Remove the case, analog board, and logic board. Label cables if necessary.
  3. Remove Capacitors โ€“ Desolder cleanly using a pump or braid. Avoid damaging traces.
  4. Install Replacements โ€“ Observe polarity markings. Most electrolytics are polarized.
  5. Solder Carefully โ€“ Apply clean, even solder joints. Trim excess leads.
  6. Inspect & Test โ€“ Use a multimeter to test continuity and check for accidental shorts.
  7. Power Up Carefully โ€“ Apply power while monitoring voltages and behavior.
  • Temperature-controlled soldering iron (fine tip)
  • Desoldering pump or braid
  • Multimeter with continuity/ESR testing
  • Isopropyl alcohol (99%) and antistatic brush
  • Lead-free or leaded 0.5 mm solder
  • Protective eyewear and insulated gloves
โš™๏ธ Voltage Adjustment After Recap
After reassembly, verify voltage rails at the floppy drive power plug:
  • +5V Rail: 4.85V โ€“ 5.15V
  • +12V Rail: 11.9V โ€“ 12.7V
Use the analog board trimmer potentiometer (R56) to fine-tune if necessary.
๐Ÿ’ก Additional Tips
  • Power up the SE at least once every few months to keep capacitors healthy.
  • Use high-quality brands (e.g., Nichicon, Panasonic, Rubycon).
  • Double-check polarity before soldering any capacitor.
  • Clean the board of any capacitor residue using alcohol after desoldering.
  • Dispose of old capacitors at an approved electronics waste center.
